Like Tree136Likes
Old 02-19-2011, 01:57 PM   #14446
Thanks! As you can see, the HPI Civic body is to narrow. The selection of 225mm bodies is limited- so shrinking it is pretty much my only viable option. Don
DLS II is offline   Reply With Quote
Old 02-19-2011, 02:15 PM   #14447
monkeyracing's Avatar
Have you tried the HPI Miata? It's roomy.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-19-2011, 02:21 PM   #14448
No I haven't, I was hoping something in 210mm would fit once I shrunk it. A Fiat 850? Has anyone ordered from RC Mart? They have Colt bodies-are they wide enough? Shipping charges with RC Mart?(standard-not expedited) Don
Old 02-19-2011, 03:52 PM   #14449
SoCalGuy's Avatar
Hi All.
I need a beginner class in differential adjustments. It seems most of you recommend a "tight" diff. How does that effect handling, steering, etc., versus a "Loose" diff. with regards to the M-05 (FWD)?
Thanks in advance.
SoCal.
And to ask a prior question; any good pre-painted mini bodies out there?
Mugen MBX6 Eco, Kyosho ZX-5 FS2, Team Durango DEX210
Tamiya TB-03, Tamiya M-05 Pro, Associate 18R, Vaterra Kemora
SoCalGuy is offline   Reply With Quote
Old 02-19-2011, 04:20 PM   #14450
cartix's Avatar
Trader Rating: 33 (100%+)
Originally Posted by DLS II View Post
Hi, I'm working on my mini. It is currently 225mm wheelbase, but I'm going to shrink it to 210mm. I need a body-suggestions? Obviously something with a "nose". Wt. is 1330 grams, width(trac) is 167mm. The weight is not completely set as it's going to get a new chassis out of .125 G10 versus .093(to much flex) and a 2s lipo. Thanks, Don
Nice work! How does it handle?
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 02-19-2011, 04:33 PM   #14451
lupin_au's Avatar
Send a message via MSN to lupin_au
Originally Posted by SoCalGuy View Post
Hi All.
Thanks in advance.
SoCal.
Well I found a "tight" diff just helps drive out of the corners. Stops the inside wheel from spinning as much and gives a little more drive to the outside wheel.
But I also noticed it makes the car slightly different to drive.
I run the TA-03 ball diff.
Exotek T2R | Schumacher Mission | M05 Mini | RC18R | X-Ray T2-007 EU | Tekin | Sprektrum | EDS
http://www.westcoastrccarracing.asn.au/
http://www.lupinzblog.com/
lupin_au is offline   Reply With Quote
Old 02-19-2011, 05:30 PM   #14452
It handles pretty well-although I've yet to be able to compare it to a M03 or M05. Don
Old 02-20-2011, 04:51 AM   #14453
pimoy_boy's Avatar
Originally Posted by BumFacedGoat View Post
i run an m03. almost unbrakeable and really ez to work on. a lot of my buddies run m05's but i reckon they arent very ez to work on.
m04 and m06 are rwd, much harder to drive
Originally Posted by monkeyracing View Post
The M-03 is the easiest car to deal with for your first mini. They are very easy to work on and fun to drive.
I would say the most essential hop ups are better axles, shorter springs and good tires.
Everything else is just shiny.
Originally Posted by sidecarphil1 View Post
i have both M03 and M05 , after 1st having problems with the M05 i have worked hard on it and now it is AS quick as the M03s in the club ,
I love it and it is more prodictable then the M03 and more consistant
all though no quicker , i like it more
and as for mantinance i can strip the gearbox and rebuild it as quick as i could with my M03 so there is no time worries there
M05 for those who like to tinker M03 fo those who like to build and drive
hi guys noted with thanks
If you wait to do everything until you're sure it's right, you'll probably never do much of anything.
pimoy_boy is offline   Reply With Quote
Old 02-20-2011, 06:33 AM   #14454
Anyone know where I can get parts for M01? Besides ebay and the WTB section.
Sponsers; None, Just in it for the fun!
hdsport82 is offline   Reply With Quote
Old 02-20-2011, 10:21 AM   #14455
Firefox's Avatar
Any pics of the plated M05 chassis assembled ?
Tamiya M05, Associated SC10.
Firefox is offline   Reply With Quote
Old 02-20-2011, 01:41 PM   #14456
RossoTorro's Avatar
Yes...
Taken with Sony Ericsson X10 Mini pro...
We run ezrun and foams on our track, since all have same tires and esc/motor combos the racing is very close!
RossoTorro is offline   Reply With Quote
Old 02-20-2011, 01:46 PM   #14457
Firefox's Avatar
Thanks.
I need to replace some chassis parts and thought I might try the plated set.
Do you run the 13T motor ?
I was thinking of a 17 turn myself.
thanks
Old 02-20-2011, 01:48 PM   #14458
RossoTorro's Avatar
We run ezrun 35A with 13T motors, perfect blend between speed and battery consumption. Cheap system that works equal for all.
Also have the black and red plated chassi, 2 of each, going to bulid one each...
Old 02-20-2011, 10:24 PM   #14459
Showbiz's Avatar
I agreed with this.
I have run 11.5T and feeling good about it but I always bite the other dust on the track lol.
Now, they using boost-able speed, which I don't have.
Here is my ride. (My Tire Sweep just burn out last night)
Showbiz is offline   Reply With Quote
Old 02-21-2011, 01:29 AM   #14460
Anyone have an update on the aftermarket gear diff situation? Can't remember who was experimenting, but I'm interested in the results.
Stab it and steer.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 10 (2 members and 8 guests)
SilverShelby
