Old 05-06-2011, 01:31 PM   #1891
I finally built my Gen X 10 last weekend and just need to pick up a servo to complete it. What's a good low profile servo for this car ? I have to say the car is without doubt the nicest quality kit I've ever built in terms of materials, fit, and finish.
Steve. is offline   Reply With Quote
Old 05-06-2011, 06:30 PM   #1892
Still Bill's Avatar
Originally Posted by littlealex View Post
cool, i could make some LE videos next sunday
Videos are good...
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 05-06-2011, 10:13 PM   #1893
Suspended
Trader Rating: 86 (100%+)
video is good as long as the car runs good
littlealex is offline   Reply With Quote
Old 05-06-2011, 10:28 PM   #1894
Suspended
i m using ko pds 951
Old 05-06-2011, 11:12 PM   #1895
Still Bill's Avatar
I also use the KO 951 KDS servo in my LE and XL; but, the JR3650 is excellent and usually costs $15-20 less.
I went with the KO servo because I use their Eurus radio too. There are a few minor options available by having them fully compatible.
Old 05-06-2011, 11:18 PM   #1896
Suspended
bill, whats advantage of use both ko radio and servo? i m using ko radio too
Old 05-07-2011, 01:36 AM   #1897
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
were i live KO and JR servos are hard to come by so picked up a savox 1250mg.
Dimensions(mm): 35.0X15.0X29.2
Weight(g): 29.6
Speed(@4.8V sec/60): .16
Torque(@4.8V oz-in): 30.6
Speed(@6.0V sec/60): .11
Torque(@6.0V oz-in): 63.9
Gear: Metal
Bearing: 2BB
Case: Aluminum
25 Tooth Spline
not as fast as some but plenty fast enough for large out door track (and old reflexes)
good servo comparison chart
http://www.servodatabase.com/compare...=589,1208,1561
ozzy-crawl is offline   Reply With Quote
Old 05-07-2011, 08:02 AM   #1898
Still Bill's Avatar
With the Helios/Eurus radios and the programming module you can program some characteristics into the KO PDS servos.
bill
Old 05-07-2011, 05:07 PM   #1899
Suspended
just want to order 3340 motor mount but its out of stock, will CRC4247 fit?
Old 05-07-2011, 08:48 PM   #1900
Thanks guys, I should have mentioned I needed digital servo. That said I ordered a Hitec HS 7775MG, it's a lot more shallow than a standard servo so it will clear the battery tray and battery no problem. More than enough power for 1/10 and plenty fast too.
Old 05-07-2011, 09:56 PM   #1901
Still Bill's Avatar
No, the 4247 does not have the attachment points for the rear cross brace.
Old 05-07-2011, 10:02 PM   #1902
Still Bill's Avatar
One of the issues with servos is getting one that has its output shaft in the correct position so you can center it in the Gen-X 10 chassis.
I do not believe the Hitecd 7775MG Low Profile servo does this using the supplied CRC parts. Have seen a couple people glue low profile servos flat to the Gen-X 10 chassis to make them work.
Bill
Old 05-08-2011, 01:51 AM   #1903
ozzy-crawl's Avatar
Bill
yea standard servo is to wide,tried that on mine but would not fit.
only mini i could find locally was the savox 1250mg (digital),i have 3 other savox servos and had a good run with them and happy with the 1250s performance
unfortunately KO and jr are hard to come by here and real expensive
Old 05-08-2011, 07:39 AM   #1904
Still Bill's Avatar
Default Servo comparisons
From A-Main Hobbies website...They carry all four micro servos...
KO-Propo PDS-951 ICS Digital Micro Servo
Torque: 108.3 oz at 6V (most by far)
Speed: 0.09 sec @ 60 degrees
Bearing: Dual (best)
Gears: Metal
Weight: 27 grams (lightest)
Size: 1.42 x 1.21 x 0.59 inches
Cost: $118.99 (highest)
JR Z3650 Digital High Speed Micro Servo
Torque: 51 oz at 6V (least)
Bearing: Single
Gears: Metal
Weight: 29 grams (heavier)
Size: 1.30 x 1.02 x 0.58 inches (smallest)
Cost: $89.99 (middle)
Savox SH-1250MG Super Torque Digital Micro Servo
Torque: 63 oz at 6V
Speed: 0.11 sec @ 60 degrees (slowest)
Bearing: Two ball bearings
Gears: Metal
Weight: 29.6 grams (heavier)
Size: 1.38 x 1.15 x 0.59 inches
Cost: $62.99 (lowest)
Savox SH-1257MG Super Speed Digital Micro Servo
Torque: 34.7 oz at 6V (insufficient)
Speed: 0.07 sec @ 60 degrees (fastest; but, has insufficient torque)
Gears: Metal
Weight: 29.5 grams (heavier)
To my thinking, the KO has the best overall specs; but, it comes at a price. JR 3650 sits in the middle. Savox's 1250MG is the bargain entry to the fray. And Savox's 1257MG is possibly suitable for 1/12th scale.
Bill
Old 05-08-2011, 07:51 AM   #1905
Still Bill's Avatar
Default Servo Saver
Oh, one other issue...I always use a Kimbrough Mid-sized Servo Saver #200 on my WGT cars. Has a stronger spring than their 1/12th servo savers.
And I utilize the two holes closest to the servo's output shaft for more steering accuracy. I cut off the unused holes for more clearance and better appearance.
Interesting that Kimbrough does not make a 21 spline servo saver in its mid-sized units. So, the only servo saver that works with Savox servos is the small Kimbrough unit.
Bill
