Like Tree81Likes
Old 11-03-2010, 01:42 PM   #13411
Send a message via AIM to Waco
Whilst I secreted the Xevo name into my last post, I have picked one up 2nd hand & whilst I understand that the manual is of little use, does anyone have a copy that I could see (as it didn't come with one, as you may have gathered from the request) as the front lay down shock set-up looks quite tricky...
Also, I have bought the 3Racing gear set & I have also heard that they make quite a racket & can wear out quickly if used with Tamiya pinions... If that's true are there any quick/ reliable fixes?
Waco is offline   Reply With Quote
Old 11-04-2010, 10:10 AM   #13412
mutley001's Avatar
Default Motor Balance weight
Originally Posted by rcnutbag View Post
For some time now I've seen all manner of balancing tips and techniques for our Minis. The one thing that has always foiled me is the ever present weight of the motor hanging out one side of the chassis. There is NO DOUBT that this imbalance works against us when we're negotiating the tricky curves at our local track.
So, recently, before a local championship race I designed a counterbalance. The pics and results (I won the c'ship) speak for themselves. All I'll add to this is that the car tracked as never before and it was visibly faster through the areas that normally would trip my car up.
The weight is placed exactly where it's needed most - along the same axis as the motor.
Anyway, if anyone out there is interested, I can produce these. I've done the hard work in nutting out the correct weight and shape, so it couldn't be easier.
I need about 100 or so people to kick me off and the price will be AUD35 plus postage. They will be created on a CNC lathe and will look a lot tricker than my prototype. I will post pretty much anywhere in the world (we are all big mini fans after all!) and the price you see on the package is what I'll add to the base cost.
I can't see any reason why this wouldn't be legal; it's just a weight after all, and you aren't drilling any new holes or modifying the chassis in any way.
A few points: the weight is designed for an M05 with a Hobbywing Brushless motor only. It can be adopted for silver or black cans, and if the orders come in, I see no reason not to be able to cater for those setups as well.
Again, PM me if you want one, otherwise, enjoy creating your own!
Just wanted to post here to express my thanks to rcnutbag for coming up with this idea. I got a counterweight from him and it made such a difference to the handling of my car it was amazing - stopped griproll in sweeping right handers, hooking in slow right handers, carries much more cornerspeed in corners and allows better braking due to the extra weight over the front axels and has improved my mini no end. Get it patented quick!
Cheers matey - great item - just need to annodise it blue.........
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 11-04-2010, 11:29 AM   #13413
academygaz's Avatar
Tech Racing CF-R....the car the M05TRF could have been?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 11-04-2010, 12:15 PM   #13414
tony gray's Avatar
And the price? Around about $300 USD and you still need some M05 bits to finish it off.....
It does do 210mm and 225mm WB but no 240mm.
And you cant readily dismiss anything from Tech Racing. Pretty much every Touring Car on the market now is descended from the 415, which itself was originally a Tech Racing product called the MY02...
tony gray is offline   Reply With Quote
Old 11-04-2010, 01:55 PM   #13415
over gear's Avatar
Trader Rating: 15 (100%+)
over gear is offline   Reply With Quote
Old 11-04-2010, 07:20 PM   #13416
J-milz's Avatar
Trader Rating: 37 (100%+)
Quick question about racing the mini Cooper m05. I race in a local beach series using TCS rules. The motor is a spec 540 J motor. My question is will the Tekin B1R /18 esc in forward only be suitable to use in this application.
💫XRAY addict💫 sponsored by the secret stash.....tee-hee-hee.
J-milz is offline   Reply With Quote
Old 11-04-2010, 07:23 PM   #13417
bukil's Avatar
What shock length do you guys normally set these mini-coopers?
Thanks in advance
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 11-04-2010, 07:39 PM   #13418
J-VET's Avatar
Thanks in advance
You should go with 1/8th truggy shocks, don't worry if they don't fit. This set up works best with no springs and elmors glue for shock oil. Also make sure you drive in reverse with only one dog bone and three wheels. This will help it will corner better.
I hope this helps Mark.
J-VET is offline   Reply With Quote
Old 11-04-2010, 07:46 PM   #13419
bukil's Avatar
LOL Taking competition out that way huh. hahahahahaha
These minicoopers like longer shock lengths. It seems to work good with more shocks play = damping? I don't know the terminology for it.
☆ ActivRC ☆
Old 11-04-2010, 08:12 PM   #13420
J-VET's Avatar
My mini does seem to work better with some ground clearance/travel. I remember reading about this topic when I was on here a couple of weeks ago. Check back a few pages and I'm sure you will find a propper answer if nobody chimes in.
Old 11-04-2010, 08:20 PM   #13421
hairy's Avatar
Originally Posted by cannon View Post
What is the difference between these two pics?
The car on the right has the rear end lowered
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 11-05-2010, 06:42 AM   #13422
On-Road-Boy's Avatar
Hey guys, Could i use my shocks off my tc?
Thanks George
Sakura XI HobbyWing-Spektrum-Savox
Sakura F113 HobbyWing-Spektrum-Savox-Venom
Team Pink
On-Road-Boy is offline   Reply With Quote
Old 11-05-2010, 06:57 AM   #13423
Butler205's Avatar
You can, but the bodies are longer, so you have to put spacers under the piston to get the mini to a decent ride height.
M05 Racer(retired) FF03 Racer - Brushless Hyper 7 Basher
Butler205 is offline   Reply With Quote
Old 11-05-2010, 02:42 PM   #13424
tony gray's Avatar
And you end up with a shorter stroke travel overall because of it (minimal up travel)
It's ok short term, but I wouldn't want to do it all the time.
However, if you're on a budget and just playing around, then its quite do-able.
Old 11-05-2010, 04:43 PM   #13425
Paul
Wow,
Thanks Paul!! Glad it made a difference (but I knew it would ).
Oh, and stay tuned for the patent...
balance.rc.products@gmail.com
rcnutbag is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
rccartips
