Tamiya mini cooper
Camber Link
Upper or lower hole? What are most running on the mo5?
Chris- I like the lower camber hole better, but it does traction roll in that position a little easier, and a lot more bump steer in the lower position. The upper position seems to work better later in the day at MMR...
Originally it was thought it would fit but apparently 3 Racing are now saying that it will not fit in the M chassis. If it did fit it would only fit the M05/06 as it needs 15x10 bearings for the diff outdrives
M05 Servo Saver
I got a regular M05, I was wondering which servo saver should I get? The Tamiya one or the Kimbrough? If Kimbrough, which size and do I need to do any mods to it (I know the M03 required a little mod).
Merry christmas to all!
I was told to run the medium Kimbrough as the stock unit was not very good. No mods needed to use it in the MO5.
I'm in need of a battery bracket for a mo3. the l shaped plastic that hold the batt in place. if anyone has a spare, pm me. thanks.
New today
Grandpa this is Eddie,
Look what I am playing with today... did a set up test on my test track and I think its ready for TCS. =)
Have a Merry Christmas and hope Santa brings you a good radio.
Here is my M03 . I just unpacked it from storage . Found out there is a fairly local indoor carpet track that is running a mini class . I just need to get some electonics for it and it is good to go .
even found a brand new mini cooper body set to paint up .
in the pic , it is on touring car foams , I used these in for bashing around with the old body .
I have a order from Hobbyking coming next week . New Lipo charger and battery .
depending on how much i get charged for duty and stuff , i will hopefully be ordering a new 2.4ghz radio system and esc & motor .
