Like Tree2Likes
Old 11-10-2010, 04:47 AM   #13486
Barry White's Avatar
Tech CF-R
Barry White is offline   Reply With Quote
Old 11-10-2010, 06:59 AM   #13487
Hello. Sorry for my English. I wanted to ask you if you know how to tell a brushless motor in the picture. The EnRoute not do that. I'm building two twin-engined prototypes, one based on an M02 and a XEvo with my frame. Thanks.
i51.tinypic.com/2mrwoxf.png
alfettone77 is offline   Reply With Quote
Old 11-10-2010, 09:25 AM   #13488
jcr
Hopefully someone can share some insight. My club races spec mini (no upgrades besides tires and bearings).
Last year I ran the M03-M with ok success using the Xpress mini rubbers all around or sometimes S-Grip front and M-Grip rear. I just got a M05 setup for medium wheelbase, I was wondering how different is the M05 to M03? Could I use the same tire combo or do I need more front grip?
jcr is offline   Reply With Quote
Old 11-10-2010, 09:42 AM   #13489
SteveM's Avatar
Trader Rating: 126 (100%+)
I was running my M-03 up until just recently and switched to the M-05 as I was getting beaten badly. I ran the medium wheel base M-03 and have my M-05 also set to medium. The tires that seem to work best indoors on carpet are the type B slicks on front with S-grip on the rear.
SteveM is offline   Reply With Quote
Old 11-10-2010, 10:07 AM   #13490
jcr
ok cool so it looks like still more front grip is required.
Old 11-10-2010, 10:16 AM   #13491
tiko's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to tiko
Originally Posted by Barry White View Post
Tech CF-R
Who carries that chassis and where can I get one for the M-05.
LionArtPrints - Custom Apparel, Hats, PitMats, RC Car Bags, and More
LionArtPrints - On Facebook
tiko is offline   Reply With Quote
Old 11-10-2010, 12:08 PM   #13492
tony gray's Avatar
It's not a 'chassis' as such, it's pretty much a complete car... Ref HERE
tony gray is offline   Reply With Quote
Old 11-10-2010, 01:24 PM   #13493
scribbler's Avatar
Originally Posted by tudor_47 View Post
I broke both rear lower arms on mine. OK the car is not meant to roll over and bounce on its rear... The things that broke were the attachment points for the rear dampers, the screws are very short so very little thread goes into the plastic. I must see if I can replace the screws with longer ones. I use the 3racing dampers.
I ordered new plastic onepiece units from rcmart.
I could not find the lower arms in Aluminium are they still available?
I ordered alu uprights for the rear at the same time as mine looked suspicious with a very large toe in on one side compared to the ohter side.
The best aluminum arms are from a company called Eagle Racing. The only place I was able to find them was through Integy. They're the distributor in North America, I believe.
All the Square products for Mini are really durable. They can be purchased through eBay. They provide multiply degree toe in uprights for the rear end.
I built the ultimate aluminum mini. Hundreds of dollars later I discovered that really the most durable parts are the plastic Tamiya ones...
scribbler is offline   Reply With Quote
Old 11-10-2010, 01:58 PM   #13494
tony gray's Avatar
Finally....someone gets it...
Old 11-10-2010, 02:05 PM   #13495
LOL my M05 is quite alloyed up
but it is no faster then a stock one
I just like it
sidecarphil1 is offline   Reply With Quote
Old 11-10-2010, 02:08 PM   #13496
gashuffer's Avatar
Trader Rating: 48 (100%+)
Blingidy bling bling
gashuffer is offline   Reply With Quote
Old 11-10-2010, 04:09 PM   #13497
Why would you do that???? The M03 is the better car unless you are running on carpet or ultra high grip surfaces.
Granpa is offline   Reply With Quote
Old 11-10-2010, 04:16 PM   #13498
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Well IMHO, all minis are extremely equal, it boils down to the correct adjustments on each. M03/5 is very equal in my eyes, i can make both do exactly what i want. Changing the combination of tires springs bodies and sauce (carpet) can make either of these two fly. The wild card is the 04. i found that the RWD is tougher to get the win. IMHO whether it be high grip low grip etc, i still always run type A rear, S grips up front, CA glue on outer tread of the S grips, grey foam insert in both front and rear tires. If found the amount of tire sauce on the S grips can dramatically change the amount of steering. I normall run yellow front springs and red rear, and this past weekend i had to change to red fronts, because the rear was so planted, it wouldnt steer as tight as i wanted! needed the weight transfer. I LOVE the CA on the edge, i can sauce the entire front, get a tonne of grip, and the CA protects me from roll overs.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 11-10-2010, 05:36 PM   #13499
scribbler's Avatar
I was debate putting the Tekin B1 in my mini. currently at RCMart they're only $40. Does anybody have experience using this speed controller.
Tekin's customer service says this product will work in this application, but I'd like the opinion of someone who's attempted this. I question the long term durability of this ESC (Tekin B1) in this application as its primary use is for 380 brushed motors.
PLease let me know your opinion!
Thanks in advance
Old 11-10-2010, 06:39 PM   #13500
jcr
Is it me or is the M05 a lot heavier than the M03? Like 50grams heavier.... might suck to race spec class with it now.... but then again both cars were fast last season
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
