Like Tree48Likes
Old 02-14-2011, 11:21 AM   #14416
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
anybody have use for a TCS loaded M03? battery, speedo bodies all steering upgrades extra super mini's etc. drop me a PM. just sittin on shelf.
doc and doc only, have use for a spare fantom dyno? lookin for a good home for it, dont have a big PS anymore nor time to fiddle with it.
R
UltegraSTI is offline   Reply With Quote
Old 02-14-2011, 03:55 PM   #14417
SoCalGuy's Avatar
Married w/ children so free time is at a premium.
I also crash alot
Are there any decent pre-painted, pre-cut bodies out there for the M-05? I spend hours (yeah, I'm slow) masking, painting, cutting, applying decals, only to smack a curb on the first lap. Any suggestions would be very appreciated.
SoCal
Mugen MBX6 Eco, Kyosho ZX-5 FS2, Team Durango DEX210
Tamiya TB-03, Tamiya M-05 Pro, Associate 18R, Vaterra Kemora
SoCalGuy is offline   Reply With Quote
Old 02-15-2011, 10:51 AM   #14418
BumFacedGoat's Avatar
I think Tamiya offer a lot of their bodies pre-painted. they come from the XB series
BumFacedGoat is offline   Reply With Quote
Old 02-15-2011, 11:17 AM   #14419
RossoTorro's Avatar
They are much more likely to crack than clear ones.
But they do look really, really good though!
RossoTorro is offline   Reply With Quote
Old 02-15-2011, 11:48 AM   #14420
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Granpa View Post
On a MWB start with a balanced set up. You know same shocks,springs, tires etc.all around. Same camber front and rear. 1-2 degrees of toe out on each side. Specific springs, oils, and blah blah blah are worthless cause we don't know the track surface, grip levels, type of track layout or track temps etc. But you sound like a veteran racer and not a total newbie so you probably knew that. Tires work the same as on a TC, but many things don't. Just don't go into an adjustment thinking it will do a certain thing. About half the time it'll do the exact opposite from a TC.
Granpa, Mango, Calvin & others....
Update.
All sorted. Culprits were badly worn tires and a frt sway bar binding....
More testing tmr to confirm but seems a lot better 2day.
Setup:
Front
1 deg camber, Outter hole on Opt Shk Tower, #400 oil, 3 hole piston, 55mm long shock, Blue springs, 3mm rebound, 1.5mm spacing for Toe-out, no swaybar, 4.5mm ride height.
Rear
1 deg camber, #400 oil, 3 hole piston, 55mm long shock, Yellow springs, 3mm rebound, 2 deg Toe-in, no swaybar, 5.0mm ride height.
General
MWB, TRF Mini Shocks, Tires 60D Super Grips, Esc on opposite side, Manta Ray Diff-packed tight with AWGrease.
Thanks again, much appreciated....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 02-15-2011, 02:35 PM   #14421
Trader Rating: 75 (100%+)
Just picked up my m-06, and was curious to see if there is an aluminum steering knuckle for it. With everything thats included in the kit, I'm shocked to see the plastic steering knuckles. I'm pretty new to the cooper seen, so I apologize if this is a dumb question.
MUDVAYNE is offline   Reply With Quote
Old 02-15-2011, 03:17 PM   #14422
monkeyracing's Avatar
The M-05 and M-06 (alloy) knuckles are the same. M-03R will fit, too. I've fit an old set of M-03/TL-01 knuckles to mine by using the older (larger) uprights.
It's just a matter of a quick test fit and figuring out the details.
Jim
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 02-15-2011, 03:50 PM   #14423
Update.
Setup:
Front
Rear
General
Glad to hear that. From your set up it looks like your track is similar to ours in grip level if that's what's working with S-Grips. With that assumption, there are a couple of things you can try.
1. Try a rear sway bar cause it looks like you went to the yellows to control the back end. I know it sounds counter intuitive, but it'll help you "roll" thru the mid and hi speed corners better. That and blue springs will keep the car a little "flatter"
2. You might start experimenting with the "rake"---- front to rear ride ht--- acts a bit like a droop adjustment on a TC. Can't tell much from your ride ht measurements cause the bottom of a Mini isn't flat so it depends on where you measured
3. Take the anti wear grease out of the diff cause it serves no purpose and will leak out and give you the most gadawful mess you've ever seen. You can pack a gear diff with stuff and that will change the diff action, but not a ball diff. Just put a tiny amount on each ball and cinch the screw down tight and that will give you tight diff that's smooth. If it loosens just rebuild and the "tightness" will come back.
Granpa is offline   Reply With Quote
Old 02-15-2011, 05:50 PM   #14424
Jim
Dialed! Thanks for the info.
Old 02-18-2011, 12:22 PM   #14425
My LHS has been telling me that there wont be any more M03's made. anyone know if this is true? they seem readily available online still
Old 02-18-2011, 01:57 PM   #14426
Does anyone here ever take apart the bearings and clean the greese out of them and put in a lighter oil? and if so, what oil?
Old 02-18-2011, 02:39 PM   #14427
Maybe not complete cars, but I've heard the parts supply will keep rolling for some time yet.
Jim
Stab it and steer.
Old 02-18-2011, 07:21 PM   #14428
I don't take the shields off anymore. I just soak them nitro cleaner. I use Slick 7 Glidex synthetic bearing lube but I think any light bearing oil will work. You just want to take the drag from grease out.
Sydewynder is offline   Reply With Quote
Old 02-18-2011, 09:32 PM   #14429
It's raining here so have another week to complete my projects so decided to check and see what was happening. I saw this post and another and decided to weigh in. It's very common to degrease the bearings thru one means or another, the most common being to soak them in motor or brake cleaner and blowing them out. Actually a commendable idea.
There are some things that you have to be careful of tho. There are a number of places you can get sealed bearings for a buck. Being naturally thrifty (cheap) I succumbed to temptation and purchased quite a few. Much to my chagrin, I made the following discovery. When you soak these bearings, the seals swell and create a lot of drag. NOT saying they all do this, but all the samples I had did. For now these bearings are just used as wheel bearings and are adequate. I don't clean etc, just put them in and run till they run rough.
My present thinking on bearings is this. I've gone back to metal shielded bearings and clean them more frequently. Both Acer racing and Boca bearings sell a quality bearing that won't break the bank. If you're really anal about this, you can remove the shield from one side and, of course put it on the inside.
Haven't done the ceramic bearing bit. Something in me rebels at the idea of spending more for the bearings than I did for the whole kit'
Old 02-18-2011, 10:02 PM   #14430
rough512's Avatar
I had bearings that became gritty when degreased. I often find that it's best to just run the bearings. The excess grease will be forced out of the races as you run them. The bearings will become very smooth and free turning eventually, much smoother than those I flushed out.
rough512 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
