Old 08-26-2011, 12:57 PM   #2206
tim fry's Avatar
Originally Posted by eevul View Post
I recently picked up a Gen X 10 and absolutely love the car. This is my first 10 scale pan car and it handles like a dream. I also have the Gen X 10 LE conversion kit that I recently picked up but I have not converted it yet. From reading these boards, it should be a simple upgrade. Is there anything else that I "need" to purchase before doing the conversion? I would hate to take the working car apart just to find out I need addtional parts before I could get it working again.
Any hints/tips or web links that could help me convert the car would be appreciated.
Get the Encore shock and relevant fittings and thats it.
tim fry is offline   Reply With Quote
Old 08-26-2011, 01:42 PM   #2207
eevul's Avatar
Will the old shock from the Gen X not work? Or is it just that much better?
eevul is offline   Reply With Quote
Old 08-26-2011, 01:53 PM   #2208
tim fry's Avatar
It will work but all the setups are based on that shock so it just makes sense.
Old 08-26-2011, 09:43 PM   #2209
Still Bill's Avatar
And 1/12th scale king pins and 50/55 front springs for most carpet conditions.
And I have not taken off the long upper arms since putting them on for the Carpet Nats in March.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 09-02-2011, 09:41 AM   #2210
BrodieMan's Avatar
When I was adjusting my rear pod, front edge was catching on the carpet, I noticed my pod is heavier on the left side and angles to the left when unweighted. Should I balance it out??
Also
My Spektrum S6070 is too wide to get the servo saver in the centreline of the car so I have the saver turned to the right to get my toe set properly. The stock turnbuckles are too long to have the saver centred. Will the difference in turnbuckle length greatly affect Ackerman?? Should I use a shorter turnbuckle on the left side?
Thanks for the help
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 09-02-2011, 10:00 AM   #2211
joeymdz's Avatar
Send a message via MSN to joeymdz
Also
Thanks for the help
on your pod... re adjust your football (make sure your chassis is flat and no links, bulkhead, or springs are set/attached)
also check your bulkhead.. that might be bent
OR.... your chasis might be tweaked and you may have to loosen up all chassis parts to find the issue
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 09-02-2011, 10:35 AM   #2212
BrodieMan's Avatar
Thank you. Will strip down my chassis and rebuild to get rid of the tweak. Thought the motors weight might not be perfectly balanced.
just remembered the screw holding the top plate to the football standoff backed out last night. That's probably what tweaked it.
Mark Richardson
Old 09-02-2011, 10:44 AM   #2213
joeymdz's Avatar
dont have an answer for the motors weight... but for me 98% of the time its the football (crashes or hits can get them outta-wacked)
also do a quick check on your bulkhead to see if its bent. looking from the back to the front... look under the rear pod and if your bulkhead is bent the motor will dip down below the pod
Old 09-02-2011, 02:02 PM   #2214
BrodieMan's Avatar
Thanks for the help guys. Motor is sitting level so it must be the football. This is one tough car, in five meets I've only broken a side link
Mark Richardson
Old 09-02-2011, 07:17 PM   #2215
Still Bill's Avatar
Good info...Thanks!
Old 09-02-2011, 08:37 PM   #2216
ground-round's Avatar
Trader Rating: 15 (100%+)
Can someone give me a good roll-out to start with for the IIC in Vegas? I'm running 13.5.
ground-round is offline   Reply With Quote
Old 09-02-2011, 08:47 PM   #2217
bkspeedo's Avatar
It obviously depends on your motor and driving style but try something in the range of 3.1" to 3.4". Remember to crank the timing in your motor.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-02-2011, 09:01 PM   #2218
BrodieMan's Avatar
In proper units of length measurement that would be 78.74mm - 86.36mm
Mark Richardson
Old 09-02-2011, 09:30 PM   #2219
bkspeedo's Avatar
My brain has never worked in mm
Brent Klingforth
Old 09-02-2011, 10:14 PM   #2220
BrodieMan's Avatar
You silly Americans. Someday you'll figure out metric is WAY easier
48P or 64P for carpet setup? That is the question.
Haven't had many issues with 64P in my TC & WGT but lots of people suggested I switch to 48P as it's much more reliable. 64P makes more sense to me for indoor on-road, more efficient. I need new pinions and spurs and can't decide if I should make the switch, such a dilema
Mark Richardson
