Old 04-14-2011, 08:54 PM   #1816
Still Bill's Avatar
Originally Posted by ozzy-crawl View Post
about the best i could do for a track pic.
bottom of pic shows two cut outs,this is used usually by the electric guys
as it cuts both ends of the long straight of,plus both ends
Yep...I see why you use the inner holes.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 04-15-2011, 12:43 PM   #1817
Suspended
Trader Rating: 86 (100%+)
can someone explain what parts i will need to shim the top plate so it will fit 2 cell batteries?
or is there any optional post for 2 cell?
littlealex is offline   Reply With Quote
Old 04-15-2011, 02:53 PM   #1818
YoDog's Avatar
Trader Rating: 26 (100%+)
I take it that you have the LE version?
The standard GenX10 is designed to accommodate 2 cell packs via a tray system. You could round up some 2 or 3mm spacers and add them to the upper plate posts but that will also change the shock position.
If you have your heart set on running 2 cell, it might be best to change to the older chassis plate. Many of us have them as many have converted to the 1 cell LE chassis.
I have an extra if you are interested.
PM me if this is the route you want to take.
YoDog is offline   Reply With Quote
Old 04-15-2011, 03:11 PM   #1819
Suspended
i m looking for longer posts that will fit 2s under top plate and also longer thread of rear stud so i can shim it
Old 04-15-2011, 03:38 PM   #1820
As mentioned, washers are the way to go. I use the original chassis, but still put 1.5mm washers under to fit the battery, but keep it snug.
As far as I know, there aren't any posts around that are "just right", i've spent a fair bit of time looking too
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 04-15-2011, 03:57 PM   #1821
YoDog's Avatar
The posts are a standard 3/16 inch hex standoff with a 4-40 thread. There are longer length ones available but may be a little too long so they would need to be machined down to the desired length.
If you tell me exactly how long you want them, I can make them for you for a small fee. PM me if you are interested.
Here is a link to a 0.875 length standoff which is 0.125 longer than stock. It just needs to be re-threaded to a 4-40 thread.
http://www.mcmaster.com/#spacers-and-standoffs/=bw4klv
Old 04-15-2011, 04:06 PM   #1822
YoDog's Avatar
As far as the rear ball stud is concerned, you could change to a female threaded version (like the forward ball stud) so the thread length will no longer be a concern.
Old 04-15-2011, 04:56 PM   #1823
Suspended
i will get some 4-40 3/8 bolts, thanks 007 and yodog
Old 04-16-2011, 12:41 AM   #1824
westy1969's Avatar
Im using these post form xray.
CRC Gen-X 10 200mm indoor-setup | CRC PX10W full 235mm
westy1969 is offline   Reply With Quote
Old 04-16-2011, 01:04 AM   #1825
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
they look very sweet west1969.
whats the length ?
at the moment i have a alloy washer and alloy lock nut then the spacer on mine as i need 25mm height .
im not sure by raising the front end of the shock up 6mm how it affects the handling. but if the standard gen x has a 3/4" spacer on top of carbon fibre spacers allowing a 2s pack to fit i would think the height on the front shock must be nearly the same as a spaced up le
ozzy-crawl is offline   Reply With Quote
Old 04-16-2011, 02:58 AM   #1826
trerc's Avatar
Trader Rating: 89 (100%+)
Lefthander RC carries a variety of chassis stand offs in varying sizes from Hyperdrive too
http://www.lefthander-rc.com/catalog/index.php?cPath=36
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 04-16-2011, 09:52 AM   #1827
Still Bill's Avatar
The original CRC Gen-X 10 Pro 3/4" high standoffs that accommodated a 2S pack are:
Part No. 1737 (Hex Standoff - GX10 Top Deck).
Old 04-16-2011, 12:24 PM   #1828
westy1969's Avatar
They are 25,21mm so al s2 pack should fit.
But check to buy the right one, because te T2 post are smaller.
whats the length ?
Old 04-16-2011, 01:29 PM   #1829
YoDog's Avatar
Hey Bill,
the 3/4" posts are not quite tall enough for a 25mm high pack. Since the original chassis use a tray system, the battery sat a bout 1.5mm lower in the chassis rather than on top of the carbon as with the LE chassis.
Troy's chassis has stiffener spacers which raise the post height by about 3mm. This I noticed on my car. I managed to put the LE car together now so now I can compare the 2 chassis. Wish I could come up and run tomorrow.
Old 04-16-2011, 08:59 PM   #1830
Still Bill's Avatar
Originally Posted by YoDog View Post
Hey Bill,
Wow! I forgot that there was a piece of graphite and a flat nut under the posts. Just checked that out in the manuals section at www.TeamCRC.com. Sorry!
