Old 12-19-2011, 11:09 PM   #2536
Still Bill's Avatar
Expecting hate mail from Team Hitec any time now...Popcorn pleeeeze...LOL
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 12-19-2011, 11:30 PM   #2537
el salvador's Avatar
Lightbulb
Why ? Did you tell "the Hitec Police" what I said ?
Note to all of the Hitec Nazi's out there: I must have spent at least an hour on the track trying to fine tune via subtrim and whatever else I could think of, in an attempt ot FIX a car that would drift to the left, then to the right, back'n forth, over'n over (definition of insanity verified then reverified yet again), and all the time it finally proved to be the F^$#*&!@ing Hitec servo!..........There, now I feel better.......
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 12-20-2011, 04:16 AM   #2538
Trader Rating: 76 (100%+)
Originally Posted by CypressMidWest View Post
Nope it's this one.... sorry for my intarweb faux pas....
http://www.teamcrc.com/crc/modules.p...prodID=7718958
It scares me when you use words like "faux pas".
MUDVAYNE is offline   Reply With Quote
Old 12-20-2011, 09:48 AM   #2539
CypressMidWest's Avatar
Well I could have used another f-word, but this is a family forum.......
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 12-20-2011, 01:22 PM   #2540
XesbyecroF's Avatar
Questions??
what parts of screws do i need to install the Reverse/flat servo mount plate ..it says something about..Will need P/N 3315 - Flat servo mounts and 1424 - 1/4 in. flat head screws to reverse mount the servo..(Hitec HS-225MG servo ) please a link or some advise..thank you..
XesbyecroF is offline   Reply With Quote
Old 12-20-2011, 01:34 PM   #2541
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
The flat mount servo mounts, 2 button head screws, 2 flat head screws and the plate (17420 or 17403) is all you need.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 12-20-2011, 06:54 PM   #2542
Still Bill's Avatar
Wow! Another Hitec servo! What is WGT coming to?
Two (2) 4-40 x 1/4" flat head screws to attach mounts to chassis plate.
Two (2) 4-40 x 1/4" button head screws to attach servo to mounts; OR, can use flat head screws with the anodized aluminum countersunk washers to add a tad better support to the servos tabs and a cleaner look.
Bill
Old 12-20-2011, 09:59 PM   #2543
Hitec has made great strides in servo quality lately. I know they have two new servos in their line-up that are tailor made for pancar racing (the 225 is not one of them). Someone please test them and give us a report.......
Old 12-21-2011, 06:17 AM   #2544
XesbyecroF's Avatar
thanks guys...
Old 12-21-2011, 08:28 AM   #2545
Robudda723's Avatar
Trader Rating: 21 (100%+)
First time with a pan, Raced off-road on and off for a while but started with an 18r and a touring car to get started on-road a couple weeks back. Looking for a general setup for my new CRC Pan to run on Carpet. I will start off with the setup on the CRC site. However have no clue about rollout and esc settings. It is a smaller track 150ft straight small tight infield.
The car has the 88 tooth spur.
LRP SXX Comp ESC
Everyone here runs the rear foams cut to 57mm, so the store owner cut mine the same, and CA'd the side walls front and rear.
1s Battery
10.5 motor
I am not sure of a recommended rollout, and LRP ESC settings for this, any guidance would be awesome. One local racer recommended a 37 tooth pinion to start, but not sure if that is based on the 88 tooth spur or the old 96 (Not sure what came originally) tooth.
Thanks,
Rob
Robudda723 is offline   Reply With Quote
Old 12-21-2011, 09:08 AM   #2546
joeymdz's Avatar
Send a message via MSN to joeymdz
i am going BACK to the original servo mount set up. i tried it for 3 days now and not having any luck with it. i race mostly on a smaller track and with the reverse set up its giving me way to much steering input at slower speeds and with on power steering.
i guess im an old dog that cant learn new tricks
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 12-21-2011, 09:27 AM   #2547
Lightbulb
Is you're Avatar a pic of Jacko ?
If so, that would explain too much steering..........
Old 12-21-2011, 09:35 AM   #2548
joeymdz's Avatar
haha it kinda does look like jacko mate! (ops wrong accent)
just talked to Camou and he said my issue was with trying to eliminate the bump steer... and i need to live with it
I'll get some fresh cuts and try it again.... BUT so far im not liking it
and to explain my issue its not allowing my car to push when im exiting the corner for on throttle power. im not sure if its the servo weight loading the front or due to the different ackerman?
Old 12-23-2011, 03:55 AM   #2549
rcgen's Avatar
LRP SXX Comp ESC
1s Battery
10.5 motor
Thanks,
Rob
Rollout formula = tire (57) x pie (3.14) x pinion (37) / spur (88)
Use rollout as a base since it will depend on type of esc and motor brand.
rcgen is offline   Reply With Quote
Old 12-23-2011, 09:46 AM   #2550
joeymdz's Avatar
LRP SXX Comp ESC
1s Battery
10.5 motor
Thanks,
Rob
or save this link on your desktop
http://gearchart.com/index.cfm?fuseaction=chart.create
