Old 05-03-2011, 10:15 AM   #1876
CypressMidWest's Avatar
Originally Posted by nitrobeast View Post
Which traction compound do you guys feel works best on asphalt?
I've always been partial to Trinity Red Dot, with an aftercoat of SPF 50 sunscreen.
Team CRC, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 05-03-2011, 07:55 PM   #1877
Still Bill's Avatar
When I originally setup my CRC Gen-X 10 Pro (not LE), I still ran red springs front and rear; so, that may still be a starting point for a parking lot track.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 05-04-2011, 03:06 AM   #1878
Suspended
Trader Rating: 86 (100%+)
finally my 1" aluminum standoffs arrived so i can use 2 cell battery in my LE
does anyone know which axle will fit gen x LE?
i found CLN4228 and CLN1728.
cool bill, i have confidence of your setup!
littlealex is offline   Reply With Quote
Old 05-04-2011, 06:53 AM   #1879
johnnywhopper's Avatar
4228 is the 12th scale axle.
1728 is the 10th scale axle.
this info can also be found in the manuals which are free .pdf downloads on the "tech" page of www.teamcrc.com
john
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 05-04-2011, 07:35 PM   #1880
Still Bill's Avatar
Default Complete Rear Axle Assembly for Gen-X 10 Pro/LE
Although not showing on the CRC website, Part No. 1720 is the whole rear axle/diff assembly for the Gen-X 10 all the way down to the screws for the rear wheels. For about $20 more than the axle alone you can have the whole enchilada and/or have a spare unit (possibly with a different spur gear for more variation with rollouts). I order them special from my hero John Firsching (johnnywhopper) at CRC. john@teamcrc.com
And Nor-Cal Hobbies in Union City, CA now tries to keep them in stock.
Bill
Old 05-04-2011, 10:40 PM   #1881
Suspended
thanks for the tip bill, do i have to contact johnnywhopper for this? is gen x 10 and le share same rear end?
Old 05-04-2011, 11:35 PM   #1882
Still Bill's Avatar
Yes about the complete assembly. Because it is not listed, contact john@teamcrc.com or call him in Rome, NY.
Rear end is the same for both models of the Gen-X 10. Except the LE has the micro left side pod plate. I prefer a full (#3340) and/or partial (discontinued part) pod plate on the left side over the micro version.
Bill
Old 05-05-2011, 12:23 AM   #1883
I have also replaced the left hand mount with a motor mount.
adds loads of strength to the rear end without much weight.
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 05-05-2011, 06:37 PM   #1884
Suspended
bill, how come you dont use 3340 on motor side since it will lower motor height
Old 05-05-2011, 07:13 PM   #1885
Still Bill's Avatar
I do have a #3340 motor plate on the motor mount side (right). I have a now discontinued CRC part on the left side (trimmed down version) with the new #1763 Full Box Rear Top Plate.
If I was hitting things alot (I try not to...LOL), I would definitely go with two #3340 motor plates on the rear pod with the new full box plate. This heavy-duty rear pod probably makes sense for mod setups too.
Old 05-05-2011, 08:09 PM   #1886
Suspended
my plan is use kit one on left side and use 3340 on right side
Old 05-05-2011, 09:34 PM   #1887
Still Bill's Avatar
Alex,
The kit one is a 3340; so, you will be doing as I described above...Using two of them.
And adding the new 1763 Full Box Top Plate will tie them all together.
Bill
Old 05-06-2011, 02:49 AM   #1888
Suspended
ok, i see what you mean now, 2 x 3340 with full box to make the rear pod more stronger.
btw is 1763 hard enough for crashes?
Old 05-06-2011, 07:58 AM   #1889
Still Bill's Avatar
With the 1763 attaching to both sides, I believe it is plenty strong. But, as Dumper will always say...don't hit s#&t anyway..LOL
Bill
Old 05-06-2011, 11:38 AM   #1890
Suspended
cool, i could make some LE videos next sunday
SEO by vBSEO 3.5.0
