Like Tree163Likes
Old 10-13-2010, 02:09 PM   #13276
Originally Posted by tdunster View Post
BILKO1,
I have the HW Brushless 13T/35a combo and 20t pinion .
Motor using 15 degrees advance timing.
Ran laps for 20mins (ambient temp 80f) at race speed no heat problems.
EDIT: I've also run the 9t combo with the same positive results.
I'd be checking the meshing if heats an issue.
Alternatively, if you have signifcant tyre wear the car may be approaching the point whereby it becomes undergeared - but unlikely.
robl08,
The chassis configuration (short / long /medium) is about as insignificant as the type of oil used in the shocks (A tourer is another thing altogether though).
Tyres are what determines success with the Tamiya Mini.
Use the wrong tyre combination and you can traction roll any of the three configurations with ease. Get the tyre selection right and all of them will perform great.
cheers
We run a control tyre here called SPC-UK they are slightly smaller diameter than the Tamiya standards ones. 55mm instead of 60mm. What pitch are the pinions is it .6 mod?
Zen RSGT, Trinity, Hobbywing, LRP.
M05 S-Spec, LRP, Intellect.
M05 v2 Tekin, Orion, Savox.
B44 Mamba Max, Trakpower.
B44.2 Avid chassis, Speed Passion, Gens Ace.
BILKO1 is offline   Reply With Quote
Old 10-13-2010, 09:51 PM   #13277
I use the standard Tamiya 20t that comes in the m-03 and m-05 kits and have not had any failures so far.
Tamiya Part #50356
I have not tried the RC 0.6 Alum Pinion Gear - Hard Fluorine Coated 20T
Tamiya Part #53059
cheers
TB-03, M-03, M-04,M-05, TT-01, DF-03ra, TRF201, SCX10, Stampede
tdunster is offline   Reply With Quote
Old 10-13-2010, 10:27 PM   #13278
RossoTorro's Avatar
Tamiya Part #50356
Tamiya Part #53059
cheers
I use the #53059 on mine, has lasted 2 years with no wear. Changed a couple of gearsets on the M03 and one on the M05.
RossoTorro is offline   Reply With Quote
Old 10-14-2010, 05:03 AM   #13279
Default First parts off the line
Thanks to all that have ordered the M05 counterbalance!
The first production units Tamiya mini cooper-dscf3988.jpg will be rolling off the line tomorrow and all of you very patient people will be getting yours sent to you in the next few days.
I look forward to the feedback!
rcnutbag is offline   Reply With Quote
Old 10-14-2010, 09:28 PM   #13280
mugler's Avatar
has anyone else used these on their cars. i used it on my M-03 and the top end speed seem to go away. haven't had a chance to take the car apart properly and look for other issues but the car was just fine before installing these with regular CVD's:
http://www.egrracing.com/shop/cv-uni...es-p-3696.html
mugler is offline   Reply With Quote
Old 10-14-2010, 11:30 PM   #13281
Apart from lessening chattering when at full lock, Universals provide little if any other benefits in an m-chassis.
As far as slowing down the car all I can think of is that you might have gone overboard on the grease or perhaps over-tightened a wheel nut ?
Otherwise - I got nothing.
cheers.
Old 10-14-2010, 11:46 PM   #13282
Trader Rating: 22 (100%+)
When you tightened up the wheel nuts it may have put excessive side load on the wheel bearings. All axle to the drive pin behind the wheel hex are of slight difference in length.
I use 5mm spacers between the bearings as a squish tube so as you can really tighten up the wheels without putting to much side load on the wheel bearings.
As for the axles in higher grip they tend to not last all that long. The pins break and then they destroy themselves under rotation after the pin breaks.
bjspinner is offline   Reply With Quote
Old 10-15-2010, 12:05 AM   #13283
mugler's Avatar
Thanks for inputs ,yea I'm developing a feeling it's nut tightening issues. This unit comes with it's own inner knuckle bearing with a thinner width which is kinda curious as well.
Old 10-15-2010, 01:25 AM   #13284
RevMaxx's Avatar
Send a message via MSN to RevMaxx
a teaser for the new M-06???...
http://www.youtube.com/watch?v=0nqAf...yer_embedded#!
rear-wheel drive now.. what's your take on this miniers?
RevMaxx is offline   Reply With Quote
Old 10-15-2010, 06:02 AM   #13285
bodymot's Avatar
Default Ball Diff
Where I race in UK have now allowed ball diff’s ,
Just wanted to know if the mini 3-Racing ball diff was ok,
or would you recommend another make.
TC .UK. Tamiya M05, X-ray T3-09, GM Genius 120, MAMBA MAX PRO.
Member of T.M.F.F.R
bodymot is offline   Reply With Quote
Old 10-15-2010, 07:18 AM   #13286
RossoTorro's Avatar
Is it for the M05 or M03?
For M03 i would rather use TA03 balldiff.
For M05 i use 3racing with Tamiya thrustbearing, 2.4mm ceramic balls and TRF screw and nut. Seems to hold up better this way than Tamiya's own M05 balldiff. The orginal 3racing thrustbearing is junk, did not last a batterypack before it was worn out. I use standard TA05 bearing in mine.
Old 10-15-2010, 07:19 AM   #13287
MD
MD's Avatar
Trader Rating: 113 (100%+)
I have read some negative comments on the 3Racing diff. I think most people recommend the TA03 diff or the M05, but I'm sure others will way in.
MD is online now   Reply With Quote
Old 10-15-2010, 07:47 AM   #13288
bodymot's Avatar
its for M05.
Member of T.M.F.F.R
Old 10-15-2010, 10:23 AM   #13289
Send a message via AIM to jmhub1979 Send a message via Yahoo to jmhub1979
Kind of off topic. Yesterday I got in a massive car accident. Some of my rc stuff was in the trunk/backseat of my car. I'm just dreading to see how many pieces my little mini is in now. My 1/1 car is mangled. That was a bad ass car. 2006 Subaru Impreza.
jmhub1979 is offline   Reply With Quote
Old 10-15-2010, 12:02 PM   #13290
superspeed's Avatar
m06 pro vs. m05 pro, it's going to be a showdown in the upcoming tcs series.
superspeed is offline   Reply With Quote
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
)EIB(, seidemanus
