Like Tree2Likes
Old 03-01-2011, 03:15 PM   #1606
Trader Rating: 19 (100%+)
Originally Posted by Atcom View Post
This may sound stupid: I also realised that there isnt enough place for average 2s lipo packs; So what if i opened the casing of a hard case lipo and put in the car like that?
are you using standard size servo or a mini, its works fine with a mini size servo, but not with a standard size. Hope this helps!
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 03-01-2011, 03:57 PM   #1607
If you run a low profile such as the Savox SC1251, you can run a non-mini servo, with a 2s pack.
http://www.savoxusa.com/product_p/savsc1251mg.htm
Shawn
Shawn68z is offline   Reply With Quote
Old 03-02-2011, 08:44 AM   #1608
Atcom's Avatar
Im using a futaba S9650 which is a mini. but thats not the problem, the problem is that the battery does not fit in the plastic battery holder by width, so if i place the battery inside while the car is upside down it sticks out by 3mm on the bottom of the chassis... Its a hardcase with dimensions: 137x47x24mm. Would it be a big mistake to take out the packs from the hard casing? Thanks for the help!
Atcom is offline   Reply With Quote
Old 03-02-2011, 09:15 AM   #1609
I would leave the pack in the hard case. I think i understand the issue you are having, but a photo would be worth a thousand words.
You might be hooped on this one, and a different battery may be needed.
Shawn.
Old 03-02-2011, 10:08 AM   #1610
Atcom's Avatar
Shawn.
On the first picture you can see that its to thick, on the second picture you can see that its to wide which adds to the height due to the side wall of the battery tray.
I'm sure that i won't be able to use this lipo with hard case on it. Any suggestions on what hard case lipo to buy? Thanks!
CRC 1/10 Pan Car-imag2107.jpg   CRC 1/10 Pan Car-imag2110.jpg
Old 03-02-2011, 10:24 AM   #1611
Buckaroo's Avatar
Default What parts to buy?
Hey there, I just picked up one of these used, looks to be in great condition. It'll be here in about a week, but I'm wondering what breaks most often and what spares should I keep on hand?
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 03-02-2011, 11:46 AM   #1612
My lipo didn't fit, but it was close. I got a dremel and ground some of the side wall of the holder out, and also put some waashers under the upper-deck posts to raise the height. Fit's perfect now, and doesn't slop around
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 03-02-2011, 12:06 PM   #1613
Thats definately a big battery! These cars were designed around the TrakPower battery, which has dimensions of 137x46x23mm.
What about having the battery sit above the tray? Use some spacers to raise the top deck until it fits.
Old 03-03-2011, 07:18 AM   #1614
Atcom's Avatar
Thanks for th advice, i think i will buy one that fits without lots of spacers... Which Trackpower is it?
Old 03-03-2011, 09:47 AM   #1615
I wouldnt buy the TrakPower these days. I dont even know if you can buy them anymore. Most Reedy 2S, Fantom, ThunderPower, or SMC would should fit. Just check the measurements.
Shawn.
Old 03-03-2011, 09:49 AM   #1616
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
So can a 2s lipo fit ? I want to run on an outdoor track which is kind of big.
XRAY T4 17' //CRC Gen X SE- 17.5 GT//Xray X12-17' GT12//Xray X12-18' 17.5
check out the new 12th scale GT class!
https://www.facebook.com/groups/148391312353349/
JEFFs SC10 is offline   Reply With Quote
Old 03-03-2011, 10:04 AM   #1617
Yes. A 2S will fit as long as you use a mini servo, or a low profile servo using straight up down servo mounts (T2 style, or AE)
Our club used to run 2S, 10.5 with these cars, and they are a blast to drive with 2S.
Just make sure the 2S is 137x46x23mm or smaller.
Shawn
Old 03-03-2011, 10:33 AM   #1618
JEFFs SC10's Avatar
awesome! Yea I just pulled out my car and checked fitment and it will definitely work. Mine has a 13.5 in it for now. i can't wait to run this sucka!
here's a pic of my heap.
CRC 1/10 Pan Car-my-crc-pan-car.jpg
Old 03-03-2011, 10:33 AM   #1619
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
no one runs 2s,it is more of a pain to switch after a race unless your doing it for fun.you have to remember they don't use the hole back stretch for elec
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-03-2011, 10:35 AM   #1620
JEFFs SC10's Avatar
I'll have to get with you sometime soon to talk about my car. Are you going to Kissimmee this weekend?
