CRC 1/10 Pan Car
#1576
A genx isn't made for modified. If you are really serious about running modified i would suggest you to sell your crc genx and buy something else like a corally 10sl or if by any change you come across a second hand Speedline or Hatzenbach (or de rc devil one) buy that without blinking.
The modified pro10's in germany use 7 or even 6t delta's. You will have to have a strong pod and chassis to withstand such forces and speeds. Purpose build modified pro10's have 3mm carbon chassis etc. Even the corally with it's 3mm carbon chassis you will have to change out the plastic ride height adjusters to aluminium cause the plastic adjusters can't handle it. To play it safe i would get lipo's in the 6000mAh range. The 5000mAh are sometimes not enough to push the car for 5 minutes. They get a beating.
The corally axle is thicker then the normal associated style axle and uses bigger bearings as well. What i read is that more people are changing towards the corally axle. It seems to be more stable. (together with the aluminium ride height spacers)
#1577
rubish, a genX-10 does work in modified
at velp I run it and it works.
corally XBP 4T, 235mm expansion set,
pink or lilac tires all round,
low roll out and a body like the porsche
to tell the thruth i broke more parts running it indoor for the first time this season as a WGT then i did in two years running it outdoors modified.
it is very durable outdoors
#1578
Hey tom,
Ok i gues i read and heard it wrong from the other peoples experiences.
Hope to see you on the outdoor track soon. (ps your right about indoor damage. )
Alexander
Alexander
#1579
I've tried this solution but diff.l plates are more softer than the X-Rays and the thrust bearing need to be replaced more often. You can use both 48 and 64 pitch gears with this car
The 235mm conv.n isn't a good option since it uses a larger axle hub instead of longer axle,this design allow the axle to flex and break often,it happened to my CRC a coupple of times,at the third axle change i put everything back to stock with the 235mm. option back as spare and thrown everythingfor sale on fleabay. The only 235mm. car worth is the Corally,the only 235mm. i've used without having any issue. For this car you better get COrally gears,axle width is slightly different from the others.
I'm sorry for those CRC supporters i'm not here for flaming but when it comes to say something about low winded 235's there's only the proof of practice.
#1580
indoor is hell
way too fast on way too small tracks
walls everywhere
and to complete this horrorscenario - compatitors pushing you into the boundaries^^
but thatīs the funpart
the crc is fine outdoor - very rigid car
but
nothing compared to a f103 based "tanks"
the more "complex" the suspensions get the weaker they become
in order to be light main parts canīt be made of aluminum and in order to be affordable it canīt be made of more exotic materials
all in all the crc does a great job
itīs a good compromise : strong + good handling + $
greetz
GenX_CLR
walls everywhere
but
greetz
GenX_CLR
#1581
And 1 part is even discontinued
Can't wait for the outdoor season.
#1582
The crc wgt with the 235 kit will work just as good as any other car running mod thinking it wont is just plane crazy. i have ran it and it works very well you just have to find a good setup that works for your driving style very easy to set up.
#1583
indoor is hell
walls everywhere
but
greetz
GenX_CLR
walls everywhere
but
greetz
GenX_CLR
Sorry but I need to make a correction, I have broken several rear axle bearings and chewed up a couple spur gears.
#1585
#1586
For the past several weeks I've been running a slight variation of Brian Wynn's setup on the CRC website. I'm running the LE version. Quick question, how would you get the front end to 200mm as he states on this setup sheet ? I can get to about 196mm with axle spacers/washers, but much past that the wheel nut is unusable. I really just want to experiment with the car at 200mm front and rear to see how it reacts. The does turn in agressively now, so I'd guess this set up is a bit tamer ? Is there a particular front end part I need to buy to get the LE to 200mm ? There just doesn not seem anyway to do it. Thanks.
#1587
#1588
With the LE, there's really only once choice on width (the center brace is a fixed width). Have I missed something ?
Now with the older car, I can totally see how to fix this issue. Again, with the LE I just can't figure it out. Thanks.
