Like Tree22Likes
Old 01-13-2011, 02:33 PM   #14191
RossoTorro's Avatar
Anyone know when the 3racing gear diff is stocked at the online shops?
They have it in parts on 3racing website, cost a little more.
Want it for both M05 and M06.
RossoTorro is offline   Reply With Quote
Old 01-13-2011, 04:19 PM   #14192
Hey guys, I have a couple of questions. First off what is the difference between RC CVA Super Mini Shock Unit (Item #50746) and RC CVA Mini Shock Unit Set II (Item #50519)? Will they both fit an m04? Also what are the dimentions of the blastic bushings in the kit. The best I figured was 5x11x4 (innerDiameter X outerDiameter X width). Thanks!
Losi 8ight
Nitro Rustler
Tamiya M04 - Karz #79
OFFroadrunner is offline   Reply With Quote
Old 01-14-2011, 12:57 AM   #14193
The super mini has a smaller oil reservoir and allows more travel compared to the mini shock unit. Go for the super mini. You can always limit the travel by adding spacers inside and outside the shock.
If you go for the mini shock unit which will have limited amount of travel when installed on the mini and should you actually require the extra travel you would have waisted your money!
Alternatively go for the TRF's or M chassis ali oil shocks.....worth it in the long run!
mr lee is offline   Reply With Quote
Old 01-14-2011, 12:37 PM   #14194
monkeyracing's Avatar
RCMart has them in stock. I'm assuming you mean ball diff rather than gear diff, since 3 Racing doesn't make the latter of the two.
Stab it and steer.
monkeyracing is offline   Reply With Quote
Old 01-14-2011, 12:52 PM   #14195
cannon's Avatar
Trader Rating: 35 (100%+)
The 3 racing gear diff DOESN'T fit in the Mini .... yet. Stay tuned to see if we can get it to fit with some modifications to the gear set
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 01-14-2011, 12:58 PM   #14196
There is a 3 Racing gear diff? What vehicle is it designed for?
Stab it and steer.
Old 01-14-2011, 01:17 PM   #14197
cannon's Avatar
It is designed to fit the Sakura FF .. their FWD car.
It has the 39t tamiya pitch diff. The only issue is it is narrow so would have to be shimmed properly. Also the sealing of the gear diff is level with the gear teeth so it jams the long centre gear of the Mini. Possibly cutting off some of the teeth of the centre gear will allow it to be used. As I said, stand by for further information as we are seeing whether it can be modified now
Old 01-14-2011, 01:30 PM   #14198
Well, that is interesting.
Stab it and steer.
Old 01-15-2011, 08:52 AM   #14199
justchris's Avatar
Hi everyone,
My mo5 after 1-2laps will not track in a straight line
any ideas. Thanks
justchris is offline   Reply With Quote
Old 01-15-2011, 08:59 AM   #14200
M03Racer's Avatar
Trader Rating: 32 (100%+)
Originally Posted by justchris View Post
Hi everyone,
any ideas. Thanks
Do you have a ball diff? is so you might wanna check it.
M03Racer is offline   Reply With Quote
Old 01-15-2011, 09:01 AM   #14201
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
Hi everyone,
any ideas. Thanks
perhaps a part of your steering system has developed some slack? or the steering servo saver is damaged?
Racing is in my blood
Tommi Makkinen is offline   Reply With Quote
Old 01-15-2011, 10:08 AM   #14202
sosidge's Avatar
Hi everyone,
any ideas. Thanks
I don't feel that the M-05 is particularly stable in a straight line with stock steering. M-05 Pro parts are a little better, even more Tamiya blue hop-ups are probably better still!
Because it is happening one or two laps in to a run I wonder whether it has something to do with the balance of the car changing a bit once the tyres come up to temperature, and exposing the straight line problems.
Tell us a little about your setup and track and we might be able to identify the problem.
Old 01-15-2011, 07:44 PM   #14203
Guddam's Avatar
Hi everyone,
any ideas. Thanks
Most m05 handles like crap when new. Mine does. Even with properly built chassis and drivetrain. After a long and frustrating run-in, the chassis handles better and better, and now handles like a dream!!!
Pay attention to the steering linkange, not just the front arm wiper but all the way to the servo saver they need to be smooth....
Guddam is offline   Reply With Quote
Old 01-15-2011, 11:07 PM   #14204
justchris's Avatar
Thank-you all for a really fast reply.
Set-up straight out of the box (its my first build)
Servo spektrum Z590 (Dx3)
Track small concrete floor painted with floor paint.
My only hop-ups are a complete bearing set.
kit tyres, (rubber)
Hope this helps
Do you think i should hop up the steering ?
Last edited by justchris; 01-15-2011 at 11:09 PM. Reason: for got to ask a certain question
Old 01-15-2011, 11:32 PM   #14205
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to AudioStylz
kit tyres, (rubber)
Hope this helps
Are you running the recommended toe out for the front wheels? I've seen guys setup their new mini with out the 1*, 1.5*, or 2* toe out and have tracking issues in the straight. I know, I was 1 of them! I run 1.5* toe out with no problems.
Mike Zadler
Associated TC3 VTA & TC6 USGT
Tamiya M-05
AudioStylz is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
shmit 1
