Like Tree21Likes
Old 12-29-2010, 10:07 AM   #13981
mangoman's Avatar
Originally Posted by COOPER S View Post
I am about to start building my m05 pro kit today. I have a ta03 ball diff to install, this diff looks way different to the one in the kit..Anyone have any links or tips on installing this into m05..
The TA03 ball diff is a direct replacement for the gear diff.
If you put in an M05 ball diff, that is however different. I think there should be instructions on the packet with the m05 diff.
Things to note, the TA03 ball diff comes with out drives because they are different to the outdrves of the gear diff. Loctite the screw through the center of the ball diff. And do it up nice and tight.
You can strip the thread when tightening up, but i do mine up pretty hard i stripped the aluminium part (not the screw) once.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 12-29-2010, 05:03 PM   #13982
jcr
anyone know what is the screw size for the M03 motor heatsink ( 53344 ) ? I think it was 3x27mm?
jcr is offline   Reply With Quote
Old 12-29-2010, 05:21 PM   #13983
Measured mine and it's 3 x 26mm. Also there's only 6mm of threads from the end. The rest is a smooth shank. Don't think it matters whether its like this or threaded all the way up if you need a replacement.
Sydewynder is offline   Reply With Quote
Old 12-29-2010, 05:24 PM   #13984
jcr
Really? only 1mm longer than the original screws?
Found my heatsink but can't find my screws so I'm trying to find replacement. The extra thread doesn't matter.
Old 12-29-2010, 05:29 PM   #13985
Ok it was 26.13mm per my calipers to the bottom of the screw head.
I doubt 1mm longer will be a problem but I would screw them in and hand roll the wheels and listen for scrapping sounds before powering the motor.
Old 12-29-2010, 05:38 PM   #13986
jcr
ok just got confirmation by looking at the M03R manual... it is 3x27mm
Old 12-29-2010, 05:53 PM   #13987
Ok
Old 12-30-2010, 01:41 AM   #13988
Originally Posted by mutley001 View Post
From what I recall it just builds up and fits in - don't think I had to make any modifications when i put mine in - its been in almost a year and still is smooth as silk! Hence why i can't really remember! Just make sure the gear on the diff goes in the correct chassis half to marry up with the gear that turns it - i think it's the right chassis half but don't quote me!
HIH
Paul
Thanks mutley
m05 pro all finished, all went together sweet as.. Just waiting on a body and trf shocks before i can cut some laps.
thanks again
COOPER S is offline   Reply With Quote
Old 12-30-2010, 01:48 AM   #13989
Thanks Mangoman for the advice didn't seem to have any probs..
Hope it holds up, will be headed down to windsor in the new year to test it..
Thanks again
Old 12-30-2010, 05:18 PM   #13990
It's amazing how fun the mini class is. Locally we are getting 30-35+ each race day. We are moving to a permanent track in the next month!
Has anyone put the M03 heatsink on the m05? Does it fit without modification?
I ask because I think when I was in Japan, I saw some racers using this(however they allowed chassis modification there).
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 12-30-2010, 05:53 PM   #13991
caltek1's Avatar
Trader Rating: 33 (100%+)
Yes the Tamiya motor heatsink for the MO3 will fit the MO5, or just use the 3Racing one that has been made for the MO5. The Tamiya heatsink requires no modification, however the 3Racing does require two of the front fins to be filed back if using the Tamiya MO5 alloy knuckles. However if you are racing TCS then I suppose the 3Racing is not legal.
Calvin.
caltek1 is offline   Reply With Quote
Old 12-30-2010, 06:46 PM   #13992
tony gray's Avatar
Finally the rc-mini review of the M06 is online now..
Click HERE to see what we thought of it.
tony gray is offline   Reply With Quote
Old 12-30-2010, 08:15 PM   #13993
Default M01 ???
M01's are often turning up on the local online auction sites at reasonable prices. The M01 's Ive seen seem just as capable as the stock M03/M05
I was thinking, the M01 looks sort of more tub car like, lower COG ??
Are the M01 /02 still a good car, just as a fun racer ??
Even perhaps try & hop it up with M03 dual shocks etc.
1101 is offline   Reply With Quote
Old 12-31-2010, 07:00 AM   #13994
Calvin.
What's the part number for the Tamiya heatsink?
Michael Zufelt
Old 12-31-2010, 07:11 AM   #13995
Thanks for the write up.
The bonus parts do have instructions provided. They are in the back of the manual the same as any other Tamiya kit. It is also the same as the 417 for this info.
4 hours for a car build is nothing. I built my World Championship Mini in about 10 hours(m05) and then still spent time on it after that.
Anyways it is cool to read some info/opinion on the M06 and have those unique pictures.
There should be about 6-8 of them at our next carpet race on Jan 9th!
Michael Zufelt
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
