Like Tree23Likes
Old 08-09-2010, 11:03 PM   #12931
gtfour93's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Sydewynder View Post
Grandpa sounds like you found the correct pinion.
The M03/M05 uses .6 module pinions. This is the same as Robinson Racing's Metric 48 pitch pinions found here (20T) http://www3.towerhobbies.com/cgi-bin...?&I=LXEX43&P=7
But the setscrew uses is a standard allen wrench and not a metric one.
Thanks for clarifying that.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 08-10-2010, 05:43 AM   #12932
tudor_47's Avatar
I could not find, by searching this thread, what the straight body pins used in the rear of a M05 is from?
I need to pick up a set for my M05 to mount a corsair chevy pick-up on it.
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 08-10-2010, 08:09 AM   #12933
i used a modified set from a TT01 for my mini pickup body
sidecarphil1 is offline   Reply With Quote
Old 08-10-2010, 10:00 AM   #12934
Could someone share some info about the front upper arm hop up options available?
I would prefer something adjustable but i only find solids in aluminium.
I like this this tho http://www.rcmart.com/catalog/rc-tam...h=595_744_1389
Shame its not available a similar to the front.
MatsNorway is offline   Reply With Quote
Old 08-12-2010, 05:15 PM   #12935
tony gray's Avatar
Mats I don't believe there are any adjustable fronts available, can't say I've ever seen any.
The fronts are so short it's difficult to do.
tony gray is online now   Reply With Quote
Old 08-13-2010, 12:29 AM   #12936
andrew-01's Avatar
QFT.
When I tried those adjustable links, even with the smallest spacer I was at positive camber. Even then taking the spacer out I had to much positive camber up front.
I use the stock Tamiyas for the front uppers and those(the linked in the post above) after market links for the rear toe in/out and also for the rear uppers couple with alum rear toe axle carriers.
ANDRXW.com
andrew-01 is offline   Reply With Quote
Old 08-13-2010, 03:40 AM   #12937
I believe 3racing produce a kit with adjustable front and rear upper links for the M05. I dont appear to be able to post links but the model number is M05-16/LB . Never tried them so can't say how well they work.
V1nce is offline   Reply With Quote
Old 08-13-2010, 06:57 AM   #12938
gashuffer's Avatar
Trader Rating: 48 (100%+)
You can always make your own with some threaded rod and ballends. Dubro has all different size rods.
T-Sal
gashuffer is offline   Reply With Quote
Old 08-13-2010, 08:31 AM   #12939
I believe those needed on the M03 is shorter than those on the M05? at least on the front?
Old 08-13-2010, 01:35 PM   #12940
RossoTorro's Avatar
I used from TL01.
RossoTorro is offline   Reply With Quote
Old 08-14-2010, 09:21 AM   #12941
gashuffer's Avatar
Looking to get a esc Bl motor combo for my car. Which ez-run system is everyone running. I am not looking for a super fast car, just something efficient and controlable. I am just running for fun. Or should I just get a black can and call it a day. I do want to run a 2cell though. Thanks
T-Sal
Old 08-14-2010, 03:33 PM   #12942
eZrun 35a with a 13t (3000kv) motor seems to be the norm for Mini's
4_cell_racer is offline   Reply With Quote
Old 08-14-2010, 03:49 PM   #12943
If you aren't following any rules like TCS I would get the Hobbywing EZRun system with a 13T motor (sensorless) or the Speedpassion Cirtix 17.5T(sensored). The Hobbywing is a bit faster. Both should be around $70-80 US. I wouldn't bother with a black can. There's too much variation in it and you could end up with a dud. Plus it'll need more maintenance and replacement than the brushless. The cost of the black can and a brushed esc is going to be the same if not more the those 2 systems.
Sydewynder is offline   Reply With Quote
Old 08-14-2010, 03:58 PM   #12944
gashuffer's Avatar
Does Cirtix have a 21.5? I have a 17.5 in my GT car and it's really fast. I wanted something more along stock speeds.
T-Sal
Old 08-14-2010, 04:25 PM   #12945
As far as I know for now there isn't a package deal with a 21.5T. The Cirtix esc is just a BL non ramping/turbo boosting esc. You can buy a 21.5 motor that would work with the esc but the cost of the motor (from Tekin, LRP, etc.) is going to cost around the whole 17.5 system so its not economical.
The M03 can easily handle the speed of EZrun 13T.
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Burlap
