Tamiya mini cooper
#1321
Trader Rating: 31 (100%+)
that's prolly the best out of the way spot to put it, and safe.
#1322
More info on the new M03-M. Looks like only 3 new things are different from the M03 that we have now.
#1323
1. Extension looks in between M-03 and M-03L; some handling implications here.
2 & 3. The new front and rear uprights look thinner, that they say is weight savings, but I'm sure that is negligable; and for many of us the beefier plastic still warps so we got the aluminum front uprights, thinner sounds worse. You can already get bearings and 2 degree toe in so this doesn't look any different here.
Doesn't sound like the M-03M suspension is going to obsolete the other M-03's; just a mid-preference wheel base packaged with 1/2 the bearings we need. Nice looking though.
#1324
#1327
mini
Originally Posted by racenut
I agree its nothing but a bling-bling. the alum clamp type(fiined) heatsink is much better.
#1328
mini
Originally Posted by asw7576
How is the feeling when using solid axle ?
I'm thinking to use solid axle to minimise wheel spin.
Answer for your question about 22t pinion ? I think it's not possible, max. is 21t ( after the spur gear is worn out ). As everybody know this is illegal for TCS / TAC .
using solid axle = no diff action, where ever & when ever u squeeze the throttle, forward power is out from those front tyres, no slip. the neg effect is just a very little bit under steer, so now depend on your throtlle control. but for me ....solid axle is magnificent!!!
just try it...
#1329
Originally Posted by t4m1y4niac
thanks for answer.in my place, no rules for mini racing..it's out law..except in race that provide by Tamiya Indonesia.
just try it...
just try it...
Tamiya did make the solid axle for gear diff case..
Check this pic.
#1330
Lock your diff
The G-parts from the VW Touareg has two plastic pieces that replace the spider gears to lock the rear diff. They are on Tamiya part number 9005422 and should be available from Tamiya.
http://www.tamiyausa.com/product/ite...uct-id=9005422
Its nice that it is a reversable mod. But I don't think that it is TCS legal. Take a look at the exploded view of the Touareg and you can see them as G-5 near the rear diff.
http://www.tamiyausa.com/pdf/58324e.pdf
#1331
Originally Posted by tunnelhead
Cant wait to see it. Customworksking. you dont have a line on a used , but in excellent condition Custom Works Aggressor, do you? They are very hard to find used. Looks like you guys dont give them up after you bought them. Thanks . Phil
www.fastlapslo.com
www.fastlapslo.com
#1333
Guys,
Anyone here knows the part # for the extension piece for the M03-M yet. Got my RS4 mini Honda Civic bodies today and can't wait until end of the month.
#1334
Guys,
#1335
Guys,
From what I can tell it isn't going to be availible till the end or march
