Old 11-26-2011, 11:33 AM   #2401
flatusboy's Avatar
Trader Rating: 42 (100%+)
Finally got around to pulling the used LE apart...lots of stripped screw heads.
There is also a Kimbrough 78t 48p spur on here. I dont have spare CRC ones (yet), so whats a good gearing to get started with?
Going to be running 13.5, 1s, non-boosted.
-- Team C Racing USA -- Team ReVtech -- Team Radiopost -- Team Terribles -- CKHobby.com
flatusboy is offline   Reply With Quote
Old 11-26-2011, 12:24 PM   #2402
joeymdz's Avatar
Send a message via MSN to joeymdz
What size of a track? How big are your tires? Any hot blondes in your area? Things we need to know to help you out
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 11-26-2011, 01:07 PM   #2403
If this is for RC Addictz, I would start about with rollout ~ 3.15in(80mm). That's what I'm going to start with when I finish putting mine together.
Regards,
Carter
darcydawg is offline   Reply With Quote
Old 11-26-2011, 02:18 PM   #2404
Trader Rating: 15 (100%+)
Default question
I am new to 1/10th pancar and running the WGT class. I having an issue with the car and can not figure it out. When I come around some corners the front and rear want to trade places. Track type is asphalt.
I have glued the front tires, I am running green springs upfront, white center with 35 losi oil, I have shorted the shock length to remove droop, green rear springs, not sure whats in the rear tubes. Running 1 1/2 camber, wgt, sohpia body, ride weight is 4.5 all around.
I have checked the car for tweek, and recut the tires.
Any suggestions.
mdhyams is offline   Reply With Quote
Old 11-26-2011, 02:45 PM   #2405
flatusboy's Avatar
Regards,
Carter
Yup it is. Thanks.
Glad to see another one is going to come play.
Old 11-26-2011, 05:39 PM   #2406
Still Bill's Avatar
Default Some guestions...
Any suggestions.
WGT to me means 13.5 boosted. Is that how you are running the car?
If so, is everyone else able to run WGT spec tires without issue?
How much traction is available on that asphalt? Is it sealed (lower traction)? Is it smooth without bumps? With bumps, you want some droop at the rear pod.
On Nor-Cal Hobby's smooth asphalt track with good traction, my LE's springs are usually red/blue/red (front to rear).
Try putting 10,000-15,000 wt lube in those rear tubes and Losi 30 wt oil in the center shock.
Put a "safety bead" of glue on the rear tires too. A "safety bead" covers the edge of the rim and spreads over to the first 1/16" of the foam. Prevents chunking the sidewalls.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 11-26-2011, 05:48 PM   #2407
Still Bill's Avatar
I run the CRC 88T 64P spur for both non-boosted and boosted on all asphalt and carpet tracks. You can get it with either 12 (standard) or 16 (optional) diff balls.
But, if you run on a track that is not really clean, the 48P spur can make sense. Kimbrough also makes optional spur gear covers that can help keep the grit out for outdoor.
Bill
Old 11-26-2011, 06:33 PM   #2408
flatusboy's Avatar
Bill
Thanks for the info Bill.
Its a new indoor track, with brand new CRC carpet, so its pretty clean. I prefer 64p for indoor, just don't have any spares yes and wanted to at least get this thing moving. I have lots of 45 (64p) and under pinions from my old TC days, just need the spur to match.
Old 11-26-2011, 07:23 PM   #2409
Default wgt
Bill
the class is non boosted. The track is smooth with great traction. No one else seems to have problems with traction. I was going to change my king pins to the 1/12 pin but I had another question. The stock kit came with a conical shaped front spring but it appears all the after markets are not tapered, do you have to change anything besides the king pin?
Old 11-26-2011, 08:04 PM   #2410
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Could you post a few pics of the car ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-26-2011, 08:08 PM   #2411
Default car
It would be tomorrow before I could do that.
Old 11-27-2011, 09:55 AM   #2412
Still Bill's Avatar
You will need 1/12th springs to go with those kingpins. Try CRC 50 or 55 springs.
Old 11-29-2011, 09:16 AM   #2413
Btw what bodies are you guys using nowadays ?
[Mugen Seiki MRX-5]
Backspace. is offline   Reply With Quote
Old 11-29-2011, 09:18 AM   #2414
Infinite 12th's Avatar
Oops
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 11-29-2011, 09:21 AM   #2415
Originally Posted by Infinite 12th View Post
As I've read most are using the Protoform AMR-12 or the Black Art RC8
But those are 1/12th bodies ! I was referring to 1/10th Pan Cars.
[Mugen Seiki MRX-5]
