Old 03-23-2011, 06:52 PM   #14731
mark.davis's Avatar
Default What Tamiya bodies fit the long wheelbase M05 pro?
What Tamiya bodies fit the long wheelbase M05 pro? 239mm. It's very hard to tell based on the tamiya webiste.
Also, should I be running the longest wheelbase? I race on a rather large parking lot track.
How to start an argument online:
1. Post something
2. Wait
mark.davis is offline   Reply With Quote
Old 03-23-2011, 07:00 PM   #14732
jcr
http://www.rc-mini.net/joomla/index....d=46&Itemid=62
Plus the Alfa Mito
jcr is offline   Reply With Quote
Old 03-24-2011, 10:42 PM   #14733
Foxxrocket's Avatar
I've been searching this thread with words like "setup" and "asphalt". But haven't came across too many setups for the M05. There is a race comming up in two weeks and I would like get it as race ready as I can. The track is outdoor asphalt, with med to high bite traction. Two sweepers with a long front straight and a small technical area in the middle.
I'm running a M05 with a ball diff and TRF shocks. I have super grip radial tire(can only run radial tires). But the biggest factor is going to be shock setup. And that's where I'm at a lose.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 03-25-2011, 09:25 AM   #14734
Swifty posted his TCS winning setup not too long ago. It should be on the Tamiya website also. I'd give you the link, but my computer skills are deficient. you might do a Sir Swiftalot search.
Granpa is offline   Reply With Quote
Old 03-25-2011, 09:58 AM   #14735
tiko's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to tiko
Here you go
http://www.tamiyausa.com/articles/ln...n_Koslosky.pdf
LionArtPrints - Custom Apparel, Hats, PitMats, RC Car Bags, and More
LionArtPrints - On Facebook
tiko is offline   Reply With Quote
Old 03-25-2011, 10:21 AM   #14736
MD
MD's Avatar
Trader Rating: 105 (100%+)
tiko - Can't open it.
MD is offline   Reply With Quote
Old 03-25-2011, 10:22 AM   #14737
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Weird worked fine for me through my email notification, but not through the link on this page. I noticed the 21t in an 05..... hmmmm??? Surely a typo
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 03-25-2011, 10:48 AM   #14738
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
worked fine for me both in the email notificiation and here
hmmmmm
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-25-2011, 12:12 PM   #14739
tiko's Avatar
Ok, go to Tamiyausa.com, on top go to articles, then radio control the very first article In Depth With the 2010 Champs. First setup sheet on top of the Mini pic. is Brandan's. Hope this helps.
Old 03-25-2011, 02:53 PM   #14740
MD
MD's Avatar
tiko - Thanks!
Old 03-25-2011, 07:42 PM   #14741
SirSwiftAlot's Avatar
Location: SOCAL the fastest mini cooper guys in the nation
If your going to use my setup I would drop down in oil to 40 as Tamiyas track is not so grippy. so higher grip lower oil. Hope that helps. Let me know if you need any help.
Why do people park in a driveway but then drive in a parkway?
SirSwiftAlot is offline   Reply With Quote
Old 03-25-2011, 09:16 PM   #14742
landozer18's Avatar
Default Mini parts online?
Hey guys & gals just looking for some good sites to order tamiya parts from (ex:metal steering links, different rims & tires)
Winning is winning, doesn't matter if it's by an inch or a mile!
Lanny,
landozer18 is offline   Reply With Quote
Old 03-25-2011, 09:56 PM   #14743
jcr
RCMart from HK is a good source. Since you're in BC and if you want to order from Canadian source, then you can try that Much Hobby link I sent you before. They're pretty much located right beside Tamiya Canada....
I got my M05 there and most of my local stuff there.
Old 03-25-2011, 10:04 PM   #14744
landozer18's Avatar
thanks again
so helpful to a new guy
Lanny,
Old 03-26-2011, 09:35 PM   #14745
Misiek's Avatar
Are there aluminum front C Hubs made by Tamiya available for M05 pro (All I could found was 3racing)?
________________________________________________________
On paternity leave...
Misiek is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
SEO by vBSEO 3.5.0
