Like Tree163Likes
Old 01-23-2011, 11:04 PM   #14251
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Morbo View Post
I keep forgetting. Is the Manta Ray or TA03 ball diff the one to have? Or is it the M05 one?
TA03
Blitzrockey is offline   Reply With Quote
Old 01-23-2011, 11:50 PM   #14252
over gear's Avatar
Trader Rating: 15 (100%+)
aren't they the same thing?
over gear is offline   Reply With Quote
Old 01-23-2011, 11:54 PM   #14253
Manta Ray and TA03 are the same. There is also one that is made for the M05.
rnd_tang is offline   Reply With Quote
Old 01-24-2011, 12:35 AM   #14254
I)arkness's Avatar
although there is a big weight difference between the two
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 01-24-2011, 01:06 AM   #14255
Originally Posted by 2-Bad View Post
BumFacedGoat,
Yes but as I posted I'm questioning it as most setups I've seen (for the M03) are running heavier fluid. As I posted I'm looking for reassurance.
Hey Tony,
Yes I read through that but I'd probably rate SA as med - high grip and hence discarded it. Where as the track at Keilor I've heard would probably best describe the track here.... (low grip, hairpins x 4, sweeper x 1). Would you not change anything from SA to Keilor?
thx....
Which track exactly do you want the setup for?
mr lee is offline   Reply With Quote
Old 01-24-2011, 08:39 AM   #14256
They are most definately not the same. The TA03 diff is the one to have. It's much lighter and at the same time more durable.
Granpa is offline   Reply With Quote
Old 01-24-2011, 09:15 AM   #14257
superspeed's Avatar
Anyone tried foam tires on M chassis to run on ozite carpet track? The size is similar to 1/12 pan car tires, I think the inner diameter is pretty close.
I see Tamiya is re-releasing the old monte carlo mini cooper. Wish the local track starts running m-chassis as spec class.
superspeed is offline   Reply With Quote
Old 01-24-2011, 10:42 AM   #14258
GreazyFinger's Avatar
foams are available to suit mini chassis, they can be found on ebay(search Tamiya M03, i think theyre the first thing to come up) and in some melbourne hobby stores , havent tried them personally on carpet used a set years ago on an outdoor bitumen track and they gripped well but didnt last long , have been meaning to get another set to run on the carpet at radical rc when wednesday nights start up there again
Ned Dryden | GRCCC - Geelong's Home of Electric Onroad 1/10 RC Racing | www.grccc.org.au
GreazyFinger is offline   Reply With Quote
Old 01-24-2011, 11:27 AM   #14259
RossoTorro's Avatar
Search for XPA-122 or XPA-124 on ebay... Great tires at a great price!
Free shipping from rcmart now!
RossoTorro is offline   Reply With Quote
Old 01-24-2011, 12:53 PM   #14260
monkeyracing's Avatar
Just a heads up on the M06 and keeping your motor alive. Run a fan on the thing! My motor temp after a 5 minute race (indoor, carpet, with a heatsink) was about 200 f. Having the motor hanging out back like that seems to hamper airflow quite a bit.
I hope I didn't kill this motor. It's the only good one I've got.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 01-24-2011, 02:10 PM   #14261
miller tyme's Avatar
???? mine is coming off at 98-105* every time, and I've been TQ and winner most of the time. I think the key is don't fight the car, it is a little rear loose and if you 'fix' it the corner speed is lost and results in drag producing the heat.
Ken Miller
RCTarget - Capricorn - Sanwa - Pro Level RC - MAX Power - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 01-24-2011, 03:41 PM   #14262
cwoods34's Avatar
Your motor ran really cool when I pinned you into the sweeper wall yesterday
Where can I get the 3* rear uprights for the M05? I filled the gear diff with 500K oil and I love how it handles now, but I need some more rear toe to plant the back end a bit more coming out of the turns.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 01-24-2011, 04:15 PM   #14263
Looked like you planted that roof pretty good.....a foot form the finish
Ken Miller
Old 01-24-2011, 07:42 PM   #14264
Originally Posted by miller tyme View Post
???? mine is coming off at 98-105* every time...
Seems any of us running the 06 are hotter than the other M's. Another fellow was running about 160f with a fan. You've got to consider that we're running on a fairly tight indoor course. The back straight is under 70' and the rest of the course is technical as heck. I was even running an 18 tooth pinion and just barely winding out through the sweeper and down the back.
Airflow never really happens when you run this slow I guess.
Jim
Stab it and steer.
Old 01-24-2011, 08:12 PM   #14265
rough512's Avatar
were you using the aluminum motor plate?
rough512 is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
