Hot Bodies Gumballs Racing Slicks
Are they any good as i have wasted close $250 on different tire does anyone know if they are good?
As the much more tires even with tire warmers set at 5 more degrees than the track temp
Or can you recomend any other rubber tires?
what type of track is it your running at? And what tyres have you got at the moment?
Much more, tamiya and rp i think i might have sorex they work but the are hard to get. i also have some other ones
I run at a tar medium rough track
Maybe can you guys recomend a good cleaner and trction compund
But from what you've said already, tyres can only do so much and if your setup is really, really bad, don't expect miracles from the tyre. Also, the insert is (a lot of times) more important then the tyre. From what I understand, Take-off CS27 or Sorex 28R are well liked down there.
PS> I'm surprised you're not an expert at this as you are with "Second-hand Stuff"
Regards,
Peter
I have a well run in motor, so it is a quik motor
Thanks peter i have a really good set up as that was the first thing i questioned but it was not the full problem but now i have found that my set up that wants to slide least with my car. Why do you assume that i live melbourne australia. Do i know you? Sorry about the tire warmers but no offence but i hate people who load there old stuff at more than rrp on newbies that dont know better. As that happened to me!!
At least say where you race , like the town etc..., as this can give us some more info on a type of tyre (heat range) ,
How can the fast guy run a mini we arnt talking about mini class here are we???
you could Ask someone that races in stock or mod tourer that does well..
Also Sorex is easy to get, just use the net....
http://rctyres.com/ Australian website to
Gumballs are crapola
ok so what state or town are you in dude!!!!!!!!!!!!!!!!!!!!!!
So we can give you advise that you have asked for............................................... ...................................
its like your dodging the ??????
(it matters heaps to what tyre to run if you are in Brisbane or Perth or Hobart etc..... due to temps)
