Old 09-02-2011, 11:46 PM   #2221
Still Bill's Avatar
Originally Posted by BrodieMan View Post
You silly Americans. Someday you'll figure out metric is WAY easier
48P or 64P for carpet setup? That is the question.
Haven't had many issues with 64P in my TC & WGT but lots of people suggested I switch to 48P as it's much more reliable. 64P makes more sense to me for indoor on-road, more efficient. I need new pinions and spurs and can't decide if I should make the switch, such a dilema
With 64P you can make finer adjustments of your gearing/rollout.
48P is more durable for outdoor racing on gritty on-road tracks and all forms of off-road. But, 48P can be also useful to on-road rookies that are not experienced in setting their gear mesh.
I run 64P on my WGT cars for carpet/asphalt. Have not used 48P since my very first RTR touring car.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 09-02-2011, 11:53 PM   #2222
Try emailing John
john@teamcrc.com
He has been quick to respond to my emails in the past.
Yep, tried that too and after about a month still response,
Michael
Understeer Radio Control Car Club
**MRJ Racing 02/2010 - 02/2017**
TeamBear is offline   Reply With Quote
Old 09-03-2011, 12:00 AM   #2223
BrodieMan's Avatar
Bill
That's was what I was thinking. Will stick with 64P.
Thanks Bill
TEAMBEAR
I emailed John a couple days ago about carpet and haven't heard back yet. I would imagine he gets loads of emails everyday and it's hard to keep up.
Try calling them 315 338 0867
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 09-03-2011, 11:43 AM   #2224
fastjoe's Avatar
I am just coming back into the hobby and a CRC 1/10 pan is my first purchase. Be nice to get a short list on what most recommend for powering it.
fastjoe is offline   Reply With Quote
Old 09-03-2011, 06:33 PM   #2225
Still Bill's Avatar
Default Da list...
Good avatar!
Get the "LE" version for 1S racing...The older "Pro" version is 2S oriented and costs more. Both versions can be run on either carpet or asphalt with very minor changes.
1) Start with a Tekin RS ESC...For ramped and unramped.
2) There are a few good 13.5/10.5 motors for different setups out there...a good answer also depends on what you intend to run...ramped or unramped?
3) I definitely like my CRC 5600 1S 65C packs. I keep my pack count down so I can try new packs as they hit the market. Maximum of two packs per car works fine (recharging at track).
4) Instead of a voltage booster, use a 220 mah receiver pack to save .05-.1V on your 1S pack at the end of the run when voltage is most important.
Bill
Old 09-03-2011, 06:37 PM   #2226
fastjoe's Avatar
thanks for the info
Old 09-03-2011, 09:19 PM   #2227
ZZracing's Avatar
Send a message via Skype™ to ZZracing
This car's design is very good, hope to see him in the game very good results!
ZZracing Titanium screws /Hobby Wing /Savox /Nvaracing / Star racing/Novarossi/Sanwa/Castle/Xcore/Yeah Racing/Tianhao UFO/Q-World/Venom/Orion/Sky Rc
Email:zzracing@126.com zzracing@foxmail.com
www.rzhobby.com www.zzracing.net
ZZracing is offline   Reply With Quote
Old 09-04-2011, 10:05 PM   #2228
BrodieMan's Avatar
Since you're a helpful lot here I will pose another question.
Team Orion Avionics LiFe Rx 600mAh 6.6V 30C
Good choice for an Rx pack for my Spektrum S6070 which has a stall current rating of 3A @ 6V?. I would prefer to use Orion cells as I've had nothing but awesome experience with them.
GTB2 with a BEC of 3A @ 6V
BTW I figured out my pod tweak issue, I'm an idiot Motor wires were pushing down on the motor. Was a good excuse to finally do a good electronics install on my Gen X 10 LE.
Thanks in advance for the advice.
Mark Richardson
Old 09-06-2011, 11:48 AM   #2229
well the BRCA nationals are now over and I had a great time. updated my blog with some details and pics:
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 09-08-2011, 08:10 AM   #2230
eevul's Avatar
And 1/12th scale king pins and 50/55 front springs for most carpet conditions.
And I have not taken off the long upper arms since putting them on for the Carpet Nats in March.
It looks like there are two 1/12 scale king pin sets:
1250 - 1/12th Kingpin Set
3250 - CRC 1/12 King pin set polished
Which one do I get?
eevul is offline   Reply With Quote
Old 09-08-2011, 08:25 AM   #2231
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
hey guys
i run my LE out doors on asphalt and i am wearing the pod plate out
mainly the left side, yet the track has mostly left corners.
it squats a lot under acceleration (running 2s,10.5 on boost/turbo)
should i try a heavier spring or could i just limit the down travel ?
its standard at the moment red centre and side springs
ozzy
MST XXXD vip
MST FS-01d
Xray T4
Xray T3
AE Sc10.2 AE SCB
ozzy-crawl is offline   Reply With Quote
Old 09-08-2011, 09:48 AM   #2232
what sort of ride height are you running on the rear?
the pod should stay level as it is a solid axle.
Old 09-08-2011, 10:04 AM   #2233
joeymdz's Avatar
Send a message via MSN to joeymdz
Which one do I get?
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 09-08-2011, 10:11 AM   #2234
joeymdz's Avatar
4mm- 4.5mm all around
Old 09-08-2011, 10:16 AM   #2235
joeymdz's Avatar
Originally Posted by ozzy-crawl View Post
hey guys
ozzy
how much droop are you running? whats your ride height? is the car balanced? anything tweaked?
when i was running in the pro10 class i had the same issue until i found out i had a crack on my rear pod (and some other tweaks here and there )
SEO by vBSEO 3.5.0
