Old 02-23-2011, 05:18 PM   #1591
Still Bill's Avatar
Originally Posted by bkspeedo View Post
you have to run the front arm assembly mounts like on the old car to get this width.
The LE front cross-brace was design to equal the medium track width setting of the GenX-10.
I just ordered these from the old car to test the 200mm front end width. Forgot to ask Brian when I was talking to him this week.
#1740 - Graphite Front End Mounting Plates - GX10/BA @ $14.99/set
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-23-2011, 08:26 PM   #1592
inconceivable's Avatar
Bill
Thanks ! I too will order this to test. Also cool to find out I'm not crazy
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 02-23-2011, 08:44 PM   #1593
Still Bill's Avatar
At least you won't be crazy alone...
Old 02-27-2011, 07:13 PM   #1594
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
hi
i finally ordered a gen 10x le after wanting a 1/10 pan car for some time.
have a couple questions.
i will be running a large 1/8 asphalt track so will be running 2s with either a 9t or 13.5t
# 1. looking at the online manual (haven't received car yet) it says the posts between chassis and top deck are 3/4" (19mm) my batteries are 22mm thick
if i raise the posts 3mm this will also change the shock mount height
what will this affect as far as handling ???
# 2. after ordering i found that this car even tho 1/10 may not take a standard 1/10 size servo,i know guys run 1s and look at reducing weight but i find it strange being 1/10 it wont take a standard servo.
has anyone gotten a standard servo to fit ???
other wise it looks like another long wait (limited income) to save for a 1/12 servo,living out side the u.s means ordering over seas (add $30 postage) or pay 2-3 times the price here if i can find one at lhs
any help would be much appreciated
scott
ozzy-crawl is offline   Reply With Quote
Old 02-27-2011, 07:30 PM   #1595
Trader Rating: 19 (100%+)
Originally Posted by ozzy-crawl View Post
hi
scott
Scott,
As far as handling goes, if you use the right kind of shim such as a 3mm tamiya shim then it will look better, but handling will not change, my lhs had a specific mod world-gt class for a while and i ran a trinity ib 5000 in the centerline and had to raise the top deck, still ran fine. I have not done it myself but a guy at my lhs just picked up a gen-x le a couple weeks ago and put a futaba 9551 servo in it, its low profile from top to bottom but width wise is standard, if you move the battery as far back as you can it may fit a standard, non low profile, servo in it, i run a futaba 9650 mini servo in mine and it works great, in the pancar classes a bigger stronger servo is not needed as much as like in touring car. Hope this helps.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 02-27-2011, 07:40 PM   #1596
ozzy-crawl's Avatar
Originally Posted by COLD AS ICE View Post
Scott,
cold as ice thanks very much for that information
i have found a hitec mini servo locally
its 4.8kg at 6 volts and metal geared,but analog 0.11 sec @ 60 deg
would this be good enough, i wont be racing (only friends TC cars)
and the track is a very large open track (they even run 1/5th)
Old 02-27-2011, 07:46 PM   #1597
sounds like it would work to me, i run an analog in my second gen-x le that i use only for outdoor racing, i like to have the extra steering speed when we run 2 cell with 7.5t motors on a 105ft long track, it comes in handy
★Randy Banks★
Old 02-27-2011, 07:50 PM   #1598
ozzy-crawl's Avatar
thats great news thanks.
how do they hold up out doors with the 7.5t
i will probably running a 9t 4000kv motor
Old 02-27-2011, 08:09 PM   #1599
it seems to hold up good, the first couple runs in mod wgt werent the greatest. but i found when running pretty much any motor more powerful then a 10.5 w/ boost, the screws in the rear pod must be loc tighted or they will get loose and when ever you power out of a turn it will rattle and sound absolutely horrible. and as far as durability for mod motors outdoors, i would recommend putting an original style associated front end on the car, the crc front is great but with faster motors and 2 cell packs it cant hold up in a crash.
★Randy Banks★
Old 02-28-2011, 07:26 AM   #1600
NiMo's Avatar
2 cell with 7.5t motors on a 105ft long track?
That must be a handful ?
We were reaching over 60mph with 2s 13.5 on a 155ft main straight, and that seemed busy, but that is with 200mm GT cars, and not full high downforce Pro10.
NiMo is offline   Reply With Quote
Old 02-28-2011, 12:13 PM   #1601
bencason's Avatar
Randy,
what bodies do you and your Dad run on your WGT cars at the C?
I am trying to put together a working car from my old pan car stock. The bodies that I have left over from the past are GTP style and intended for 235mm. The car most likely to get used is a RC10L SS that is 200mm in the front and 210mm in the back, so I would like to pick up a modern 200mm body for it.
The RC cars are in storage but not forgotten
One of these days, I'll be back to racing... somewhere
bencason is offline   Reply With Quote
Old 02-28-2011, 06:21 PM   #1602
Originally Posted by bencason View Post
Randy,
Hi Ben, its great to see you are interested in world gt at the coliseum, theres a link below to wgt rules and should answer all your questions or you can come see me next time time you are at the track and we will get you setup. http://www.worldgtrc.com/World%20GT%...s%20-%2009.pdf these are the rules we follow at the 'c' i run the db9 gt and dad runs a protoform corvette, when you get serious about wgt we will have to get you setup with a CRC ride!
★Randy Banks★
Old 02-28-2011, 06:25 PM   #1603
ha, believe me, it is! To be able to make the turn on the end of the straight we have to run full front compound, but now that the carpet nats are near, we are running by the true rules.
★Randy Banks★
Old 02-28-2011, 06:42 PM   #1604
gonzo416's Avatar
Trader Rating: 39 (98%+)
It would be nice to see a video.
gonzo416 is offline   Reply With Quote
Old 03-01-2011, 11:12 AM   #1605
Atcom's Avatar
This may sound stupid: I also realised that there isnt enough place for average 2s lipo packs; So what if i opened the casing of a hard case lipo and put in the car like that?
Atcom is offline   Reply With Quote
