Old 01-21-2008, 08:03 PM   #1
Default GTB 4-Cell and power capacitor
has anyone used their GTB 4 cell without the power capacitor?
I am running 10.5, in a Gen X
But I need to shed some weight on it and this would be a good way.
Is there any substitute that is smaller?
lifeguy is offline   Reply With Quote
Old 01-21-2008, 08:56 PM   #2
trailranger's Avatar
I would not remove that TransCap modual. It may lead to failure of the ESC
You can shed weight by:
Shorting your ESC and Servo wires with a kit from Servo City (Crimp pins not solder)
Replacing all the screws with Titanium and Aluminum screws.
Replaceing the rear motor pods with the AE plastic left side and a milled out Magnesium right side.
Use 14ga or 16ga wire if current loads permit
Replace the servo with a lighter one (Karbonite or Ti gears vs brass and steel)
Use smaller battery bars. I believe deans 2.0 are lighter than SMC
Cut on your chassis
Lightweight body
Use a smaller RX (I use the SR3500 from spektrum)
Use lower natural rubber tires, they weigh less
trailranger is offline   Reply With Quote
Bad Power Capacitor??? 2BAD4ALL Electric On-Road 4 11-24-2004 10:59 AM
Power Capacitor ?? T.SATO Electric On-Road 10 04-12-2004 04:18 PM
Power Capacitor T.SATO Rookie Zone 7 04-08-2004 03:49 PM
Power Capacitor johnbull Electric On-Road 31 05-22-2003 07:27 PM
power capacitor - TC3 Brazilian Electric On-Road 11 01-12-2002 07:24 AM
SEO by vBSEO 3.5.0
