Old 08-06-2011, 12:54 AM   #2086
Originally Posted by BrodieMan View Post
Try emailing John
john@teamcrc.com
He has been quick to respond to my emails in the past.
Thanks BrodieMan and stillbill,
I'll shoot him an email,cheers.
Michael
Understeer Radio Control Car Club
**MRJ Racing 02/2010 - 02/2017**
TeamBear is offline   Reply With Quote
Old 08-06-2011, 06:28 AM   #2087
abailey21's Avatar
Trader Rating: 36 (100%+)
Should I spend the money on the aluminum standoffs for the tweak plates or stick with the plastic ones?
Carpet only.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 08-06-2011, 07:39 AM   #2088
Default stand offs
Dont waste your cash, the plastic ones are fine, The alloy ones are more stylish but wont help you to go faster.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 08-06-2011, 07:45 AM   #2089
Default WGT CLASSES in Uk
we have effectively 3 classes in the Uk but by far the most popular is 1s 10.5 boosted.
1s open modified is a none starter and 2s 17.5 is a very minority class. The 2s 17.5 is a tadge faster than 1s 10.5.
WGT is becoming very popular in the Uk, control tyre and 1s 10.5 becoming the biggest class.All classes are boosted.
Old 08-06-2011, 08:24 AM   #2090
Still Bill's Avatar
Carpet only.
I take my tweak plates off fairly often; and, did finally strip one of the plastic standoffs. So, I do use the aluminum versions in both 1/2" and 5/8" high.
No noticeable tuning difference between the two standoff sizes. 1/2" ones are lighter. Car is still about 930 grams for the IIC...
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 08-06-2011, 08:59 AM   #2091
abailey21's Avatar
Bill
Here's one more for you Bill. Both of my cars (bought used) only have one washer between the front end plate and chassis. The manual calls for two. and I don't see anything on any setup sheets that i can find whether I should run one, or two?
K.C.C.O.
Old 08-06-2011, 09:49 AM   #2092
Buckaroo's Avatar
Run what works. If you really want to know, put a second washer in there and run, compare times, decide from there.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 08-06-2011, 05:58 PM   #2093
dzstr's Avatar
Trader Rating: 20 (100%+)
Are the 1/12th king pins and springs the only parts being swapped out on the LE front end? Keeping the same spring cup?
The manual recommends the mid-size servo saver. Is this what everyone is using instead of the small size?
Thanks!
dzstr is offline   Reply With Quote
Old 08-06-2011, 10:54 PM   #2094
Still Bill's Avatar
The 1-2 #4 washers are for those that run larger front tires. I don't; so, no washers at all for me. If you run big tires, you have those washers as an ride height adjustment.
With no washers, I do always have the 5mm Ride Height Spacers under the lower arms.
Pretty much run between 4-4.5mm ride height for the carpet and asphalt tracks I run at. Nor-Cal Hobbies is as smooth an asphalt track as you will ever find.
Bill
Old 08-06-2011, 10:59 PM   #2095
Still Bill's Avatar
Thanks!
No spring cup needed for the 1/12th scale springs. The regular e-clip that is used to hold the spring cup on the 1/10th scale king pin retains the smaller 1/12th scale spring on the 1/12th scale king pin.
Bill
Old 08-07-2011, 07:59 AM   #2096
dzstr's Avatar
Bill
Thanks Bill. Glad I asked. I left the cups in.
I found a link on here somewhere to show how to measure the king pin length but can't find it now. Anyone have this?
Old 08-07-2011, 08:48 AM   #2097
Still Bill's Avatar
Insert the Dual Steering Axle (I always use the trailing axle position for 1S) into the Steering Block. Screw the king pin into the unit until the there is about 1 thread still showing.
Using calipers, measure .404" (for 1/12 scales king pin) from the bottom of the Steering Block to the bottom of the e-clip groove in the King Pin. Because the bottom of the Steering Block is not even, do this measurement at the same location for both assemblies to be consistent from side to side. I do it on the side of the Steering Block under the axle.
For the 1/10th scale king pins that I use on asphalt, the length measurement was something like .576-.580" to the bottom side of the e-clip. Just be consistent side-to-side in what measurement you use.
Bill
Old 08-08-2011, 03:51 AM   #2098
Default long arms shorts arms
I run 2 wgts the new LE and the old version with the Mckune conversion. set up on the mckune is long chassis wide front end and top brace. Im using the short arm and 10 degree caster blocks ,2 washers to rear and 1 in front .Camber is 0.5 mm.
The car goes good and is a very safe drive but just lacks that extra 5% to make it very competitve.
I go in to corners aggressive and tight but coming out car tends to push and understeer.
Looking for a solution, will long arm cure this or should i be looking some where else.
Also running in line axle blocks.
Old 08-08-2011, 07:59 AM   #2099
NiMo's Avatar
Running the 10 castor blocks will give you more power on understeer.
Try running with the 5 blocks. Bit less turn in but more coming out.
Also try some toe out on the front to get some steering back.
NiMo is offline   Reply With Quote
Old 08-08-2011, 05:44 PM   #2100
BrodieMan's Avatar
I will be switching my Gen-X 10 LE from 2 cell SCAR 25.5T spec to 1 cell World GT 17.5T spec soon. Just wondering what the best placement is for 1 cell on a high bite, tight carpet track. Also what tire diameter will give approx. 5mm ride height with #3 ride height inserts??? Trying to get the most life out my tires as possible. Thanks guys
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
