Old 05-09-2011, 03:45 PM   #1921
wingman2's Avatar
Hi mate, I measured my car from yesterday's meeting at Ardent, and it was actually running at 196mm (with Jaco rims). I must of set the rear width with Corally rims (or something similar) when I built it, so the offset is obviously differant with the Jaco's. Have n't tried the car with CRC rims yet though. Cheers, Chris.
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 05-09-2011, 03:48 PM   #1922
one thing to note is that the crc/bsr rims are 2mm wider per tyre than the jacos.
also updated my blog with a small part about yesterdays race
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 05-09-2011, 07:57 PM   #1923
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Nice Blog
But just to be clear, the width of the Jaco and CRC/BSR tires are the same, it is the offset on the wheel that is different, no ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-09-2011, 08:32 PM   #1924
Still Bill's Avatar
Originally Posted by ozzy-crawl View Post
Come on down under bill, I will throw another shrimp on the barby mate.
Things are a lot more expensive here, but a lot is not the shops fault but importers and then the cost of rent for a hobby shop, even a small one is around 5-6 grand a month. That's a lot of Rc gear just for rent.
Strange thing is prices are the same when the Aus $ was worth 52c u.s now it's worth double that but Rc gear is still the same price.
And fuel has gone up $1.50 plus a liter, close to $6 a gallon.
Still aus is a top place to live.
Enough of my dribble, looking at a new body for the Le, what's the Sophia GT like ??
Sounds like I will be staying in one star hotels.
I definitely prefer the ProtoForm Sophia over the Parma Aston Martin. Still awaiting CRC to produce a WGT body (Mercedes?).
Cheers!
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 05-09-2011, 08:35 PM   #1925
Still Bill's Avatar
CRC/BSR rims are also 1mm taller than Jacos. Have not seen any Jacos WGT wheels/tires produced recently; whereas, CRC/BSR mounted tires are easily available.
Bill
Old 05-09-2011, 09:02 PM   #1926
Still Bill's Avatar
Originally Posted by RedBullFiXX View Post
Nice Blog
Measured my CRC/BSR and Jaco WGT rims...again.
CRC/BSR front rims are 29mm wide by 49mm diameter.
Jaco front rims are 29mm wide by 48mm diameter.
CRC/BSR rear rims are 52mm wide by 49mm diameter.
Jaco rear rims are 50mm wide by 48mm diameter.
Offsets from the inner side of the rim to the flat surface of the inner bearing holder seem to be about the same at 12mmą for the fronts and 14mmą for the rears. With no other changes, a CRC/BSR setup will always be 4mm wider in the rear than a Jaco setup. Front should be similar.
Bill
Old 05-09-2011, 09:13 PM   #1927
Bill
Thanks Bill.
Like you say, can't find Jaco WGT wheels anywhere, so wasn't sure of the specs.
Old 05-09-2011, 10:48 PM   #1928
Still Bill's Avatar
Thanks Bill.
Only good Jaco WGTs were the original front/rears with the carbon fiber pattern on the rims. They were killer because you could true the tires down a mm further than the CRC/BSR sets.
Jaco's newer fronts (last year's spec tire for the Asphalt Nats) with the wide bands of yellow foam on the inside were pathetic; but, the matching rears were fine. Jaco just made the way soft yellow bands too wide which took away a good deal of steering.
CRC/BSR mounted spec foams are the best available for true WGT racing.
Old 05-10-2011, 12:33 AM   #1929
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
I first ran the BSR tyres purple front/rear, when I went to get some more wanted a softer rear but could not find any in stock. Brought a set off xcede
Purple front/ magenta rears
Rear track width on stock LE setup 196mm
The bsr from memory were 200mm
ozzy-crawl is offline   Reply With Quote
Old 05-10-2011, 07:22 AM   #1930
ozzy-crawl's Avatar
Cheers!
Bill
thanks bill,found one in Aus for $45 + freight
Old 05-10-2011, 12:22 PM   #1931
hi,
just to get some idea of sizes for the rear hubs can people measure theirs and post up the results? Need to measure like below:
Mine came in at 19.1mm. Would be interesting to find out what LE owners measure at.
Cheers
Old 05-10-2011, 12:32 PM   #1932
NiMo's Avatar
19.1 and 22.9 are all mine
NiMo is offline   Reply With Quote
Old 05-10-2011, 11:36 PM   #1933
Still Bill's Avatar
I agree with 19.1 and 22.9.
Have had both versions of the Gen-X 10 and do not remember a dimensional difference in their axles or left/right hubs since my first car.
What are you looking for in this comparison? If you want something slightly different, try contacting Dave Irrgang at IRS Racing.
Bill
Old 05-11-2011, 12:31 AM   #1934
At the race on sunday we came across two recently delivered GENX10 LEs that when we did the same measurement on their hub it came in at roughly 17.6mm.
Old 05-11-2011, 07:59 PM   #1935
Still Bill's Avatar
Sounds like that is measured to the back side of one side that was checked. You only mention one hub. What about the other hub on the other side?
What was the overall width of the rear of the car and what rear tires did it have on it?
Bill
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
astgerma52sp, dawgmeat
