Old 06-03-2011, 05:27 AM   #1996
gonzo416's Avatar
Trader Rating: 39 (98%+)
Anyone looking for one (CRC GEN X-10 WGT ROLLER-MCKUNE CHASSIS & MANY SPARE PARTS) ,
check here: http://www.rctech.net/forum/r-c-item...are-parts.html
best offer
gonzo416 is offline   Reply With Quote
Old 06-05-2011, 06:02 AM   #1997
Originally Posted by Still Bill View Post
Carpet or asphalt?
Where can i found any setup for asphalt GenX10?
I only found one post of John Stranahan
thanks
TyoBBS is offline   Reply With Quote
Old 06-05-2011, 01:56 PM   #1998
Have a look back a bit further, i've been tracking my changes on asphalt for about 6 months now. Must say, i'm still not having great luck!
What sort of track, and what battery/motor type are you running?
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 06-05-2011, 05:22 PM   #1999
Still Bill's Avatar
thanks
I posted mine from the Asphalt Carpet Nat sometime in April. Just look back into my post history for it.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 06-06-2011, 01:17 AM   #2000
I found your pdf and some setup of JR007 thanks.
Our track AMSA in Barcelona (Spain) 45m straight (2S with 7,5motor):
http://www.google.es/imgres?imgurl=h...w=1024&bih=605
Why we don't have our forum in rctech to be more clear all information with best post with sticky?
regards
Old 06-06-2011, 03:22 AM   #2001
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
you will find most of the U.S guys setups are for 1s i believe.
seems they favour small indoor tracks (possibly weather related) and work well with 1s
ozzy-crawl is offline   Reply With Quote
Old 06-06-2011, 06:59 AM   #2002
Still Bill's Avatar
regards
Nice track!
My original setup used a 13.5 motor and 2S battery...quite fun. But, making the car light with a 1S battery really brought out the handling characteristics of the car. So, most here in the US went with the WGT configuration of 13.5 with 1S.
The few guys that stayed with 2S configurations usually added the 235mm upgrade and went with the big prototype bodies; but, that has completely died out here.
Bill
Old 06-06-2011, 07:56 AM   #2003
ozzy-crawl's Avatar
i would like to try 1s at some stage,i have a few 1s packs.
just my track is large with a couple big straights and dont know if i would get the punch and speed with 1s
hell if there was any pan car racing at my track i would run 1s,2s,nimh, alkaline batteries,anything as long as there was some racing
Old 06-06-2011, 11:32 AM   #2004
Has anyone tried the car with 1S and a 4.5 (or so) motor? Just curious, as 1/12 specs down here is mod, and many run with 5.5 motors. Not sure if I would overheat the electrics trying that with a heavier car or not.
No real reason to try it, just for sh*ts and giggles.
Old 06-06-2011, 11:42 AM   #2005
NiMo's Avatar
Ran 1s McKune X10 with 8t Delta, so much grip on our track that we could pull wheelies, was very hard to do proper laps though as was too easy to pop a wheelie.
(GRP Magentas - GM120)
NiMo is offline   Reply With Quote
Old 06-06-2011, 03:42 PM   #2006
ozzy-crawl's Avatar
thats the thing that stops me trying,lots of amps trying to get the same performance out of half the voltage
Old 06-06-2011, 10:14 PM   #2007
I know people with 1S (6000) and 3,5 motor, enough for 8 minutes.
regards,
Old 06-06-2011, 11:08 PM   #2008
Still Bill's Avatar
Question for Brian Wynn or Brian Bodine,
At the 2011 Carpet Nats at TimeZone II, your WGT cars both had extra washers on top of your four 1/2" tall standoff posts to raise the rear body mounts and provide more vertical adjustability of the rear side springs.
What did that do for your cars?
Did you ever switch over to the optional 5/8" tall aluminum standoff posts #1293 in lieu of the washers?
Thought this change might be something to put out there as a tuning option.
Bill
Old 06-07-2011, 05:57 AM   #2009
Bill,
I was mainly trying to see the difference of moving the side springs to on top of the link. I did not have longer standoffs with me so I cobbled something together to try it. My testing was inconclusive as I had electrical issues the whole time I was there.
dumper
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 06-07-2011, 06:00 AM   #2010
NiMo's Avatar
.... and lots more internal heat caused by the extra amp draw
(2s 10.5 on test rig draws 40A, 1s on same test rig draws 80A)
I gave up 1s 10.5 racing as I was often melting the solder inside the motor and on the ESC motor wires. When I return to pan car it will be the now legal BRCA GT3 class (2s 17.5) and use those Xcelorin 60c 3800 96mm LiPo's, which fit in to a 1s chassis (they are 1s length and 2s height).
