Like Tree195Likes
Old 01-21-2011, 07:53 PM   #14236
BumFacedGoat's Avatar
did you think of actually just trying what the locals suggested?
it looks pretty much spot-on from what my experience.
BumFacedGoat is offline   Reply With Quote
Old 01-21-2011, 08:01 PM   #14237
tony gray's Avatar
Originally Posted by 2-Bad View Post
Caltek1,
Yeah I looked through that site but couldn't find any setup's specifically for the M05...
Ummm.... THIS gives you springs, shock oil, pistons, ride height, toe-in, etc etc. Specifically for the M05...have I missed anything?....
tony gray is online now   Reply With Quote
Old 01-21-2011, 09:01 PM   #14238
2-Bad's Avatar
Trader Rating: 24 (100%+)
BumFacedGoat,
Yes but as I posted I'm questioning it as most setups I've seen (for the M03) are running heavier fluid. As I posted I'm looking for reassurance.
Hey Tony,
Yes I read through that but I'd probably rate SA as med - high grip and hence discarded it. Where as the track at Keilor I've heard would probably best describe the track here.... (low grip, hairpins x 4, sweeper x 1). Would you not change anything from SA to Keilor?
thx....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 01-21-2011, 09:11 PM   #14239
I)arkness's Avatar
i can give you a setup i ran this morning at keilor if you want, for an m05? i was running the rides and crosses though so not sure how it would go with the TCS specs tyres!!
pm me your email and ill give you a setup sheet.
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 01-21-2011, 11:50 PM   #14240
caltek1's Avatar
Trader Rating: 36 (100%+)
2-Bad,
I would use the USA TCS winners mini setup from the Tamiya site. I am sure Brandon would not mind. If you need the pdf file then PM me a E-mail address, as I can not post as too large to upload.
caltek1 is offline   Reply With Quote
Old 01-22-2011, 01:14 PM   #14241
Does the M06 pro come with zero degree rear toe hubs? That might be a handling problem out of the box.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 01-22-2011, 01:25 PM   #14242
monkeyracing's Avatar
M-06 has 1.5 degrees built into mounting plate for lower control arms. Supplied uprights are 2 degree. Total out of the box, 3.5 degree.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 01-22-2011, 04:51 PM   #14243
Monkeyracing, thanks. Maybe my friend flipped the hubs left/right and thought the car came with zero degree hubs.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 01-22-2011, 05:43 PM   #14244
over gear's Avatar
Trader Rating: 15 (100%+)
i just got a Manta Ray Ball Diff set for my M05. Which cone washers am I supposed to remove for a stiffer diff action?
over gear is offline   Reply With Quote
Old 01-22-2011, 08:28 PM   #14245
One of the small ones. Careful how much you tighten cause it can get too stiff. I used to do this but no longer do. If you're not a TCS racer, this works fine if you don't have to use the TCS spec tire. Not so great with the Spec tire.
Granpa is offline   Reply With Quote
Old 01-23-2011, 08:17 PM   #14246
SirSwiftAlot's Avatar
Location: SOCAL the fastest mini cooper guys in the nation
M05 For Sale if anyone is interested.
________TAMIYA M05__________
Why do people park in a driveway but then drive in a parkway?
SirSwiftAlot is offline   Reply With Quote
Old 01-23-2011, 08:20 PM   #14247
Originally Posted by caltek1 View Post
2-Bad,
Of course I don't mind. If anyone has questions feel free to ask. PM is easier for me. Got the 06 at the Tamiya track on Sat. Its not where it needs to be yet but I am sure after several more track sessions it should come around. BTW where was that posted its the first I have seen it. I remember doing the interview.
Old 01-23-2011, 08:41 PM   #14248
silvermag's Avatar
hey guys,im trying tofind a lipo battery to fit the m03. that in legan to tamiya rules, does any one know and can post options, thanks.
*axial 2.2 , swx chassis, vw police car body **Do It On All 4's*
$$youtube-k3!-crawl
mo3/swift. if it's not a mini, it's not racing.... i guess?????
super cub
** YA I GOT BIG STUPID TIRES**
silvermag is offline   Reply With Quote
Old 01-23-2011, 10:42 PM   #14249
Ran the M-06 for the first time tonight. (indoors on sticky carpet) Ran it pretty much box stock, including tires. It's a very forgiving ride, compared to the M-04. It doesn't seem to have the outright speed, though.
I used 0 degree uprights on the rear, only used the built in 1.5 degrees. It worked well. Kit tires and spring setup were good. Overall, I like it, especially when compared to the 05.
Jim
Stab it and steer.
Old 01-23-2011, 11:00 PM   #14250
Morbo's Avatar
I keep forgetting. Is the Manta Ray or TA03 ball diff the one to have? Or is it the M05 one?
All humans are vermin in the eyes of Morbo.
Morbo is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
tony gray
