Old 01-16-2012, 07:06 AM   #2626
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by XesbyecroF View Post
i think that i have too much camber for starting rounds.. what do you think?0 dregree dynamic caster,5mm height front..some advice please for tweaking...i am a new guy
Yeah, that looks like alot.
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 01-16-2012, 07:14 AM   #2627
westy1969's Avatar
That depens on the wear of the tire, when its a flat wear than its ok.
Me my self use about 3 degrees of camber on one site because of the high speed sweeps on that side.
CRC Gen-X 10 200mm indoor-setup | CRC PX10W full 235mm
westy1969 is offline   Reply With Quote
Old 01-16-2012, 07:22 AM   #2628
westy1969's Avatar
A Friend and me did some training last week.
Finaly it went well for him, and we discovered that his tyre choice was wrong.
+ YouTube Video
Old 01-16-2012, 07:33 AM   #2629
2wdrive's Avatar
Seriously if you are completly new to pancar (and it seems you are) then i would not start with a 3.5t. A 13.5t or 10.5t and 2s is more then enough then. You will not be too happy trust me. It doesn't mean that dedicated pro10 modified cars can't handle a 3.5t as i know they can but your setup and driving skills aren't up to the task of handling that car. A pancar can go as fast as a driver can handle.
anyway... set 1.5-2 degree camber both wheels. After driving look how the tires wear. As a guide, when the tires wear cone shape then adjust camber accordingly so the wheels wear flat. Usually one side needs more camber then the other side. That is ok as long as both sides wear flat. Before driving tweek the car with the coin trick so the pressure on both front wheels are the same.
Set ride height to at least 6mm both front and back and cut off the exces bodypost
Good luck, i think you will need it.
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 01-16-2012, 07:44 AM   #2630
Default Cool
So cool cars,never seen before,
Aaron chen is offline   Reply With Quote
Old 01-16-2012, 08:48 AM   #2631
XesbyecroF's Avatar
Thumbs up
what price of coin do i need?im just kidding (i did the thing with the coin everything is ok )thanks 2wd for helping me ..i know 3.5t is more than enough but this motor was in my garage for three months thats why i put it..i hope i can find traction in my track the biggest problem..i will find what compound do i need and other staff but everything you say is a big word for me and i will remember them..all the advise are welcome
XesbyecroF is offline   Reply With Quote
Old 01-16-2012, 09:27 AM   #2632
2wdrive's Avatar
For the coin trick, don't use any Euro coins. It is too unstable at the moment
I use two coins of 1 (chinese) yuan myself
www.rc-lemans.de
Old 01-16-2012, 10:45 AM   #2633
NiMo's Avatar
Thumbs up
Like
NiMo is offline   Reply With Quote
Old 01-16-2012, 02:51 PM   #2634
Exclamation
TOO FUNNY!!!!
Try Canadian pennies, we are pretty stable........3.5 2S....
Have fun
THEBIGBULL is offline   Reply With Quote
Old 01-16-2012, 03:55 PM   #2635
Still Bill's Avatar
Default Currency jokes aside...Forget the coins.
Just find the front center of the car (look for small balancing hole in chassis) and use an Xacto knife at that point to pickup the front end to check for tweek. See which front tire comes off of the setup board or flat surface first and adjust tweek screws at rear of the car accordingly.
Rarely got any consistency in the results from using coins myself.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is online now   Reply With Quote
Old 01-17-2012, 05:43 PM   #2636
RcChaos's Avatar
Trader Rating: 40 (100%+)
Default wgt 13.5 help
Just getting in to.wgt
trying to find a starting point for gearing
any help would help
crc gen x
13.5 viper bl motor
takin rs
got new tire just need to get them cut down
Team Chao
SC10 4x4 EXOTEK ft upgrade Rx8 Novak 550 4.5t M11 nano-tech Rcshox cdiff pistons
Orlando Fl
RcChaos is offline   Reply With Quote
Old 01-17-2012, 10:06 PM   #2637
Still Bill's Avatar
any help would help
Too little info to say...
Old 01-18-2012, 03:53 AM   #2638
XesbyecroF's Avatar
Thumbs up
Bill
how many differentials balls is better to place ?8 or 16?and why is everyone changing the king pins to 1/12pins is it better for carpet set up?is this gonna make any difference for me?
p.s i love this car.. a guy did 120km to see this thing from a close view here in my country..
Old 01-18-2012, 06:28 PM   #2639
Still Bill's Avatar
Use 16 each of the 3/32" (2.4mm) diff balls. If running outdoors, you might want to try the 12 ball Kimbrough spur gears that have an optional dust cover for each side of the gear. I typically use an 88t 64 pitch diff gears for all situations using up to 10.5T motors.
The 1/12th scale king pins and springs are for carpet racing.
And what country is that?
Bill
Old 01-19-2012, 02:57 AM   #2640
XesbyecroF's Avatar
Thumbs up
Bill
i use kimbrough ..do you have a link for the optional dust cover?i wear 90t 48p ..so i will put all the balls to the differential spur ..country Hellas
