Old 03-02-2012, 10:38 AM   #2761
joeymdz's Avatar
Send a message via MSN to joeymdz
Originally Posted by dumper View Post
hold it in front of your face, open your eyes.
I only have 1 working eye you insensitive JERK!
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 03-02-2012, 11:19 AM   #2762
Using the ways of the force is in the Dumper's Speed Shop advanced classes.
I don't meet the pre-requisites...
JoelV is offline   Reply With Quote
Old 03-02-2012, 11:30 AM   #2763
wingman2's Avatar
Originally Posted by joeymdz View Post
i didn't answer my own question... i was just sharing my info
I'm not the only one that is switching back to the stock location (as per some of the local big race travelers)
OKAY OKAY I WAS WRONG (in "MY" eyes its easier to stiffen the rear to get more steering then changing the battery position)
Exactly what I do mate! Changing the centre shock spring and/or side springs is MUCH easier! Generally, the stiffer the springs, the quicker the steering response but watch how much additive you put on the fronts as it'll be a nightmare to drive else!
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 03-02-2012, 02:51 PM   #2764
hyperdrive1's Avatar
At my local track, BMI and AE run thier batteries sideways and handle pretty well, I personally haven't seen a CRC with the battery sideways.
Don't know that I even want to test this and have to move all my electronics around. I'm not going to go against the grain, I'll mount my battery like most other CRC guys do, but was still curious if that setup works....I mean after all, CRC LE chassis is capable???
Benny ( The Jet )
CRC...LE chassis...Fut 4PKS....Tekin RS
hyperdrive1 is offline   Reply With Quote
Old 03-02-2012, 05:52 PM   #2765
gonzo416's Avatar
Trader Rating: 39 (98%+)
Great deal on a great car, check it out:
WORLD GT - CRC - NEW SPARES (CHEAP)
gonzo416 is offline   Reply With Quote
Old 03-02-2012, 11:47 PM   #2766
I know that Andy Griffiths ran his at the rear across the chassis and kicked ass with it but he is an amazing driver!
I don't really want to do that as I would have to but the encore shock and mess about with cell tape again!
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 03-03-2012, 08:18 AM   #2767
I have decided to try this setup. Only thing I had to do is drill three hole for battery holder. This is a similar setup to AE and BMI. If it doesn't work, I'll just remove the single battery holder and put it long ways down the middle.
CRC 1/10 Pan Car-new-chassis.jpg
Benny ( The Jet )
Old 03-03-2012, 08:41 AM   #2768
Norman2's Avatar
Hi, This is the set up I use as it seems this will give me the right balance
for the car. Has worked fine up to now. Good Traction and steering.
Regards,
Norman2
CRC 1/10 Pan Car-img_0003.jpg
Norman2 is offline   Reply With Quote
Old 03-03-2012, 08:58 AM   #2769
Regards,
Norman2
Thanks for the input Norman. I thought about trying that but didn't want to alter my shock mount setup. This way I can quickly remove the battery holder and run it long ways if need be. I don't feel like it's too far forward because it's similar to where BMI and AE run theirs and at out track, they do a lot of winning.
I won't get to test this til Wednesday, but hoping to be pleasantly surprised?
I was looking at your tires, is that setup for pavement?...On our carpet setup we cut them down to roughly 2.08 or so...give or take and run them down from there. Never seen anyone run them with that much foam, but then again I haven't seen them run on pavement, if in fact that is how they run them?
Thanks again for the vote of confidence that your setup works.
Benny ( The Jet )
Old 03-03-2012, 02:24 PM   #2770
Looks like I might have to scratch how I have my battery. I put my electronics behind the battery, finished setting the car up and it is so left side heavy...can't add enough weight to balance it. Even if I put all my electronics on the right, still don't think that would be enough.
I will mess with it all day tomorrow and see what I can do.
Benny ( The Jet )
Old 03-03-2012, 02:50 PM   #2771
OK, scratch that last post. The surface I had my pins on wan't flat.
It is now balanced and not tweaked. Few things left then race it Wednesday night!
CRC 1/10 Pan Car-new-chassis-setup.jpg
Benny ( The Jet )
Old 03-04-2012, 06:14 PM   #2772
Been there, done that, will never do it again.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 03-04-2012, 07:27 PM   #2773
Norman2's Avatar
Hi, The class I plan to run is the Nascar Oval spec on a asphalt banked
oval. we have the use the foam spec tire and cannot modify them also
must be the compound I have in my photo. Here is a photo of the cars
I will be running. They only last two weekends on asphalt. Regards
Norman2
CRC 1/10 Pan Car-img_0002.jpg   CRC 1/10 Pan Car-img_0001.jpg   CRC 1/10 Pan Car-img_0004.jpg
Old 03-04-2012, 08:13 PM   #2774
Norman2
Good to know Norman. I thought maybe that was the case. We cut ours down around the 2.08 and usually get about 3 race weeks out of the fronts, rears last a little longer. Great looking cars you got there!
Benny ( The Jet )
Old 03-04-2012, 09:57 PM   #2775
joeymdz's Avatar
Lol....
