Old 10-18-2011, 08:33 PM   #2296
Still Bill's Avatar
Originally Posted by chris_blakey View Post
cheers bill will get one ordered. had a good weekends racing, updated my blog with a race report and some pics:
http://rcgtpancars.blogspot.com/
Chris,
Thanks for the blog update. Love those pictures and your commentary.
Fun to see Kevin and his wife in one of the pictures...just like they were at the IIC.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 10-19-2011, 07:44 PM   #2297
Having trouble building the pro strut front end on pg10 for parts #56 upper a arm, #53 upper arm mount #59 upper cap. Which part is supposed to rotate and which stationary? Is it 1. The pin held stationary by the arm mount + upper cap and the upper A arm rotates on the pin. Or 2. The A arm + pin held stationary against each other (pin felt tight when pushed all the way through) and the pin/A arm assemble rotates inside the arm mount/upper cap?
I found if I leave the upper cap screws loose enough for the A arm to move freely, there is a gap. If I tighten it a little bit more the gap disappears but now the arms cannot fall down on their own. I am not sure where to trim on the mounts as suggested on pg 10 of the manual. There is still a very slight gap for the A arm to move fore and aft so itís not binding in that direction. Unless I make the trough of the arm mount wider or filing it deeper? Thanks for any help on this.
one-nil is offline   Reply With Quote
Old 10-19-2011, 08:10 PM   #2298
Still Bill's Avatar
Simply...I usually have to sand both ends of the top caps a small amount with 800 sandpaper to get the fit right. I never get to fully tighten down the 8 small screws that hold the two top caps in place.
For these surfaces, my little white spacers are placed:
asphalt = 2 spacers back/1 forward
carpet = 3 spacers back/0 forward
Bill
Old 10-20-2011, 01:12 AM   #2299
Bill
thanks Bill, will try sanding again, although as I said before there is enough room for the upper A arm to move fore and aft. Also, thanks for the tip on the spacers. Good to know that the kit setting will be for asphalt.
Old 10-20-2011, 10:31 AM   #2300
joeymdz's Avatar
Send a message via MSN to joeymdz
I'm sorry i forgot the bit size but you can ream out the upper arm slightly so that the arm can move freely. the pin(s) will be held in once the caps are held down by the screws.
i also sanded down my end caps slightly (use caution or you can sand off too much!)
2 back 1 front white washers is a good starting point. if you want more on power out of the corner try 3 back on the white washers.
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 10-20-2011, 07:26 PM   #2301
Still Bill's Avatar
What Joey says...going with 2/1 is a good starting point for either surface. I transition to 3/0 when the bite comes up on carpet.
It is amazing how much the movement of one thin white spacer changes the caster angle.
Old 10-20-2011, 07:49 PM   #2302
Thanks for confirming to ream the upper A-arms. I went medieval on the caps after Bill's advice. The fit is a little bit better but not floppy loose yet. Now to find a bit that fits...
edit: found a 2mm drill bit and reamed the arms out a little. So nice too see them flop down on their own! This was followed by the discovery of one of the countersink holes not countersunk on the main chassis. Luckily I had a 5mm countersink tool around. Boy these cf plates are hard. The bit died after doing one job!
I'll just be running asphalt so may not need to move all three back. Thanks.
Old 10-22-2011, 08:12 PM   #2303
Jsaves's Avatar
I found on the website GenX 10 le set ups they measure the kingpin. What are the measuring points.
Thanks and God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 10-22-2011, 10:02 PM   #2304
Still Bill's Avatar
From the bottom of the plastic steering block to the bottom of the groove on the pin. I picked the side of the steering block under the axle to be consistent about that location for measuring.
Old 10-27-2011, 05:01 AM   #2305
Default stock steering tie rod size?
Does anyone know the size of the stock steering tie rod turnbuckles (cln 1317) and any recommendations on a good long lasting tie rod tool?
thanks.
Mike
mikev9925 is offline   Reply With Quote
Old 10-27-2011, 06:12 AM   #2306
42mm
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 10-27-2011, 07:34 AM   #2307
al dente's Avatar
misread.
post deleted.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 20-23, 2017
al dente is offline   Reply With Quote
Old 10-27-2011, 07:43 AM   #2308
Default follow up: tie rod middle squared off area size?
dumper, thanks. In my original post I should have done a better job asking: What is the size of the middle tie rod squared off portion? So I can purchase the correct tie rod tool for adjusting the tie rod
Not sure if it is 3mm or 4mm.
thanks again.
Old 10-27-2011, 08:30 AM   #2309
Think a they might be 3.5mm but I will check when I get home.
I have and EDIT tool which has two sizes one on each end, again I will check when I get home
chris_blakey is offline   Reply With Quote
Old 10-27-2011, 08:49 AM   #2310
al dente's Avatar
this is the current "team" wrench of choice.
CRC 1/10 Pan Car-pipe-wrench.jpg
