Like Tree23Likes
Old 10-17-2010, 09:53 PM   #13306
tony gray's Avatar
The 05 Files Pt II.
online now on rc-mini HERE
tony gray is offline   Reply With Quote
Old 10-18-2010, 12:41 PM   #13307
tony gray's Avatar
All new M06 Pro pics, straight from the Japan show. Exclusive to rc-mini!
Go HERE to see them all
Old 10-18-2010, 12:47 PM   #13308
MD
MD's Avatar
Trader Rating: 106 (100%+)
M06
MD is offline   Reply With Quote
Old 10-19-2010, 06:20 AM   #13309
Given the lack of interest in the M-04 (I actually own two and love them) I cannot see the M-06 being popular.
However, the M-06 though appears to have addressed the weight distribution problems of the M-04 so who knows.
I'm a Tamiyaholic so I'll be getting one regardless.
TB-03, M-03, M-04,M-05, TT-01, DF-03ra, TRF201, SCX10, Stampede
tdunster is offline   Reply With Quote
Old 10-20-2010, 05:56 AM   #13310
Default m05 ball diff instructions
does anyone have the instructions for assembly for an m05 ball diff? I've searched with no luck.
I have also seemed to have shattered the thrust bearing. Are these available separately?
LOWPAO is offline   Reply With Quote
Old 10-20-2010, 11:15 AM   #13311
over gear's Avatar
Trader Rating: 15 (100%+)
speedtechrc http://www.speedtechrc.com/store/ebp...il.asp?id=7734
over gear is offline   Reply With Quote
Old 10-20-2010, 12:12 PM   #13312
Hi!
I'm sure it's not that complicated. It would go:
diff screw - thrust bearing - actual diff with bearing et. al. - diff spring - nut
can't post pics yet..
try downloading some instruction manual from tamiyausa and just replace the ring gear or the pulley in the ball diff assembly.
Hope this helps.
www.dubdrift.com
Tamiya M-05 ~ Tamiya Volac MS
3Racing Sakura Zero ~ HobbyWing 60A/13T Motor
laNcE_08 is offline   Reply With Quote
Old 10-20-2010, 05:53 PM   #13313
RossoTorro's Avatar
It's not Tamiya's M05 diff, but it builds the same except this has 12x 2.4mm diff balls and Tamiya use 8x 3mm diff balls...
Massive picture.
RossoTorro is offline   Reply With Quote
Old 10-21-2010, 05:47 AM   #13314
Apparently this is a known problem with the 05 ball diff and some have now reverted back to the 03 diff.
In our TC finals my car just slowed right down and then towards the end of the race seemed to speed up. I had this happen before when the tyre jumped off the rim and was wearing on the steering hub. This time it was the diff.........it tightens up when turned in one direction and loosens in the opossite!
mr lee is offline   Reply With Quote
Old 10-21-2010, 09:42 PM   #13315
J-VET's Avatar
I run the M05 diff with the 416 screw and lock tight on the nut. Haven't had any issues.
J-VET is offline   Reply With Quote
Old 10-22-2010, 12:48 AM   #13316
Does the 416 screw have a bigger head hence it does not cause it to crush as easily?
Old 10-22-2010, 12:59 AM   #13317
use the TRF thrust bearing , screw and nut , problem fixed !!
sidecarphil1 is offline   Reply With Quote
Old 10-22-2010, 07:25 AM   #13318
silvermag's Avatar
well i gave up on the ball diffs, after replacing 3 and not racing that much i decided to glue the original set together, she corners a little hard and wears the hell out of tires but i sure pulls out of a corner, have no problems now.
*axial 2.2 , swx chassis, vw police car body **Do It On All 4's*
$$youtube-k3!-crawl
mo3/swift. if it's not a mini, it's not racing.... i guess?????
super cub
** YA I GOT BIG STUPID TIRES**
silvermag is offline   Reply With Quote
Old 10-22-2010, 07:48 AM   #13319
Thanks for everyones help. Parts are on the way. Also gonna try the ta03 diff as well as the manta ray.
Old 10-22-2010, 07:51 AM   #13320
My M-05 steering is still not centering after I turn left.
I replaced the standard steering rod / link to the servo with Tamiya's aluminium version (part#54195) but the problem still exists.
The same problem is mentioned on rc-mini.net but no explantion or solution is provided.
The servo is working fine, the tie-rods appear fine - I have even swapped them over to opposite sides and nothing changes.
Also, the car requires almost maximum trim to the left to get it to track straight if that's any help.
M-03 > M-05.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
dmcguire, Set, shmit 1
