Old 01-07-2012, 05:58 PM   #2581
elex300's Avatar
Trader Rating: 102 (100%+)
Originally Posted by CypressMidWest View Post
Hitec has made great strides in servo quality lately. I know they have two new servos in their line-up that are tailor made for pancar racing (the 225 is not one of them). Someone please test them and give us a report.......
I've been using the 225mg in my 10le for 2 weeks now without a single problem. I did buy a JR3650 but ended up buying a 12th scale so I put it in that. I hav'nt seen a difference yet. The Hitec centers perfectly everytime. Maybe it's a hit or miss type thing. I would like to try the 445mg to see how it performs.
Erik Everett
EZ Customs (Rc Painting) www.facebook.com/ezcustomspainting
Jconcepts - Trinity/Revtech - Xtreme Hobbies - RCADDICTION Products
elex300 is offline   Reply With Quote
Old 01-08-2012, 12:46 AM   #2582
CypressMidWest's Avatar
Good to hear. The last 225 I tried was SEVERAL years ago. Perhaps they've upgraded that servo since then.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 01-11-2012, 01:19 AM   #2583
hi. I just bought a 235mm expansion kit for the LE but could not work out what one pair of parts fit.
It's the two smaller plates on top. Since they are not shown to be used on the CRC site I am beginning to think that they are not required. If not, what are they for? Thanks.
The chassis looks so wide even just with the rear adapters fitted.
one-nil is offline   Reply With Quote
Old 01-11-2012, 05:07 AM   #2584
westy1969's Avatar
Hello one-nil
Stack the 2 carbon parts on to each other, and than mount them to the chassis.
its hard to see on the picture..
CRC Gen-X 10 200mm indoor-setup | CRC PX10W full 235mm
westy1969 is offline   Reply With Quote
Old 01-11-2012, 06:12 AM   #2585
XesbyecroF's Avatar
Questions??
guys i want to change the spur gear to 48p..i bought one from kimbrough 90t 48p form amainhobbies i cant post a link.. i have the le edition! do i have to change the diff balls(1/8) because its to small for the 48p halls,what about the d rings.. is the biggest ones that le editon has?or do i need other part?(Large "D" rings)
XesbyecroF is offline   Reply With Quote
Old 01-11-2012, 06:25 AM   #2586
westy1969's Avatar
The large D-ring will be fine.
Old 01-11-2012, 06:48 AM   #2587
XesbyecroF's Avatar
thanks westy..but what about the balls?and why you dont put the a arm in the last halls of the 235mm kit and you put it in the inside?my rear wheels tires are wider than the front 230mm rear 215mm front whaen i do this..
Old 01-11-2012, 07:19 AM   #2588
westy1969's Avatar
Because the electric bodies are smaller at the front. (215mm)
So i had to use the smaller option.
I dont understand what you mean with the balls?
Old 01-11-2012, 07:33 AM   #2589
XesbyecroF's Avatar
if the front is wider do we have better handling?
i have problem with the diff balls..in the le edition are 1/8 but they dont fit in the kimbrough spur halls spurs halls are bigger..do ia have to chang diff balls..sorry for my english..
Old 01-11-2012, 07:45 AM   #2590
EricF's Avatar
Kimbrough spur gears use 1/8" balls in the "holes" Don't worry about your english.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 01-11-2012, 07:55 AM   #2591
XesbyecroF's Avatar
E
Kimbrough 48P Spur Gear (90T)
[KIM149] from amainhobbies this is my spur i cant post the link sorry
Old 01-11-2012, 05:14 PM   #2592
Thank you westy1969!
Hello one-nil
Old 01-11-2012, 06:30 PM   #2593
Still Bill's Avatar
The wider front end can give you more stable handling; however, it can also slow down the steering response too. Otherwise, you probably will want your car's front end to be no wider than the body allows so you have reasonable tire to body clearances.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 01-11-2012, 06:33 PM   #2594
Still Bill's Avatar
I believe you will find these plates shown in the original Gen-X 10 Pro manual (on the CRC website). Probably not in the LE manual. They should be stacked under the larger plates to allow you to run larger front tires on you car without adding other shims to get to proper front ride height.
Old 01-12-2012, 12:18 AM   #2595
XesbyecroF's Avatar
Wink
Bill
thanks bill..guys what pinion do you suggest for a 1/8 track 2s lipo 3.5t motor 64p 88spur?
