Like Tree168Likes
Old 11-11-2010, 04:38 PM   #13516
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by scribbler View Post
What do you mean by power cap? The capicitor that comes with most Tekin products, or another part? And, does tekin provide this part with the Speedo, or do I have to find somebody who does?
I believe this is by Spectrum. The use of a "stutter stopper" capacitor will ensure the BEC voltage is kept as high as possible through the infield where servo movement and current consumption is at it's peak.
gashuffer is offline   Reply With Quote
Old 11-12-2010, 01:04 AM   #13517
What this actually does it filters out all the hash caused by el cheapo servo's. I scoped it up when I was having RX issues on my Spektrum. Changing to Futaba/Savox servo's actually eliminated the need for the addon RX cap.
The voltage range for the SR3000 is 3.2v- 9.6V, I doubt the BEC voltage will drop to 3v.
1101 is offline   Reply With Quote
Old 11-12-2010, 01:58 AM   #13518
gashuffer's Avatar
This was what the f1 guys are using to run the B1 in their cars. Without it the esc would fry.
Old 11-13-2010, 06:25 AM   #13519
scribbler's Avatar
Thanks for the advice, I'll let you know what the end result is, if I decide to put this combo in my mini. I'm still a little hesitant about seeing if this will work in a mini (Tekin B1, silver can combo). It should work, but F1's are half the weight of mini's
scribbler is offline   Reply With Quote
Old 11-13-2010, 07:50 AM   #13520
RossoTorro's Avatar
Try it, it's only $40....
And be done with it, no need to go on for pages on this!
I tested 1/18th esc ezrun 18A with 13T/3000kv and it worked.
Got a little hot but worked well enough.
RossoTorro is offline   Reply With Quote
Old 11-13-2010, 09:02 AM   #13521
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Originally Posted by jcr View Post
I guess how do you make it balance since it is heavier on the motor side.... add all the weight onto the other side?
call it luck or whatever, i had never really tried to perfectly balance these cars. Weight is all around the centreline, and if you want, some offsetting the motor. In the m03, i have a huge chunk in the rear pod, stuck against the bottom. I run my GTX on top above the battery, with the reciever next to it. With the M05, i added alot around the electronics opening, opposite the motor side. Also i added some over the battery, opposite side to the motor. Ive never tried to balance them with balance spikes, i bet they are still way off, but ive found with a nice chunk of weight, you get the suspension working for you, instead of poggoing.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 11-13-2010, 11:14 AM   #13522
Hi guys, need some help with my m03
Went racing for the first time with the mini since the national champs a couple years ago, first time i ran it since last year, i dont know what happend, but it wouldnt corner, i would turn, and the rear end would just spin round on it, if i slowed down i could roll through it and then get on the power, but it would also roll over when spinning out,
the track surface was astroturf, at an indoor sports centre, but here in nz we cant use any hopups or anything, so its basic kit m03, the only thing we can do is sway bars and bearings,
any help would be cool
cheers
craig
kiwif103racer is offline   Reply With Quote
Old 11-13-2010, 01:42 PM   #13523
cheers
craig
are you running a lipo ??
try adding some weight to the rear of the car , cut 1 coil off each of the springs and add 100,000 shock oil inside the stock plastic shocks
The car that won our 6 uurs race was running kit shocks
sidecarphil1 is offline   Reply With Quote
Old 11-13-2010, 01:44 PM   #13524
nope ,not running a lipo, cant afford one yet, haha, i would cut the coils, and add the oil, but thats illegal here, cause this is a basic class, build and race effectivly,
Old 11-13-2010, 01:56 PM   #13525
caltek1's Avatar
Trader Rating: 36 (100%+)
Thumbs up
kiwif103racer,
Very hard to second guess the cause to your cars woes. However did you fit new tyres prior to racing. If not they maybe your problem. Try changing to a new rubber front and back. What is your ride height? Are you running TRF shocks, super mini cva's or kit shocks. A rebuild on these with fresh oil may assist with tuning and handling.
I would also check to see if the suspension is binding and your drive chain is free.
Other than that go here and have a read, see if this helps:
http://www.rc-mini.net/joomla/index.php
Should give you some ideas to try.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 11-13-2010, 02:24 PM   #13526
hairy's Avatar
cheers
craig
It has been my experience that when this happens..your front suspension is way too soft. Your front end has more traction than your rear and so it is digging in in the turn and locking up the car.Try harder springs on the front and if you have oil filled shocks try a firmer oil.
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 11-13-2010, 02:26 PM   #13527
mangoman's Avatar
If you can only run standard kit, i assume that means you are running a gear diff in the front which cant be modified?
I think that is pretty typical of driving a mini with a free gear diff, in that you will need to drive the car pretty smooth through the corner.
However, if the tyres havent been raced in a while you may want to run your rear tyres on the front to scrub them in a bit then swap them back to the rear to see if they come good.
I raced on astro turf once, we were mainly using M Grips, Kit Tyres and HPi x-patterns (xpatterns only on the front). However, these days on carpet we have been using x-press tyres on the rear (dont use x-press rims though, they seem to shatter pretty easy around the edges).
Like sidecarphil1 said, i would probably also try experimenting with weight, although not really sure where to put it. Although i would keep it around the center line of the car and low down. So i guess on in the inside of the actual chassis in the rear.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-13-2010, 03:07 PM   #13528
caltek1's Avatar
Martin,
I don't think weight is the issue, as Craig isin't using a Lipo.
Craig,
Are you restricted to using only Tamiya tyres if not then try as Martin suggested the Express mini tyres on the rear and some worn Tamiya M grips on the front or HPI x patterns.
I would also soften the rear suspension to give back some rear grip and check your radio settings so that your steering rate is slowed down to make the car change direction smoothly.
Hope some of these suggestions assist with fixing your car problems. Remember just do one thing at a time and see what effect it has on the handling.
Regards,
Calvin.
Old 11-13-2010, 05:22 PM   #13529
silvermag's Avatar
hey guys, i have a bit of a problem with mini rules and motors, i are running silver can only in our club, so i went and got a 540 motor. when i went home and installed the motor i realized that its a goldish color instead of a silver color like my other one, i looked on tamiya site and all the motors that they list are marked with decals and major writing, is it a standard motor or not or did they change thinks up on the motors, its closed bell like the original. thanks guys.
*axial 2.2 , swx chassis, vw police car body **Do It On All 4's*
$$youtube-k3!-crawl
mo3/swift. if it's not a mini, it's not racing.... i guess?????
super cub
** YA I GOT BIG STUPID TIRES**
silvermag is offline   Reply With Quote
Old 11-13-2010, 05:45 PM   #13530
Misiek's Avatar
Default is it worth to get M05 pro instead of M05
I want to get into mini cooper racing and would like to know if its worth to pay extra for M05 pro, or should I get M05 and upgrade as I go?
Thanks,
M
Misiek is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
