Like Tree1Likes
Old 10-30-2010, 07:17 AM   #13381
caltek1's Avatar
Trader Rating: 33 (100%+)
Julius,
I use anti-wear grease on the splines to assist with remaining in the diff drives. I have stripped my fair share of TAO3 ball diff splines I now use a short length of fuel tube in place of the "o" ring. You just have to ensure you get no binding from the universal/dogbone when the suspension is altered. (Thanks Grandpa, for the Top Tip).
Michael,
We found today that the spool is not as fast at SMA as the gear diff or the ball diff. Great acceleration as you stated, however you lose to much corner speed.
Tyres and car setup also play a huge role in how fast you can be, especally when you factor in the drivers input.
However, I believe that a solution to the diff problem maybe only a couple of months away max. Can not say more.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Old 10-30-2010, 01:46 PM   #13382
Originally Posted by caltek1 View Post
Julius,
Michael,
Later,
Calvin.
Hi Calvin,
Thanks for the info, I hope you had a great day's racing...
Will you be mini racing this friday night ?? If you are, i'll push to get there.
That would make for a decent 4/5 car battle for TQ !!!
Your little teaser sounds interesting, I wonder if it is along the lines of what i'm working on at the moment for my M-05 ??
Michael.
MICHAEL BROWN is offline   Reply With Quote
Old 10-30-2010, 02:57 PM   #13383
TraxxasPeter's Avatar
Trader Rating: 21 (100%+)
ok im new to the on road scene. im getting a m03. any tips?
Peter Kren
Losi 810
Associated RC8E
Gilligans Raceway
Island Raceway in Lindenhurst, NY
TraxxasPeter is offline   Reply With Quote
Old 10-30-2010, 03:23 PM   #13384
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
buy my car, save cash and have it ready race w/all the trick bits on it now instead of buyin upgrades as you hear about them or they finish in front of you in the 1st couple wks.
and if not my car, i suggest highly buyin some1s old TCS ride...much better way to go indeed and less $$$$. they are tricky lil things w/their own nuances, why not let some1 else take the headaches for you.
R
UltegraSTI is offline   Reply With Quote
Old 10-30-2010, 04:28 PM   #13385
R
im trading for one
Peter Kren
Losi 810
Associated RC8E
Gilligans Raceway
Old 10-31-2010, 07:44 AM   #13386
tudor_47's Avatar
Originally Posted by 1101 View Post
ebay (seriously)
hobbyking had them for $29, you can get them to email when back in stock
I do not know how or why I forgot to check ebay..?
i have now a motor coming from an ebay dealer... and it was very reasonable priced too.
SO thansk! very good and practical tip!
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 10-31-2010, 05:54 PM   #13387
Default M-03M Question
Hi. I ran an M-05 but still interested in getting an M03. My question is: Is it easy to convert an M-03M to the short version by simply not installing or removing the plastic insert that goes with it? Or do I have to purchase another part for me to do so. I want to run the old Mini Cooper body with it which I think is only for the short chassis. Thanks for any info guys. Edwin
efm2 is offline   Reply With Quote
Old 10-31-2010, 05:55 PM   #13388
jcr
you just need to remove the chassis spacer and that's it
jcr is offline   Reply With Quote
Old 10-31-2010, 05:57 PM   #13389
Thanks for the reply jcr. Much appreciated
Old 10-31-2010, 11:07 PM   #13390
Well, after years of running M03s, I have finally put my first M05 together. It's all bearings and has Tamiya aluminum steering link 54192. It runs great and the steering is dead on. I couldn't be happier with it, BUT, the black can motor is pretty lazy.
So tonight I ordered the Hobbywing 35a 13t motor/ESC combo from Hong Kong after doing some research in this thread. You guys are a big help on here. Not sure how long it will take to get here (I'm in California).
Anyway, my question is.... It looks like the shaft is longer on the Hobbywing motor than on the Sport Tuned... Will I have to do some chassis modding to accommodate the longer shaft? And one more... Is the fan for the ESC really necessary? Temps in this part of California can easily get over 100f in the summer.
Thanks in advance.
BlackMini is offline   Reply With Quote
Old 10-31-2010, 11:32 PM   #13391
Thanks in advance.
Black mini,
Nope no mods required, the Hobbywing motor fits straight in. Just make sure you use the pinion mounting thingy that comes with the kit.
ARC R10 2013
Wylie27 is offline   Reply With Quote
Old 11-01-2010, 06:04 AM   #13392
Thanks in advance.
I run mine without a fan. Simply not enough load on the motor to warrant it (in a mini). Out here in the Wild West , summer gets a lot hotter than that . That's < 38* C. So you're pretty safe to leave it off.
I've heard of guys running their speedy inside the rear chassis extension on the m03.
Old 11-01-2010, 06:25 AM   #13393
Peter $'s Avatar
I do that - and there isn't room for the fan, so I took it off. I have no heat problems at all, even when I drive for 20 mins and have installed the 3Racing fast gear set (indoor on carpet with wide foam tires).
Cheers,
Peter
Peter $ is offline   Reply With Quote
Old 11-01-2010, 06:56 AM   #13394
Cheers,
Peter
Thanks for the pic - exactly what I meant !
Old 11-02-2010, 09:15 AM   #13395
bodymot's Avatar
Default Tam M05 ball diff, 54194
What are your views on Tamiya M05 ball diff 54194, is it ok with out mods, or do you need to change some of the parts. Only ever used gear diff so far, but clubs I race at in UK now allow ball diff’s. Have a 3-racing ball diff as well but waiting for mod parts before I use it.
thank you in advance
Ben
TC .UK. Tamiya M05, X-ray T3-09, GM Genius 120, MAMBA MAX PRO.
Member of T.M.F.F.R
bodymot is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 05:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-02-2011 12:08 AM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 09:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 07:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 08:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
