Old 04-14-2011, 07:19 AM   #14851
caltek1's Avatar
Trader Rating: 33 (100%+)
The Big Wig,
I don't call 40 grams heavy. That is with oil. With the BL systems we are using in mini we get wheel anyway. Once they are rolling, less wheelspin and more drive out of the corners with the added advantage of less maintenance.
Calvin.
caltek1 is offline   Reply With Quote
Old 04-14-2011, 07:26 AM   #14852
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by The Big Wig View Post
Now why do U need a heavy gear diff with a front wheel driven car? The wheels will start spinnin' waaaaaaaaay before the ball diff does. In a high power touring car I can come in to that but any FF with mild motor it will only ad rotating mass.
FYI ....
TA03 ball diff .... 30 grams
Oil gear diff ...... 25 grams (the oil gear diff is a standard gear dif with a gear added ... more info coming)
So in fact the oil gear diff is lighter
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 04-14-2011, 10:16 AM   #14853
The Big Wig's Avatar
Originally Posted by caltek1 View Post
The Big Wig,
Calvin.
For maintenance I can understand but peformance wise I think ANY fwd is better of with a ball diff (as long as it lighter).
Originally Posted by cannon View Post
FYI ....
25 With no oil. 30 For a heavy TA03 one. M05 ball diff is lighter (and smoother) but needs some work to keep its settings right.
The Big Wig is offline   Reply With Quote
Old 04-14-2011, 02:16 PM   #14854
cannon's Avatar
FYI .. the oil gear diff is 25g WITH OIL . The M05 ball dif is around 18g so 7 g is hardly a problem.
For all your comments have you actually run an oil gear diff in your Mini? I doubt it
Lets see .. at TITC in Thailand all the worlds best like Groskamp etc what did they use in their Minis and FWD cars ??????? ....... gear diffs because they pull better out of corners
Old 04-14-2011, 05:26 PM   #14855
7g x3 Becouse its rotational mass. Only in my M04. Jilles wanted allmost spool like action and used cleaning putty.
Old 04-14-2011, 06:12 PM   #14856
Trader Rating: 22 (100%+)
The Big Wig,
Calvin.
Um mine weighed 55 grams ( moddified Durango gear diff ) at the masters Calvin, and the car was slow.
More weight in the diff makes it spool up slower (less wheel spin) and carry more momentum through the corners.
bjspinner is offline   Reply With Quote
Old 04-14-2011, 08:02 PM   #14857
Ok but with that theory you should use a steel pinion/outdrives/driveshafts/ect,alu wheels and so on. Look at real race cars. The ONLY time they consider using a havier part would be a flywheel on a combustion engine. Lighter is ALWAYS better. When a heavy car works better then a light car then it's the lighter one that isn't set up right.
Old 04-14-2011, 08:17 PM   #14858
We run the Hobbtwing 13T brushless system, it has plenty of torque.
Heaps of wheel spin equates to tire wear. With control tire's that weight slows down the spool up speed (less wheel spin more tire life) and also carries speed through the corner (smoother cornering).
I have tried them all (diff's) the oil filled gear diff is by far the best that I have used.
I don't care to much about the weight, my MO5 tips the scale's at 1500+ grams and it is fast.
Old 04-14-2011, 08:33 PM   #14859
I get U. But U probably wack the throttle to much. Very tempting in an FWD becouse U won't spin out.
Old 04-15-2011, 12:49 AM   #14860
caltek1's Avatar
Thumbs up
Bruce,
I have to agree with you. I am using a modified 3Racing oil gear diff with 500 000 wt oil which gives me a diff which works very well.
I tested it today on a semi tight track and the car is working really well. I will be monitoring its durability, however with graphite gears from a nitro car oil gear diff and nitro diff outdrives I'm sure it will last. All of the guy's who have a oil gear diff fitted to there mini seem to like them.
I still have the TAO3 ball diff in one car that I use regularly. Today I ran against two of the faster mini drivers and I can keep up with them, so the diff is working well. Now it is car, tyre and driver setup.
Bruce will contact you later.
BTW,
Don't take to much out of this as my mini is kinda slow. LOL
Regards,
Calvin.
Old 04-17-2011, 11:36 PM   #14861
Just thought I'd post an update on my struggles with my evil M05M. It had resisted all my efforts and the suggestions on this thread and a number given to me in PMs. That damned evil piece of S--- behaved the same way no matter what we did to it short of total destruction.
A fellow racer, Kevin Nino, whose M05M is excellent, took that evil monster home with him and went thru it. He returned to me, a car that was very, very good. I like to run very little droop in the shocks cause that's what my M03 M&L seem to like. Kevin increased the droop about 1.5 to 2mm over what I had and we had us a new car. He says that was about the only change required. I now have a car that responds predictably to spring changes, drives in a straight line, doesn't pull one way then another under acceleration. I forgot. he raised rhe front ride height a mm over what it was before. I've taken to calling Kevin the exorcist.
In some ways, I envy my Australian friends and others, who have the benefit of using different tire and insert combinations. But, tire changes may have made the car driveable and I then would still have a car in need of an exorcism. I'm changing my position on the Spec tire and think it's not a bad idea. Not trying to start anything here, just saying I like the one we're using.
I guess the new B compound tire aren't selling cause the rumor mill has been floating the possibility of a new Spec tire for TCS in the USA. I'd heard that was for next year. Don't know if it is an addition to one we have now, or a replacement.
Granpa is offline   Reply With Quote
Old 04-18-2011, 11:41 AM   #14862
gruman28's Avatar
Trader Rating: 16 (100%+)
Can anyone tell me where I can order the tamiya aluminum steering set up and front damper stay in the USA? I can find the steering set up on ebay, but not the other.
chris
gruman28 is offline   Reply With Quote
Old 04-18-2011, 12:06 PM   #14863
chris
Try Speed Tech. Decent prices and good service
Old 04-18-2011, 07:16 PM   #14864
gruman28's Avatar
thanks, they even have TOP parts.
Chris
Old 04-19-2011, 05:15 AM   #14865
Guddam's Avatar
Default Current M-05
Mini Forever......
Controlled by FUTABA
Powered by SMC and IP
Moved by SPEEDPASSION, LRP and HOBBYWING
Sponsored by VISA and MASTERCARD...
Guddam is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
SEO by vBSEO 3.5.0
