Old 12-08-2011, 06:38 PM   #2461
eevul's Avatar
Originally Posted by OVA View Post
Have you drove Korage Xray ??
No, I have never driven Korgae's Xray. I did drive 3 other XRays and I believe one of them was Frank's old one. The cars were just ok. I loved my CRC from the first day I hit the track. Other people that have XRays have also switched after driving my CRC. I find the CRC easy to drive. It is almost too easy but you have to remember, I have been driving a Tamiya Mini for the last two years so any pan car would be a huge improvement.
eevul is offline   Reply With Quote
Old 12-08-2011, 11:18 PM   #2462
Still Bill's Avatar
Originally Posted by RedBullFiXX View Post
13.5 blinky WGT is quick on our 90x45 rug.
We run the same laps as 12th blinky, mid 10s
No CRC Team drivas down here that I know of, but plenty of CRC cars of course.
On our 90x42 rug, Crashby and I have touched 8.6 a couple times with 13.5 boosted. Other WGTs have done 8.7s. 12th blinky is down to low 9s. Track is reconfigured for this week's points race; so, we will see slower laps with the new groove just being started.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 12-09-2011, 03:15 AM   #2463
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Bill
TQRC Track record is currently 9.9 with my R5.2
In the past we have had some 8s layouts
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-10-2011, 11:46 PM   #2464
flatusboy's Avatar
Trader Rating: 42 (100%+)
Can I upgrade the steering blocks on the LE to the same ones as on the Xi?
Of course, that would include axle, bearings, etc...
Or, can I only change the kingpin and springs to the 1/12 version?
-- Team C Racing USA -- Team ReVtech -- Team Radiopost -- Team Terribles -- CKHobby.com
flatusboy is offline   Reply With Quote
Old 12-11-2011, 02:00 AM   #2465
I am going to wing it, and say yes. Since the same front end was used on the 1/10 as the 1/12, I cant see why you couldnt make the change.
Shawn
Shawn68z is offline   Reply With Quote
Old 12-11-2011, 09:13 PM   #2466
Still Bill's Avatar
You can. I have had the new steering blocks and steel axles on my two LE's (carpet & asphalt) since the IIC. Carpet uses 1/12th kingpins while asphalt has 1/10th units.
Make sure you also get 1/8" x 5/16" flanged bearings and 1/8" shims for the new axles.
Bill
Old 12-12-2011, 04:26 AM   #2467
flatusboy's Avatar
Bill
Old 12-12-2011, 07:54 AM   #2468
eevul's Avatar
Is anyone else having problems breaking the following part:
http://teamcrc.com/crc/modules.php?n...prodID=7718920
I have a friend of mine who recently bought the GENX 10 LE and he has broken these same parts every time he goes out and races (usually 1 - 2 of these per weekend). I have never broken mine but my car was upgraded from the original Gen X to the LE. Is the plastic weaker on the newer parts? I have already had him purchase the foam front bumper and it seems to have helped but regardless, he is still breaking the same part. I know, I already told him to stop hitting stuff but it seems that he is breaking these parts rather easily.
Old 12-12-2011, 08:22 AM   #2469
briankstan's Avatar
I've broken 1. it was completely my fault, it sure wasn't the walls fault as it had position and held it.
They aren't made for impacts. My advice would be to slow down a bit and run cleaner, it will be faster in the end as well.
www.slmini-zstore.com
www.saltlakemini-z.com/forum
www.howfastareyou.com
briankstan is offline   Reply With Quote
Old 12-12-2011, 08:23 AM   #2470
I broke one at the last meeting but it was very old and it was a very hard hit!
Check that he isn't tightening up the plastic part which hold the pivot ball in place. If that is too tight/not free it can cause extra stress on the parts.
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 12-12-2011, 09:34 AM   #2471
Default new front end
Could some post some photos of the new front end,servo flipped, link age positions etc any packing under ball.
I found holes for servos only lined up for a Futaba s9650 ,couldnt fit the KO servo with drilling fresh holes little dissapointed not mulitiple drillings for servo adjustments.
vinster is offline   Reply With Quote
Old 12-12-2011, 09:39 AM   #2472
There are multiple pictures. Scroll back a couple of pages.
The front end plate has two sets of holes. JR, Futaba, KO, Spektrum and Hitec all fit. Still Bill used a KO servo in Vegas and did not have to drill holes.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 12-12-2011, 09:46 AM   #2473
nitrobeast's Avatar
Trader Rating: 41 (100%+)
When the get the servo installed make sure you shim the links so they are nice and straight. I found this is what works best on carpet.
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 12-13-2011, 03:06 AM   #2474
Default Dumper
Hi Brian
i tried fitting the KO PDS-2413ICS which i had ran on my car for the last 12 months with out a problem and i can assure you it does not match up with any of the holes on the new servo plate .Ive had to fit my spare Futaba S9650 which fits with out a problem.
I dont have an option for drilling holes so took the easy way out and fitted a new servo. .
Old 12-13-2011, 08:37 AM   #2475
nitrobeast's Avatar
Never broke 1 and have had some really hard hits . Make sure something else isn't broken or bent that might be causing it.
Rui Goncalves
