Like Tree173Likes
Old 08-27-2010, 09:27 PM   #13051
mitsubishi's Avatar
want to ask guys which one you would recommend, ta03 ball diff or Mo5 ball diff? we are using carpet tracks...thanks...
mitsubishi is offline   Reply With Quote
Old 08-28-2010, 01:48 AM   #13052
RossoTorro's Avatar
Originally Posted by sidecarphil1 View Post
do they ???
i have had no problems with mine ??
they are great and a lot cheaper then the Tamiya ones
The trouble with 3racing diff is the thrustbearing, mine did not even last a battery. I even took the diff apart and regreased it before use. Changed it to Tamiya TRF415 thrustbearing and holds up well. Bought a new diff and tested it with carbide diff balls and Tamiya thrustbearing, It's one of the smoothest diffs i have ever felt. Runs great and excellent traction. The diff is good, but not right out of the box!
RossoTorro is offline   Reply With Quote
Old 08-28-2010, 03:05 AM   #13053
Originally Posted by gashuffer View Post
For those who run Sweep tires. What size are they 55 or 60 and which shure is the best for asphalt? 33's? Also which inserts do you recommend? Thanks. I'm asking because I'm limited to 55's with the Berlina body
I have the Sweeps 33 tires with medium inserts but have not run them so I can't comment on how well they do on asphalt. I can tell you the tires on Sweeps wheels come out about 53mm outside diameter.
You're going to race that nice Abarth body?
Sydewynder is offline   Reply With Quote
Old 08-28-2010, 03:19 AM   #13054
If you're going to crank the diff down to avoid wheelspin out of corner then m05 diff isn't the one you want. The screw and lock nut are too small and you'll most likely break the screw. It is nice that it has plastic blades to avoid outdrive wear but the diff rings are pretty low quality plus they're not notched to fit the cut in the diff halves.
TA03 diff have been a reliable diff for a long time. Just make sure the drive cups don't slide out (use orings or fuel tubing to hold them in) and strip the splines.
Old 08-28-2010, 04:25 AM   #13055
For the sake of argument and because it just seems counterintuitive to me, what's the point of using a ball diff if you are going to crank it down to the point that it acts like a limited slip diff? A ball diff is designed to do just the opposite of what you are trying to get it to do. The thrust bearing is failing because you are overloading it. Same can be said about the bolt/nut.
I read on other threads where touring car guys are using the new Spec R gear diff on the front to get the same effect that you guys are trying to get. They are replacing a ball diff with a gear diff and you guys are replacing a gear diff with a ball diff. I think we all agree that a limited slip effect is better for getting the power to the ground getting out of the turns. It just seems to me that a gear diff is more suitable for this than a ball diff.
My OEM gear diff with two shims and a little AW grease is very smooth and yet has a very good limited slip action. Turning one wheel will spin the motor rather than the other wheel. It's also as reliable as a hammer.
woodys3b is offline   Reply With Quote
Old 08-28-2010, 04:29 AM   #13056
gashuffer's Avatar
Trader Rating: 48 (100%+)
I just run at the track, nobody else has a mini. I would race it if they're was a class
T-Sal
gashuffer is offline   Reply With Quote
Old 08-28-2010, 04:36 AM   #13057
gashuffer's Avatar
These are good points, but gear diffs are just to loose(even with AW grease) compared to ball. You can adjust them without taking the diff out. If I drive in a circle with moderate power you can see, hear and feel the difference. For me at least.
T-Sal
Old 08-28-2010, 06:10 AM   #13058
Julius's Avatar
You can fill the diff with thick silicone oil. I use 80k oil. Needs a bit of work now and then as it leaks a bit at the outdrives but yu have the advantage of the loose diff off throttle with the locking properties of the thick oil on throttle.
I just need a bit of more work at the outdrives to seal it a bit better
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 08-28-2010, 06:30 AM   #13059
bodymot's Avatar
I agree with you,
I have run touring cars for years when I started racing minis ran with a ball diff but didn’t like the feel,
had to tighten the screw right down to stop the wheel that lifted in the corners spinning out and losing some drive.
Everyone is different but the only thing wrong with kit gear diff was one wheel would spin when not in contact with the track,
and if the gears spins too much would wear it out.
I have run kit gear diff for months now and it is still like new.
All I use is FG sticky grease (FG 6512) fill it up.
I think it’s smoother than ball diff that’s tightened right up but will rotate in corners when both wheels on the track,
helps the wheel that lifts from spinning. Might be a bit heavier,
The best bit for me, build it and forget it. Like you said (It's also as reliable as a hammer)
I’m still new to Tam mini racing and might be wrong,
But it works for me .
TC .UK. Tamiya M05, X-ray T3-09, GM Genius 120, MAMBA MAX PRO.
Member of T.M.F.F.R
bodymot is offline   Reply With Quote
Old 08-28-2010, 09:10 AM   #13060
I think you need to find what is best for you personally
I like my ball diff feel and it isn't as tight as it can go
I use a lot of thicker grease for the balls and the diff rings then the thrust bearing gets AW grease on it then i tighten it till it wont slip
stick it in and bobs ya uncle , worked loverly for over 6 months indoors and outdoors
I found with the gear diff if i added spacers it wore the teath off the innergears and no matter what oil / grease i added it just poured out after one race , i even tried the really thick grease for the 5th wheel on a Articulated lorry but that made a real mess . . . . . . . .
sidecarphil1 is offline   Reply With Quote
Old 08-28-2010, 07:06 PM   #13061
gruman28's Avatar
Trader Rating: 16 (100%+)
I run the mini sweeps, 40 front and 33 rear. I buy the 4 pack, that comes with tire insert and rim. I have to buy two packs (33 and 40). I just glue them and go! The sweeps last forever compared to tamiya. They are smaller in diameter, so on an open track you lose a little top end.
I feel that the sweeps are a great handling tire and for the price you cant beat them!
gruman28 is offline   Reply With Quote
Old 08-29-2010, 04:44 AM   #13062
Originally Posted by bodymot View Post
I agree with you,
I have run touring cars for years when I started racing minis ran with a ball diff but didnít like the feel,
I think itís smoother than ball diff thatís tightened right up but will rotate in corners when both wheels on the track,
Iím still new to Tam mini racing and might be wrong,
For to put grease FG 6512.... is it necessary that the differential is watertight?
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 08-29-2010, 06:04 AM   #13063
I know what you mean.
I've tired antiware grease before and what as mess that made. Never the less FG grease has just arrived and I must say it's very, very thick.
I'm just going to wait a while now before putting it in
shawnh is offline   Reply With Quote
Old 08-29-2010, 07:10 AM   #13064
I`ve tested the Spice slicks on carpet and they work really really good. The problem is that they`re twice as much as most others.
Does anyone know something else on RCmart that works just as good?
Losi 8ight 2.0 EU - Nitrotec - Nitrotane - Spektrum - Savox - AKA
Team Assocoated B4 - B44 - Reedy - LRP
Tamiya M03R
runar80 is offline   Reply With Quote
Old 08-29-2010, 07:41 AM   #13065
bodymot's Avatar
Default I tried other thick grease types
I tried other thick grease types but with this one is really sticky and doesnít go too thin when it warms up,
used to run it in 1/5 marder rear diff years ago.
Had none leak out of the out drives.
Been running it for a few months now had a little leak inside of chassis but only a small amount.
Just like how it feels coming out of corners and the best bit, build it and forget.
But everyone is different.
Iím still new to mini racing but just liked it better than ball diffís.
Member of T.M.F.F.R
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
