Like Tree81Likes
Old 11-14-2010, 12:20 PM   #13546
pyro18t's Avatar
Originally Posted by gruman28 View Post
Has anyone used the 3 racing aluminum steering rack? Its a lot cheaper than the tamiya, but I know how some of the aftermarket stuff bends easily?
On a side note, some people can't use the 3Racing rack because it doesn't fall in line with TCS rules. Make sure you check with you local track.
Jay
~ Jason Kennedy ~
~ Sweep Racing Tires ~
~ TQ Wire~Wire~
pyro18t is offline   Reply With Quote
Old 11-14-2010, 03:40 PM   #13547
mangoman's Avatar
I was trying to get one for ages, was really hard to get one a little while back.
Ended up using the yeah racing one, which isnt bad. But from what i have seen the 3 racing one is better than the yeah one and really tough like their new knuckles and almost as good as the tamiya one.
With regards to whether the alloy steering rack is better, people kept saying it was a must, a little while back. I got rid of the plastic stuff straight away. But someone was saying the plastic one isnt too bad, but if you hit things then the plastic will warp quickly. Although the nature of the M05 is such that in my opinion even if you are a good driver you will hit things initially while you sort the car out. Generally the best thing is to run a massive amount of toe out on the front M05.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-15-2010, 02:15 AM   #13548
Originally Posted by caltek1 View Post
I suppose it all comes back to what makes you happy. For me the Pro was the way to go, as it was released first. The shocks are the weakest part of the kit and mine are still in there packaging.
Most importantly,(except for the better steering saver..), the pro doesnt have a body($40 there) , still has the horrid tyres, no usefull upgrade like perhaps the steering upgrade , no steering bearings
Bling hubs for the rear only , ????, !!!!
No esc or motor, (could of sold em for some spare cash)
I did get the Pro, made me happy regardless.
Ive sorted my M05 steering issues: torque steer type o thing on full power. Not perfect but much much better now.
Abit more toe out,
run a loose diff (perhaps that why some say the issues goes away after a while, diff getting looser??)
many thanks to all for the advice .
1101 is offline   Reply With Quote
Old 11-15-2010, 02:24 AM   #13549
caltek1's Avatar
Trader Rating: 35 (100%+)
I already had a blinged out MO3R, so it was easy to just combine parts from both to get the MO5 I wanted. Same wheelbase etc made the decision easier for me at the time.
However, I do know beginners need a baseline to start with. A standard MO5 kit is the cheapest way and I have seen some of the better mini drivers run all plastic parts on there cars because they are lighter.
I just get dazzled by the need for bling...
Later,
Calvin
caltek1 is offline   Reply With Quote
Old 11-15-2010, 06:00 PM   #13550
scribbler's Avatar
I was thinking of replacing the plastic cross brace in the steering of my M05 with the graphite one from Tech racing. Does this put stress on any other parts of the steering rack? Do I need to replace other parts?
scribbler is offline   Reply With Quote
Old 11-15-2010, 09:28 PM   #13551
Zac_with_no_K's Avatar
Questions??
Can someone post the parts that break easily that I should stock up on?
Thanks.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 11-15-2010, 10:18 PM   #13552
mangoman's Avatar
Dont know if there are really parts worth buying.
Maybe knuckles ball studs, kingpin screws knuckle (and front suspension for M03). If you are worried about a breakage at a race meet, this might sound stupid but in my opinion you would be better off having a second kit.
www.smaracing.org
Old 11-15-2010, 11:45 PM   #13553
caltek1's Avatar
The only part I have broken on my MO5 Pro is a c hub, which is on the F parts for the MO5. This was from tapping a wall. The rest of the car is resilient, although I have heard of others breaking a front plastic knuckle.
The diff outdrives are the only other parts that wear.
Later,
Calvin.
Old 11-16-2010, 12:03 AM   #13554
I have found that the alloy steering parts bend and stay bent.
Whereas the plastic bits flex and return.
Also a slight bend in the alloy rack for example, could cause erratic ackermann settings and be difficult to notice.
I have only broken one plastic steering block, bent/broken cv shafts.
My car has had some epic barrier crashes, these cars are tough !
I recommend buying a full kit for spares, they're so cheap that way !!
MICHAEL BROWN is offline   Reply With Quote
Old 11-16-2010, 12:18 AM   #13555
Calvin
Bling is nice, allways fell better/go faster with a sexy looking car
2nd M05 I bought was the std M05 kit
std kit for racing
M05Pro + 9T brushless just for fun.
Its a vicious cycle once you start buying RC bling upgrades. Seen some TT01's that had $700(yes, thats $NZ1000) spent on them- garrrh.
Old 11-16-2010, 08:32 AM   #13556
mangoman's Avatar
Yes alloy does bend, especially the really cheap ones. I have had a yeah racing ones, and generally speaking they have been tough. It's been driven at windsor too, so i can guarantee you its had some really big hits.
As i stated before the 3racing ones are really good but tamiya would have to be the best.
People swear by the tamiya knuckles and i have to say the ones ive got from my pro kit have been great for ages. Ive also had the current 3racing knuckles and they seem really tough and I havent had problems with them. I even bought a whole bunch of them expecting them to bend but havent had to swap them out.
Also i think you probably need to take into account that a mini with the speeds and style of driving arent particularly fussy about a touch of tweak.
www.smaracing.org
Old 11-16-2010, 09:58 AM   #13557
duneland's Avatar
Anyone know where to get M-class foam tires? Preferably in the states..
duneland is offline   Reply With Quote
Old 11-16-2010, 10:29 AM   #13558
hairy's Avatar
Default Mo5 pro
Personally I have a M05 Pro and race it quite often and have yet to break a part. Mine is set up for TCS rule racing and I love it!
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 11-16-2010, 01:21 PM   #13559
Chassis ..... broken 2 of them in the last 3 weeks
1st was where the stearing system screws in one crash and it destoyed the screw hole
2nd was where to front upper arm screws to the chassis snapped it clean off the new 1 week old chassis
just unlucky i think (hope)
sidecarphil1 is offline   Reply With Quote
Old 11-16-2010, 05:48 PM   #13560
trerc's Avatar
Trader Rating: 89 (100%+)
Ditto for me with the mo3, I find keeping it off the boards helps.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
