Tamiya mini cooper
#1310
Originally Posted by StadiumChris
Currently I have a Manta Ray diff.. so if I swap out to a TA03 diff and add the carbon hollow shafts, I should see a noticeable difference?
#1311
Whats the deal with the Tamiya 6mm hexs. I bought some and tried to install them on my Cooper. I used the drive pin with the kit. I snugged the set screw down and the hex still fell off. Pulled it apart looked at it the reinstalled it tightened it more. Tugged on it fell off again. I didnt pull to hard. Tryed to snug it a little more and the set screw broke. Any Ideas? Thanks My first thught maybe the drive pin is to short. The drive pin is a few mm shorter then the slot in the hex adapter and it cant quite tighten down properly?????? Thanks for your help
#1312
its tamiya and its for the mini. dont expect quality
#1313
I had the same problem and solved it by:
Took my robo-grips ( or a LARGE pair of pliers ) and squeeze it shut.
Then tighten the screw
If it didn't close all the way then:
Take screw back out and do the steps listed above again.
Problem solved for me.
#1314
#1315
Transponder mount
For those that race, where/how do you mount your transponder on the M03 chassis. I want to mount it so that I can run M03 or M03L wheelbase. I think I saw somewhere the transponder over the diff. Is that OK?
#1316
#1318
#1319
Over the battery sounds like the most practical place. I was afraid to mount it over so much metal. I think the right/passenger side would be better, I find that the M03 is a little weight biased to the left. That would also put it out of the way when opening the gear box. Thanks for the advice.
If I see the M03M #58368 Swift at Faszination Modellbau I'll try to get some pics of the suspension and post them here. I hope it doesn't make the old M-cars obsolete. Or, maybe I do.
http://www.faszination-modellbau-messe.de/en/35089
