Like Tree200Likes
Old 02-25-2011, 08:04 AM   #14506
mangoman's Avatar
Go the switch!
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 02-25-2011, 02:43 PM   #14507
Default which Kimbrough servo saver ??
Hi there.
Which is the right which Kimbrough servo saver to use
Small, med, large,or heavy duty.
are the large too large??
the small too small ??
cheers
1101 is offline   Reply With Quote
Old 02-25-2011, 03:10 PM   #14508
monkeyracing's Avatar
I've been using the Kimbrough large and/or heavy duty on my minis. You may have to drill your own holes, but they work worlds better than the Tamiya one.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-25-2011, 05:16 PM   #14509
Our local club is hosting a 6 hour mini Enduro, 90% are M05 and 10% M06
Anyone on here have any suggestions that has run in one before?
We are running Canadian TCS rules.
Bodywerx_rc is offline   Reply With Quote
Old 02-25-2011, 09:22 PM   #14510
jcr
Originally Posted by 1101 View Post
Hi there.
cheers
M03 use the large one but need to trim a bit of the edge off for clearance
M05 I am using the medium with the middle hole with no issues
jcr is offline   Reply With Quote
Old 02-25-2011, 10:44 PM   #14511
Firefox's Avatar
It has probably been answered before but what is the difference between the Tamiya CVA Super Mini Shocks #50746 and the CVA Mini Shock Unit Set II #50519 ?
Witch is more desirable ?
Tamiya M05, Associated SC10.
Firefox is offline   Reply With Quote
Old 02-25-2011, 11:06 PM   #14512
Are you running in teams? Taking shifts?
Here's how we usually run a team: 3 guys. Driver, marshal, pit guy. We would run 5 minute shifts, so it was kind of like running heats, but with no gap between them. Each guy on the team rotated through each job, with the most important being the guy making sure all the batteries in the pits were charging.
Each driver on the team would run their own car. This reduced wear on individual cars and gave the pit guy a chance to do repairs while the car was in.
That's pretty much it. Not sure how others run them. There are probably examples out there where there's a single team car with rotating drivers, actual pit stops, etc.
Stab it and steer.
Old 02-25-2011, 11:19 PM   #14513
Originally Posted by mr lee
The super mini has a smaller oil reservoir and allows more travel compared to the mini shock unit. Go for the super mini. You can always limit the travel by adding spacers inside and outside the shock.
If you go for the mini shock unit which will have limited amount of travel when installed on the mini and should you actually require the extra travel you would have waisted your money!
Alternatively go for the TRF's or M chassis ali oil shocks.....worth it in the long run!
from a few pages back
Losi 8ight
Nitro Rustler
Tamiya M04 - Karz #79
OFFroadrunner is offline   Reply With Quote
Old 02-25-2011, 11:41 PM   #14514
caltek1's Avatar
Trader Rating: 36 (100%+)
Firefox,
The Tamiya CVA Super Mini Shocks #50746 are the ones to get. The others are to long and you will not be able to drop the car enough and still have any droop.
The best alternate is to get the Tamiya M Chassis TRF shocks or if you have normal TRF shocks add a 4mm spacer underneath the piston.
For springs if you get the Tamiya CVA super mini shocks then get the short TRF mini spring set PNo 84117 or the TC Short Spring Set PNo 42168.
I think you should have a good read of the rc mini net site, which will be able to answer the majority of your mini questions.
Another alternate is to get the 3Racing shocks, come in a packet of four and come in different lengths.
I refer to that site regularly and point others to it often.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 02-26-2011, 06:50 AM   #14515
Firefox's Avatar
So are the 53155 shocks pictured below the M chassis aluminum of which you speak ?
Do you have a part number for the TRF's ?
thanks
Old 02-26-2011, 08:18 AM   #14516
jcr
thanks
You're looking for 54000
http://www.rcmart.com/catalog/rc-dam...0-p-25921.html
Old 02-26-2011, 09:48 AM   #14517
Firefox's Avatar
And just playing around.......
Old 02-26-2011, 03:25 PM   #14518
Trader Rating: 55 (100%+)
Are the TCS premounts #1016 the same compound as the tires that come with the M05? If not, what is the part # for the tires that come in the kit?
Thanks,
Greg
G the Menace is offline   Reply With Quote
Old 02-26-2011, 08:59 PM   #14519
Laguna Bozo's Avatar
Default Enduro
Isn't the whole point of an Enduro to run one car the whole way?
Craig Richter
Laguna Bozo is offline   Reply With Quote
Old 02-26-2011, 10:13 PM   #14520
Depends if you're racing on a budget. We're a cheap bunch.
We set it up more like a relay, I guess. It works though. Always fun.
Stab it and steer.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
