Old 08-11-2011, 03:34 AM   #2116
BrodieMan's Avatar
I've asked this before, but nobody seems to know. Thought I'd throw it out there once more.
CRC World GT Mercedes body, is it EVER coming out or is this body just a myth perpetuated by RCTECH rumours, never to come to fruition?? Dig the Sophia, and so does Ingo, Len, Bill, Dave............
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 08-11-2011, 07:17 AM   #2117
I would love to come back to the TimeZone GP, but it is not up to me if I can make it or not.
Black Art will be making the Mercedes WGT body, not CRC. We are just the importer. We have a standing order for alot of them. When Black Art decides to release it, then we will have it.
dumper
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 08-11-2011, 07:33 AM   #2118
BrodieMan's Avatar
dumper
Cool, thanks for the heads up Dumper. I have a feeling it's going to be awesome.
Mark Richardson
Old 08-11-2011, 06:10 PM   #2119
dzstr's Avatar
Trader Rating: 20 (100%+)
I asked about the long arm install but figured it out. A few pics are attached. Simply cut the center of the #3277 brace out. These also show #3230 roll center kit installed to raise the hinge pin.
CRC 1/10 Pan Car-dscn1969.jpg   CRC 1/10 Pan Car-dscn1970.jpg   CRC 1/10 Pan Car-dscn1972.jpg
dzstr is offline   Reply With Quote
Old 08-11-2011, 08:14 PM   #2120
Still Bill's Avatar
Fine as you show for asphalt; but, if that is for carpet racing, you may want a cross brace too.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 08-11-2011, 08:18 PM   #2121
dzstr's Avatar
Bill
Which brace? Yes, for carpet.
Old 08-11-2011, 09:15 PM   #2122
BrodieMan's Avatar
Emailed Black Art
Mercedes WGT body is coming out this fall
Mark Richardson
Old 08-11-2011, 10:18 PM   #2123
Still Bill's Avatar
Gonna start by saying that I am currently using the complete Mckune front end kit parts on my LE; so, my front end is about 200mm wide.
As far as I know, the only braces for the wide front end are the Troy Mckune and Manutech units.
I know the Mckune top braces (in two sizes) fit for the widest settings with both standard and long arms; but, not completely sure about the Manutechs (because I have two different units but only see one listed on their website).
You can equal the Mckune's width by using the CRC #1740 Front End Mounting Plates from the original Gen-X 10 kit. Not as nice a solution; but, still quite workable.
FYI...I get Mckune parts directly from Troy's website.
Bill
Old 08-11-2011, 10:51 PM   #2124
Still Bill's Avatar
Default Slapmaster Diff Thrust Bearing for 16-ball spur gear
Not sure how many have tried CRC's new 16-ball spur gears; but, I really like having one on my LE (and XL). The diff action is smoother with the extra 4 balls.
One problem is that the balls are smaller (3/32") which moves the right hub inward a tad and can affect your ability to correctly adjust the diff nut without bottoming out on the axle's threads.
Brian Bodine of Slapmaster to the rescue...
Brian pointed out to me that his #109 Diff Thrust Bearing (originally made for the 12R5) has a wide enough machined spacer to eliminate any chance of bottoming out. And he's right! So, the problem is solved and I love the smooth action of the extra balls in combination with the Slapmaster.
And Brian even calculated that 16 of the 3/32" balls weigh about half that of having 12 of the 1/8" balls; so, less rotating weight...LOL
Thanks Brian.
Bill
Old 08-12-2011, 08:24 AM   #2125
al dente's Avatar
or you can slide a few rear axle shims on between the outer diff bearing and the supplied red spacer. this pushes the spacer out so that there is no way of bottoming out on the threads. this is standard on every diff that i build.
i dont always run thrust bearings in my diff.........but when i do, i run slapmaster.
lol.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 20-23, 2017
al dente is offline   Reply With Quote
Old 08-12-2011, 09:23 AM   #2126
Trader Rating: 17 (100%+)
Default Will Airtonics 94761 servo fit
Is the servo mounting plate slots long enough to mount the smaller Airtonics 94761 without grinding?
billb60 is offline   Reply With Quote
Old 08-12-2011, 10:32 AM   #2127
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
lol.
Mario, I can always count on your support. Just like a jock strap.
Bill; thanks for the report!
Brian
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 08-12-2011, 11:36 AM   #2128
joeymdz's Avatar
Send a message via MSN to joeymdz
HAHAHA
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 08-12-2011, 02:42 PM   #2129
tim fry's Avatar
What are the benefits of the longer arms please?
tim fry is offline   Reply With Quote
Old 08-12-2011, 03:24 PM   #2130
BrodieMan's Avatar
Bill
I have apparently LOL The manual says the diff balls are 1/8" in my LE kit when actually they are 3/32". So now I have a bag of 100 1/8" balls. crap.
My chassis turned out nice, just a few more pieces to finish. PIMP my Gen X
CRC 1/10 Pan Car-genx10le.jpg
Mark Richardson
