Old 07-09-2012, 07:31 PM   #2896
Just wanted to let everyone know about our new 12th and 10th scale pan car tire truing adapter. This really helps get a true running tire by clamping the wheel the same way as when the wheel is attached to the hub with the mounting screws. Check it out at www.teamtamale.com.
CRC 1/10 Pan Car-tt1546.jpg
team_tamale is offline   Reply With Quote
Old 07-09-2012, 08:14 PM   #2897
Suspended
Trader Rating: 86 (100%+)
add front wheel bearings on the list
Originally Posted by Still Bill View Post
Atown,
Front steering blocks (come as pair with right and left blocks). They can come with either 5/64" or 1/8" axles; so, check for which one you have. 1/8" axles are fairly new. 5/64" axles use #3251 blocks and 1/8" axles use #3221 blocks.
And a spare set of either 5/64" or 1/8" front axles. #3235 and #1236 respectively.
#3281 Clamping Side links (pair).
#1728 Large D-Ring Axle for 1/10 scale (each). In case you have a big impact involving the rear end.
Post a picture of the car and I may come up with some other items to suggest. What bumper does the car have?
Bill
littlealex is offline   Reply With Quote
Old 07-09-2012, 08:17 PM   #2898
Suspended
which spec tire would you recommand for gen x le?
i m having my first pan car trophy race in a month
thanks
Old 07-09-2012, 10:35 PM   #2899
got to be the CRC spec tyres, I have tried others but couldn't get consistant results like I do with the CRCs!
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 07-09-2012, 11:57 PM   #2900
2wdrive's Avatar
Hi,
I did a search but could not find it. I was wondering if the Calandra Pro Strut Steering Blocks: Gen-Xi CLN3221 have the same dimensions and geometry as the old associated dynamic strut spindle? Reason i ask is that i wanted to put a crc suspension on a car that was designed for the old associated strut but i got ackerman (too extreme) and some other geometry problems with the standard crc steering spindle (with the graphite #1752 part). Was wondering if the new spindle will get me roughly the same steering geometry as the old associated strut suspension. Maybe someone has 1:1 experience with it already.
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 07-10-2012, 08:34 AM   #2901
joeymdz's Avatar
Send a message via MSN to joeymdz
are you guys still making the rear motor pod/ rear bulkhead? i didnt see them on your site anymore
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 07-10-2012, 10:24 AM   #2902
We sold out of the new rear pod a while back. I have more material to make some more. I have a couple of other projects to finish up, then I will get back to making some more before IIC and carpet season fires back up.
Old 07-10-2012, 05:55 PM   #2903
Suspended
is bsr same as crc tires? they look the same but have different part numbers
Old 07-10-2012, 11:18 PM   #2904
joeymdz's Avatar
exact same
Old 07-11-2012, 01:16 AM   #2905
CypressMidWest's Avatar
Atown,
Just thought of an even more important part. CRC #1766 Rear Bottom Plate (for rear pod). I have had a few of these get tweaked in big shunts. Not necessarily broken; but, no longer lays flat on a setup board making it difficult to properly setup the car.
Cheers!
Bill
Loosening of all the screws in each bulkhead after every big shunt will make this piece (1766) last a lot longer. I've actually been loosening all the bulkhead screws and re-tightening after every run lately. Really helps prevent tweaking of the 1766.......
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 07-11-2012, 05:11 PM   #2906
Will your 1/10th tire adaptor work on a Maxi-mod?
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 07-11-2012, 06:38 PM   #2907
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I googled Maxi-mod but got doll pictures. If you explain, post a picture I can tell you if it works or not probably.
Old 07-11-2012, 07:05 PM   #2908
Someone else emailed me the same question. I depends on the knob that comes with your arbor. If the threads start at the end of the knob, it should work. The reason I supply a 6mm knob is the latest Hudy arbor comes with a 6mm machined knob that has a c'bore in the end and the threads will not engage the arbor when using my adapter.
Old 07-11-2012, 07:56 PM   #2909
Still Bill's Avatar
Kewl idea. Have not tried it; but will...When I go 400 miles to the nearest carpet track...<sniff>
See ya at the IIC.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 07-11-2012, 09:34 PM   #2910
Trader Rating: 23 (100%+)
I have some brand new BSR tires for sale. Here is a link to the listing, On Road Foam Tire Lot - Fronts and Rears.
AtownT is offline   Reply With Quote
