CRC 1/10 Pan Car
#2281
#2282
After what I saw at the tzgp last year, mixing Joey and apple pie might be the root of the problem.
Hahahahahaha
................zzzzzzzzzzzzzzzzz................. ..
It's a shame I have to miss this year.
Hahahahahaha
#2283
Receiver battery pack (?)
In 1s WGT racing, does a smaller 6.6v 200mah receiver pack provide adequate juice over the total race or do i need something such as a 800mah 7.4 2s pack? I'm thinking about this from a power and weight perspective....
thanks
Mike
thanks
Mike
#2286
my 235mm car seems to have developed a wobble in the rear axle somewhere. how easy is it to bend one of these carbon axles? if it isn't the axle then it may be the hub extenders although i'm not sure they would readily bend either. that said, after two blowovers on the front straight at the local track and the ensuing hard landings i can see that something probably has to give..
#2287
The axle usually just snaps when exposed to a big hit.
#2288
i concur. running the 235 adapters add a lot of weight to the hubs. it seems to make the hubs a bit more susceptible to bending. we ran a lot of 235 when we had the outdoor track running. 2s 10.5, awful fast. when the axle takes damage, it usually sheers off where the locating pin for the diff goes through.
#2289
I'm sure my axle is bent as it displays a visible wobble with the hubs removed. Wouldn't have thought so but there you have it. It appears there are people out there making wide pods for use with longer axles and the standard hubs which would be the way to go I think
#2290
do CRC sell a complete rear axle kit, axle and hubs?
think mine is need of replacement.
#2291
Yes they do. Check amain hobbies or rcmodel
#2292
#2293
must be blind!
I can't see them on any of the website, is there a direct link or a part number anyone can get for me?
Cheers
Cheers
#2294
#1720 Large Ring Diff Set- Red, GX10
I get them directly from John at CRC ([email protected]). List price is $44.99.
Bill
#2295
cheers bill will get one ordered. had a good weekends racing, updated my blog with a race report and some pics:
http://rcgtpancars.blogspot.com/
