Like Tree200Likes
Old 02-28-2006, 05:33 PM   #1276
Send a message via AIM to Bane
So does anyone know for sure or not if the new double wishbone suspension will fit the existing M03 or M03L chassis?
Bane is offline   Reply With Quote
Old 02-28-2006, 09:15 PM   #1277
Toesup's Avatar
Lightbulb Rollover
Hi guys, i'm new here.
I have attached a couple of pics of the latest re-incarnation of my 'Cooper' and its stable mate.
I'm running a 19 turn motor, 1800 NiCads and a standard 20 tooth spur gear. I cant quite keep up with the XXX's and TC3's on the straight, but because of the Sorex slicks i can run rings round the opposition in the corners.
It handles just like the real '98 Cooper i had when i was back in GB...'sigh', i wish i had bought it over to the USA with me...'Sigh'.
A couple of questions...
1/ I dont see many rear aerofoils on Coopers i have seen here, do you think they are a disadvantage?.
2/ I am suffering severe 'rollover' in the tighter corners, even though i have lowered the Cooper to within mm's (1/16"s) of the ground. Any suggestions?.
3/ Even though i am running Sorex slicks, i am suffering with extreme wheelspin and i was considering changing up to a 22 tooth spur to get more straight line speed.. will this increase the wheelspin?.
Toesup is offline   Reply With Quote
Old 02-28-2006, 09:42 PM   #1278
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Can anyone confirm if this body:http://www.hpiracing.com/bodies/body...ber&value=7024 will fit the m03 chassis with no probs
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 02-28-2006, 09:50 PM   #1279
ckbridge's Avatar
Default civic body
I belive the HPI Civic body is a 225mm wheel base. The M03 is 110mm and the M03L is 139mm. The new M03M is 225. So if you could get the chassis extender from the M03M the Civic would fit. I am waiting until parts are available for the M03M to use a HPI golf body.
ckbridge is offline   Reply With Quote
Old 02-28-2006, 10:04 PM   #1280
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
the civic body doesnt fit mine very well... its too long for the short chassis, and the long chassis is too long to fit the body...
seems like it fits the short M04 chassis... cant verify it at the moment, but maybe tomorrow, if no one else chimes in....
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 02-28-2006, 11:57 PM   #1281
danjoy25's Avatar
Looks like the M03-M is the go then. Thanks guys I also got a reply from RC-Champ that the Suzuki M03-M will be out end of this month for anyone wanting one.
Old 03-01-2006, 01:10 AM   #1282
414play's Avatar
im sure its only the uprights and c-hubs that have changed, arms stay the same.
414play is offline   Reply With Quote
Old 03-01-2006, 02:00 AM   #1283
t4m1y4niac's Avatar
Default mini cooper
how Toesup can change the spur with the 22 tooth one??
i'm from Indonesia using solid axle for my MO-3L and it's works well in any track conditions, it just a little bit heavy on the diff because i locked 'em with araldite.
t4m1y4niac is offline   Reply With Quote
Old 03-01-2006, 07:34 AM   #1284
Default Tyre wear
Hi guys looks like my mini tyre wear more to innner side than the outer.I tried criss cross the tyre.Looks like no differ.What should I do to make it wear evenly.Should I toe in more or toe out.
If I wanna change my chasis screw to Titanium or aluminium.What type of thread should I get
a)tapping screw thread as the original
OR
b)machine thread
X1 CRT
KO HELIOS
9351,9451
STS.28
JP3
JConcepts
faiunie is offline   Reply With Quote
Old 03-01-2006, 08:19 AM   #1285
SWAMPER's Avatar
will the speed gears work with a TA03 ball diff ???
SWAMPER is offline   Reply With Quote
Old 03-01-2006, 08:37 AM   #1286
asw7576's Avatar
How is the feeling when using solid axle ?
I'm thinking to use solid axle to minimise wheel spin.
Answer for your question about 22t pinion ? I think it's not possible, max. is 21t ( after the spur gear is worn out ). As everybody know this is illegal for TCS / TAC .
Old 03-01-2006, 10:35 AM   #1287
ckbridge's Avatar
Default pinions
The Robinson pinions are smaller than the Tamiya with the same number of teeth. I.E. a Tamiya 20T and a Robinson 21T are the same diameter (sp?). Not TCS but good to know. So after the spur is worn a bit a 22T Robinson will fit.
Old 03-01-2006, 01:44 PM   #1288
danjoy25's Avatar
What would you guys recommend to get:
53597 M03 Assembly Universal Shaft Set
or
53205 M-Chassis Universal Shaft Set
Also on the shocks. Is alloy alot better than plastics or is it mainly a bling factor?
Thanks again
Old 03-01-2006, 01:53 PM   #1289
Turbonium's Avatar
i really like the alloy ones... mainly for the threaded adjustment. not too pricey, really...
id get the newer drives, with the cvd-style pivot, instead of the older u-joint style... think the newer ones would be the 53597.
Wes
Team Novak
Old 03-01-2006, 02:32 PM   #1290
danjoy25's Avatar
Thanks again
Tamiya Mini Cooper M-03L Hop-ups mini71 R/C Items: Wanted to Buy 8 01-12-2017 04:48 AM
Tamiya Mini Cooper mach51 R/C Items: Wanted to Buy 10 09-01-2011 11:08 PM
FS:TAMIYA Mini Cooper, TA 04S rthmotorsports R/C Items: For Sale/Trade 4 10-20-2007 08:37 PM
Tamiya 415 MSX and M03 Mini Cooper F/S Racer X79 R/C Items: For Sale/Trade 14 12-22-2006 06:38 AM
Tamiya M01,02,03, or 04 Mini Cooper ccugolf.com R/C Items: Wanted to Buy 2 12-05-2004 07:55 PM
Tags
m03, m03r ules, m05, mini, tamiya
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
