Old 05-01-2012, 09:14 PM   #2821
Still Bill's Avatar
Long upper arms have less camber gain than the standard arms as the front suspension works. They really help eliminate a car's tendancy to traction roll when track gets overly grippy (common at a major event). A great tuning aid.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 05-02-2012, 02:14 AM   #2822
cheers for that bill!
Don't know if we will get to the levels of grip here in the UK but that will be a good thing to remember if needed.
Its the start of the UK National series this weekend and I can't wait! Will try and get plenty of pics for everyone.
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 05-02-2012, 11:49 AM   #2823
CypressMidWest's Avatar
I actually run the long-arm set-up everywhere I go. I just prefer the more linear steering feel it gives the car. Good luck at the first Nationals series race this weekend Chris. I'm looking forward to your updates on your blog, always good stuff.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 05-02-2012, 06:19 PM   #2824
Still Bill's Avatar
Cheers for letting us in on your car experiences Chris. I may get over there for some WGT racing at some point in time.
Bill
Old 05-02-2012, 07:03 PM   #2825
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
ooops!
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 05-03-2012, 12:32 AM   #2826
what body shells do you guys prefer with these?
ben w is offline   Reply With Quote
Old 05-03-2012, 12:33 AM   #2827
master__john's Avatar
Default asd
Sorry wrong thread.
real
master__john is offline   Reply With Quote
Old 05-03-2012, 05:00 AM   #2828
The Protoform Sophia is THE shell to have in WGT at the moment, other shells do work but not as well as that. Hopefully someone will bring out a different looking shell that will handle similar so we can have different looking cars on the grid!
Old 05-03-2012, 07:40 AM   #2829
I tend to disagree. The Parma DB9 works at least as well, and IMHO better than the Sophia. I have each shell, and use them as a tuning aid. Three of the top drivers at the last ROAR region 5 race were running DB9's.
Set-up and personal driving style dictate which body will work better for a given individual. I prefer to drive a car with alot of steering. The DB9 offers more front downforce, and seems to rotate a little quicker through the corner.
In instances where the track is EXTREMELY high bite, and the car is driving "on the nose" the DB9 can be a bit aggressive. Under these conditions a Sophia can smooth out a tippy or twitchy car.
Old 05-03-2012, 07:44 AM   #2830
liljohn1064's Avatar
Trader Rating: 16 (100%+)
They're on and ready for tonight! I might have a couple runs left in my old front tires. I'll report back after giving it a few runs.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 05-03-2012, 07:50 AM   #2831
And your car is absolutely glued to the track all the way around. I do actually take a break to watch your practice runs. I have never seen a car that is so .... making this up.... aggressively neutral as your's.
Old 05-03-2012, 10:22 PM   #2832
Thanks John!!
Just thought I'd share my set-up for those who may be interested. She's not pretty, but she gets the job done
Front:
long arms
inline axles
mounting plate set forward
12th kingpins
45 springs
kingpin length set to just touching spring
5k lube
1 caster shim forward, the rest back
2 degrees camber
Servo angled
zero toe
10 degree blocks
4.25mm ride height
Rear:
.25 inch forward shockmount plate, 3mm spacer under ball on plate
Shock mounted in third hole from rear on topdeck, 2mm shim under ball
CRC Green spring, 30wt. oil
20k in tubes
White springs set to just touching plate
.25mm pod droop
4.25mm ride height.
Battery against molded stop mounted in forwardmost location
chassis set level
Parma DB9 body
Did I miss anything?
CRC 1/10 Pan Car-2012-05-03_18-26-43_598.jpg
Old 05-03-2012, 10:30 PM   #2833
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thanks for posting that
We'll see if that helps the locals at TQ get on pace with the CRC
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-03-2012, 10:36 PM   #2834
Not a problem Mr. Berger. I've found the forward mounted shock and softer center spring to be one of the most beneficial changes I've made.
If they have any questions let me know......
Old 05-03-2012, 10:46 PM   #2835
These are just props to my paint and graphics guy. Look up Mudvayne here on RCTech. RK Designs gets it done.
CRC 1/10 Pan Car-wgt2.jpg   CRC 1/10 Pan Car-wgt1.jpg
