Old 06-23-2003, 05:38 AM   #1
sixandeightstri's Avatar
Exclamation Question for ppl with battery zappers
Greetings - I have a Quillen 1500 zapper, and to be honest, I'm not sure it's actually doing anything.
I've been zapping some fresh cells, and although the process seems to be proceeding normally (the LED's light, fade and go out properly) I wanted to know if there is some sort of sign that the zapper is actually doing its job.
Shouldn't the batteries be a little warmer when I take them off? Can I put a multitester across the contacts to verify that a charge is going through the battery? If so, what range should I set the multitester?
Any insight is appreciated, as I'm a bit slow on the uptake as far as electrical tech stuff is concerned - but I'd really like to know if I'm sitting here going through the motions of zapping and not actually doing anything.
sixandeightstri is offline   Reply With Quote
Old 06-25-2003, 02:47 AM   #2
Send a message via ICQ to JesseT
You can use a multimeter (200V range) to measure voltage across the cell while zapping. Since the cells should be totally discharged before zapping, you can also measure the voltage before and just after zapping ad see if there is a rise. The cell should not become any warmer or anything because of the zapping.
JesseT is offline   Reply With Quote
Old 06-26-2003, 06:46 AM   #3
Cycle your cells, before and after......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Turbomatcher 4/30, battery zappers HenBeav R/C Items: For Sale/Trade 4 11-29-2006 06:42 PM
Battery Zappers gc2005 Electric On-Road 21 04-09-2005 07:59 AM
Anyone know about battery zappers? elmo6s Electric On-Road 15 02-22-2005 03:41 PM
Battery Zappers? soon2bfast Electric On-Road 1 04-07-2004 12:30 PM
Your thoughts on Battery and Magnet Zappers popsracer Electric On-Road 9 04-13-2003 10:14 PM
SEO by vBSEO 3.5.0
