Old 09-13-2011, 09:49 AM   #2251
Thats what you get for cutting your tires with a chainsaw!
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 09-13-2011, 10:11 AM   #2252
joeymdz's Avatar
Send a message via MSN to joeymdz
i needed EXTRA traction!!! haha
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 09-25-2011, 01:51 AM   #2253
Trader Rating: 17 (100%+)
i'm looking to find some more high-speed steering through sweepers without making the car too twitchy at low speeds. driving the 235mm version on a medium-traction asphalt surface. am thinking of applying additive to the inner half of the front tyres as a start (not currently applying any to the fronts, which are a jaco purple compound). don't really want to reduce rear wing height as i like the way the rear is locked in. similarly don't like the feel of a harder rear tyre. have also thought to try the 'rear steering' i've read about here. is it achieved by raising the front ballstud on the links? any other ideas would be appreciated thanks!
m@_c is offline   Reply With Quote
Old 09-25-2011, 03:06 PM   #2254
NiMo's Avatar
In my experience the rear steer only worked once the car was loaded in a corner.
I actually ran my 200mm GT version with the rear steer in reverse (raise rear links by 1mm), so i had more turn in but the the rear would then turn in to the corner thus preventing the rear coming round as much under power.
NiMo is offline   Reply With Quote
Old 09-25-2011, 06:01 PM   #2255
DAF Racing's Avatar
Default booster help
Just picked up a ESC booster for my Tekin, just want to make sure that I hook it up right.
I know that you plug it in to the Receiver and then the other side to ESC leads from batt. Do I put a on off switch inbetween?
DAF Racing is offline   Reply With Quote
Old 10-02-2011, 09:46 PM   #2256
BrodieMan's Avatar
Looking for some advice
#1 What body posts should I get that are stronger than the stock ones. Got in a crash this weekend and the flimsy stock posts bent and ended up with a DNF in the final
#2 Looking for a metric steel screw set, or bulk metric hex screws with 4-40 threads.
#3 Need a longer turnbuckle (Spektrum S6070 can't be 100% centred) & better rod-ends.
Thanks Gen X'ers
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 10-02-2011, 11:10 PM   #2257
joeymdz's Avatar
Thanks Gen X'ers
I use xray body posts and longer ball cups
and try fastener-express.com (lots of screws)
Old 10-03-2011, 01:23 AM   #2258
Hi,
have bought CRC Gen-X 10 LE Conversion Kit. It comes without shock. Would like to change shock also. Which CRC Dura-shock or CRC Encore Shock I have to buy?
Do I need anything more for smooth conversion to LE? Thank you!
Audrius
www.rc-cars.lt - offroad in Lithuania
www.lasa.lt - onroad in Lithuania
audriusv is offline   Reply With Quote
Old 10-04-2011, 03:56 AM   #2259
Hi,
I still use the old shock on my conversion and its working great. Loving the car at the min. Updated my blog:
http://rcgtpancars.blogspot.com/
Need to do a piece about the car as I have made a few changes.
chris_blakey is offline   Reply With Quote
Old 10-04-2011, 05:33 AM   #2260
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
I'm still running my original 10 X Pro in 13.5 1S boosted and love it. My driving stinks, but the car is just so much fun to drive. I've put on the Powell shorty front bumper, the side extensions to use the shorter body posts and the Powell Nerf bars (I'm always worried that I'll snap a rear axle with my bad driving.) I have some problems with traction roll due to my horrible driving, but I still think these are the greatest cars out there. I'm seriously considering getting a second one to set up a 235mm 2S 10.5 for some outside summer fun next year.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 10-04-2011, 06:00 AM   #2261
What are these nerf bars that you are on about?
Where do you get them? I would love a bit more protection for the axle!
Old 10-04-2011, 06:33 AM   #2262
Doug Powell Racing made them. I don't think he is in business any longer. John Stranahan referred me to him when I first bought the car. I would imagine the designs are still available, but you'd have to find someone to cut them.
Old 10-04-2011, 06:38 AM   #2263
if you can post some pics of them that would be great.
Old 10-04-2011, 08:30 AM   #2264
joeymdz's Avatar
Originally Posted by audriusv View Post
Hi,
CRC encore shock is the one you need
you may want to go with 12th scale king pins and springs (personal preference)
Old 10-04-2011, 10:02 PM   #2265
Thank you all for answers. Will try old one until new one get here in LT. Would like to order Encore but amain do not have them. Where else I can find CRC parts with nice prices?
Yep, I am using shorter king pins and love this setup. Only I think was using bad ones because one broke...
This season my club will allow setup with 1S and 10.5T motor. That is why I am changing to LE. I think that 1S and LE will help for tires to last longer . Or I am doing wrong assumption?
Audrius
