Old 01-21-2011, 07:05 AM   #1501
I love my LE! Can't beat it.
chuck
mackin is offline   Reply With Quote
Old 01-21-2011, 08:25 AM   #1502
Still Bill's Avatar
chuck
In case someone does, we're here to help...LOL
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 01-21-2011, 12:04 PM   #1503
tim fry's Avatar
Originally Posted by Still Bill View Post
Hi Tim,
Please start with some information on your current setup.
Motor/battery configuration?
How much caster are you using? Caster (via spacers) and dynamic caster.
What body?
Spec tires? Sizes?
Cheers!
Bill
Hi Bill
Im running 1s 10.5 with battery fixed up front. Caster Im running shims all behind and 10 deg blocks so should give maximum entry. Rear Ive got green side springs and 50k oil in dampers.
Im running the front on wide setting with middle ackerman.
I had to stiffen it up to stop it from grip rolling but now when we run a tight track it struggles to turn in and change direction. I did soften the rear again a bit but then the roll comes back. We run lilac spec tyres.
Tim
tim fry is offline   Reply With Quote
Old 01-21-2011, 12:36 PM   #1504
NiMo's Avatar
Originally Posted by tim fry View Post
Hi Bill
Tim
When grip is down narrow the front track
NiMo is offline   Reply With Quote
Old 01-21-2011, 04:27 PM   #1505
Atcom's Avatar
Thanks for all the advice! I am going to go with the LE kit. im planning on using my 10T brushless motor, with dx3s and some metal geared digital servo. Does that sound fine?
Atcom
Atcom is offline   Reply With Quote
Old 01-21-2011, 08:21 PM   #1506
Still Bill's Avatar
Atcom
Sounds good.
Best servos are the KO PDS951-ICS or JR3650. JR is usually a tad cheaper.
Old 01-21-2011, 10:17 PM   #1507
Cory98604's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Cory98604
I've got a question I am finishing putting my LE kit together and I was wondering what do you guys do with the ant. wire do you tuck it with all you other wires or do you run the ant tube? Any pics of your cars also for positions of electronics, wires.
Cory98604 is offline   Reply With Quote
Old 01-21-2011, 10:31 PM   #1508
Plasting's Avatar
Send a message via AIM to Plasting Send a message via Yahoo to Plasting Send a message via Skype™ to Plasting
I never got into pan cars but this thing looks clean!
www.PlastingDesigns.com
Plasting is offline   Reply With Quote
Old 01-22-2011, 04:56 AM   #1509
It's a great car, easy to set up and drive. WGT is a blast. No need for different compounds of tires, and the 13.5 is plenty fast indoors. plus plenty of help if needed.
chuck
Old 01-22-2011, 11:58 AM   #1510
Still Bill's Avatar
With about 7" of antenna wire to deal with, i did about a 4.5" antenna tube that bends to the rear of the car about a third of the way up the tube.
ESC is behind battery pack. Li-fe pack is on left and receiver is on right. Both are about 1/4" ahead of the front of the side links. All side-to-side balancing done with these components and transponder. No additional weights required.
Old 01-22-2011, 07:49 PM   #1511
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Well I got my car from another member here. It's setup for carpet, never ran carpet or a pan car so should be interesting. Need to save up for a Tekin esc and radio now and then i'm good to go.
Anyone run these outdoors with much success?
offroad - AE B44.3 / /Serpent SRX2 MM / /
onroad - VTA AE TC7 // XRAY 2017 T4//CRC Gen X SE- WGTR//Xray X12-17'
support your local tracks- Beachline Raceway-Revolution RC-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 01-22-2011, 09:24 PM   #1512
Still Bill's Avatar
I ran my Gen-X 10 for the 2010 Asphalt Nats at NorCal Hobbies. The car was excellent; and, I believe the LE version will be even better...on asphalt. Already is on carpet. Trying to keep WGT going year around on carpet and asphalt in the Greater SF Bay Area.
Today, we had 14 WGT cars for a winter points series carpet race at NorCal...10 being CRCs. And not everyone was there.
Bill
Old 01-23-2011, 11:59 AM   #1513
JEFFs SC10's Avatar
My intent for this car was to run it outdoors, it's nice here 80% of the year.
Old 01-23-2011, 07:04 PM   #1514
Still Bill's Avatar
Spec tires work great at Nor-Cal Hobbies and Speedworld. And I now understand that Ripon is good too. Go for it!
Old 01-23-2011, 07:46 PM   #1515
Still Bill's Avatar
Hi Bill
Tim
Didn't ask; but, I assume you are on carpet.
I almost always have red side springs and usually 30k oil in the damper tubes.
If you are grip (traction) rolling, I suggest you get your camber to somewhere below .75 neg degrees until that is under control. And then add camber to get some steering back; but, not enough that you start grip rolling again. You may end up with slightly different camber settings from side to side...no problem.
Cheers.
Bill
