Old 11-24-2011, 09:30 AM   #2386
Still Bill's Avatar
Originally Posted by audriusv View Post
I already see that my Hobbywing 120A 1S ESC will not stay long in my LE chassis...
So my old Tekin RS Pro will go in. What good booster you can suggest to get?
I got my third booster from the UK. Cannot remember its name. It was better than the Novak and TQ boosters; but, I now run receiver packs (li-fe batteries) for the highest level of performance from my pan cars.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 11-24-2011, 09:58 AM   #2387
Default booster instead of receiver pack
Best booster and most popular in the Uk is from Rcdynamics A guy called mark Jordan. Google it and you the company
vinster is offline   Reply With Quote
Old 11-24-2011, 10:12 AM   #2388
Still Bill's Avatar
That's it. Thanks Vinny.
You ready for the IIC...in 2012?
Cheers!
Old 11-24-2011, 09:08 PM   #2389
flatusboy's Avatar
Trader Rating: 42 (100%+)
Just picked up a used X-10 LE to go with the new Xi.
Does anyone have any good layout pics for the LE? Or know where to find some?
Im going to be running 1s and a Tekin RS Pro with rx pack.
Thanks in advance
-- Team C Racing USA -- Team ReVtech -- Team Radiopost -- Team Terribles -- CKHobby.com
flatusboy is offline   Reply With Quote
Old 11-24-2011, 10:50 PM   #2390
Bill
I see. So is this one will be ok for me?
http://www.ebay.com/itm/Intellect-6-...item5d2f62a100
How long I can run with one charge? Do you have two and interchange them or use only one and recharge every run?
Audrius
www.rc-cars.lt - offroad in Lithuania
www.lasa.lt - onroad in Lithuania
audriusv is offline   Reply With Quote
Old 11-24-2011, 11:16 PM   #2391
YoDog's Avatar
Trader Rating: 25 (100%+)
If you can find one of these it has a switch which makes it a bit more convenient.
http://www.dynamiterc.com/Products/D...ProdID=DYN1418
https://www.ssl-stormerhobbies.com/c...pl?pn=FAN27705
charge it after about every 2 or 3, 6 minute runs.
YoDog is offline   Reply With Quote
Old 11-24-2011, 11:51 PM   #2392
Still Bill's Avatar
Absolutely the first one with the switch incorporated into the pack and a separate lead for charging. Have this on all three of my pan cars.
The separate switch on the other li-fe unit did not stand up to normal use and had to be replaced with a better quality switch.
I charge every use. Too easy for me to forget if I did it otherwise. I use a separate li-fe pocket charger for this so I do not tie up my regular charger.
Bill
Old 11-25-2011, 12:57 AM   #2393
Thanks in advance
Hi fella, there is few pics in my blog, I use tekin rs with 1s lipo. I use a booster thought but if you put the rx pack on the opposite side to the receiver it should balance nicely
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 11-25-2011, 07:52 PM   #2394
Still Bill's Avatar
Thanks in advance
A couple pics of my carpet LE.
Tekin RS Pro ESC and SMC Li-Fe receiver pack are at the rear.
Has the new reversed servo modification shown in the second picture. A great mod.
Should have the new CRC adjustable top brace next week.
Bill
CRC 1/10 Pan Car-le-layout-002.jpg   CRC 1/10 Pan Car-le-layout-001.jpg
Old 11-26-2011, 07:59 AM   #2395
flatusboy's Avatar
Bill
Thank you both.
Old 11-26-2011, 08:16 AM   #2396
Smile
Hey guys, I wanna do the servo mod... Could someone send me all the part # that I need please... Im running 17.5 carpet.
CRC Gen-X LE 10, Novak GTB2 17.5, Sophia -- CRC Gen-X 1/12, No Motor/ESC yet
Xray X10, NO Motor/ESC yet.-------------------- Losi JRX-S Type R, Novak GTB2 17.5, BMW.
Savage, Picco .28, Mid Tank Mod, ERCM Pipe.
www.extremercforum.com
RCstraat is offline   Reply With Quote
Old 11-26-2011, 08:29 AM   #2397
http://teamcrc.com/crc/modules.php?n...windex&catid=2
that shows you all the part numbers, there are two options for the width
Old 11-26-2011, 08:55 AM   #2398
Wink
Thanks, so if im reading it right i need to order..
17402 + 17403 + 1776 3-piece ... only thing i cant seem to find is the servo mounts... I see the part #3315. Just cant see to located it on the web... Anyone wanna help me out please!!!
Old 11-26-2011, 09:06 AM   #2399
Infinite 12th's Avatar
http://www.google.com/search?rlz=1C1...c+servo+mounts
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 11-26-2011, 09:15 AM   #2400
Still Bill's Avatar
Stay in the CRC website and use the search function (using "3315") to find the plastic servo mounts - flat.
And I suggest that with your non-boosted car, you will want the standard width plate. With the wide plate, the front tires are all the way out to the full width of the Sophia body. I have both plates to tune my steering to the track conditions.
Bill
SEO by vBSEO 3.5.0
